| Re: spi sailing
[Re: Arjan13]
#252472 09/19/12 09:07 AM 09/19/12 09:07 AM |
Posts: 6,049 Sebring, Florida. | You should be steering that slalom course in gusty winds, that's normal.
With every big gust, you have to bear off and run deeper, or, as you did, you'll flip, even if you are flogging the spinnaker, it's still a lot of drag up there pulling you over.
So just bear away in every big gust, and go fast with the spin trimmed in.
You should be looking back over your shoulder all the time, looking for the next gust so you'll be ready to bear away when it arrives. Do not wait until you are already nearly flipped over.
Blade F16 #777
| | | Re: spi sailing
[Re: Arjan13]
#252473 09/19/12 09:08 AM 09/19/12 09:08 AM |
Posts: 1,246 Orlando, FL | Sailing a spin boat (with Spin hoisted) is a little counter intuitive to the new sailor.
One thinks that going slow is "safe" ... but it is not. You need to keep maximum boat speed to minimize the differential between your boats apparent wind and the upcoming gusts.
Example:
Let's say the wind is blowing at 15k gusting to 23k. If you go slow and only achieve 8-9k the difference between your boat speed and the upcoming gust is 14-15k (additional) on your sail plan.
On the other hand, if you achieve 15-17k then the differential between your boat speed and the upcoming gust is 6-8k -- alot more manageable.
USA 777
| | | Re: spi sailing
[Re: Arjan13]
#252475 09/19/12 09:20 AM 09/19/12 09:20 AM |
Posts: 3,224 Roanoke Island ,N.C. | Like Tback said speed is your friend. By dumping the spin sheet you are reducing/eliminating your boats ability to bearaway (go deeper downwind) so by doing so you are powering the boat up by slowing down and bringing your apparent wind more to the beam. Trimming on the kite ,if you are at speed, can increase your speed and get the boat downwind to a safe power zone faster if the helm and skipper are in tune with each other . If not ,often the rudders will cavitate due to the sudden addition of extra power and without depowering to get them connected up again, you will have no steerage. Blowing your main can break your mast, dumping some traveler may be an option as long as tension remains on your mast in a proper alignment to act as a backstay.
| | | Re: spi sailing
[Re: Team_Cat_Fever]
#252476 09/19/12 09:25 AM 09/19/12 09:25 AM |
Posts: 5,590 Naples, FL | +1 on easing the traveler and driving down in a puff. You can bring it back up once you get organized or the puff runs out
Also, try not to head too high up between gusts... it makes the boat heel further when the puff hits, as well as making it harder to drive all the way back down.
| | | Re: spi sailing
[Re: Arjan13]
#252518 09/20/12 07:50 AM 09/20/12 07:50 AM |
Posts: 6,049 Sebring, Florida. | And if you pull your dagger boards up half way, it won't fly the hull as quickly, so if you're having trouble with it popping up in every gust, try pulling the bords up, see how that works for you.
Blade F16 #777
| | | Re: spi sailing
[Re: Arjan13]
#268181 12/31/13 07:57 AM 12/31/13 07:57 AM |
Joined: Jun 2012 Posts: 97 The Netherlands Arjan13 OP
Posts: 97 The Netherlands | Also this year we're still working on the spi control. I think it's realistic to say that we experience no problem what so ever in a wind up to 18 knots. But when the gusts are getting bigger or the basic wind is increasing, there are still moments that we are loosing the control once in a while. Last saturday we went out sailing again, and it happened a few times again, but we caught it on video. I made a video of that day, and left two moments in on purpose, to show you. I hope you can tell me what we are doing wrong here. Two times after eachother we experience a gust of around 20 knots. You see the cat's diving in the water with the bow. Of course the hull is getting up, and therefore my natural reaction is to let go of the sheet. We already were sailing with the traveler far out. http://www.youtube.com/watch?v=-KYCMV1yFIk (see at approx. 1 minute) The questions we have: 1) Of course what are we doing wrong here. Should we anticipate better/earlier, or do we anticipate in the wrong manner? 2) We've been told that we should keep the sheet at such length just before the point that the spi collapses. When the wind increases the length of the sheet increases. But just that is making that the spi will sometimes collapses hard. (hope my English is explaining right) Is it right to lengthen the sheet when the wind increases? 3) And probably the most stupid question of the day: In September we participated in a long distance race, where we eventually sailed 40 km to the wind, and 40 km downwind. The wind was 5 bft, and when going back the wind force was increasing with gusts of 6 bft. We were tired, and had multiple moments where the spi was taking off with us. Also the new spi course was not very helpfull, so we decided to take it in, and proceed without. However we were not used at all to sail downwind, with this kind of windpower, we never did it before, and had to figure it out when tired and water was flying around our heads. We managed to get back, but lost a lot of time (and places) the last 20 km. We didn't know if we should sail the main with the traveler wide open with such wind, and if we should keep the sheet tight, or let is go? In trapeze or not? Can anybody explain these basics to us? Thanks in advance, and I wish you all many good sailing hours in 2014! | | | Re: spi sailing
[Re: Arjan13]
#268185 12/31/13 11:04 AM 12/31/13 11:04 AM |
Posts: 12,310 South Carolina | It could be an effect of the camera but it looks like your spinnaker luff is too loose. This will cause you to have to sail higher into the wind in order to get wind into the kite and cause it to be more powerful over a wider range of wind angles. With the luff too loose, it will be less powerful on deep angles leaving you slower when you are trying to sail deep to get around a race course efficiently. The soft luff / fuller kite will also carry power over a wider angle of apparent wind which makes it less sensitive to helm corrections as you change your course reacting increased wind pressure and additional boat speed. The fuller kite means you have to steer more dramatically causing lost speed and distance. Tighten the luff and you can sail deeper and make smaller changes in the helm to accommodate the changing wind / boat speed.
When setting up the spinnaker on shore, you should hoist it fully and with the sheet loose, you should grab the luff of the spinnaker making a fist with the luff on the interior of your fist and rotate your hand 45 to 90 degrees before the spinnaker is tight and prevents your hand from rotating further. You want the spinnaker luff to be almost tight when hoisted fully. I bet this will help make the boat easier to sail downwind.
Jake Kohl | | | Re: spi sailing
#268193 01/01/14 06:19 AM 01/01/14 06:19 AM |
Joined: Apr 2013 Posts: 858 Victoria Australia Pirate
Posts: 858 Victoria Australia | .... it looks like your spinnaker luff is too loose .... x2 and at the 0:38 mark (no spinaker) and onwards the entire rigging is flapping about, the leeward shroud looks to have 10" of movement mid length. it might be my eyesight or the camera view, but the mast looks to move as well as the shroud slackens and tightens, I think that's also visible as the guys on the trap seem to momentarily bob up n down in the heavier chop Everything looks too loose to me......  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
Kingy started with Impara Cadet #3 / Mosquito #245 & now Mosquitos #1182 & #1740 | | | Re: spi sailing
[Re: Timbo]
#268194 01/01/14 06:21 AM 01/01/14 06:21 AM |
Posts: 858 Victoria Australia | And if you pull your dagger boards up half way, it won't fly the hull as quickly, so if you're having trouble with it popping up in every gust, try pulling the bords up, see how that works for you. ok .... I gotta ask.... how does lifting the daggers alter the speed in which the hull lifts  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#268195 01/01/14 07:14 AM 01/01/14 07:14 AM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | .... it looks like your spinnaker luff is too loose .... X3, it looks to me like the spinnaker was not fully hoisted. If you mark the halyard at the block when it is fully hoisted on the beach, you will know on the water if you have it fully hoisted. I have on many occasions thought that I had the spin fully up due to pressure when I was still 2 feet short. The skipper then had to go lower to release the pressure so that I could hoist the last bit. I'd personally pull that tack line a little tighter, too. -Rob V. Rob V.
Nacra 5.2
Panama City | | | Re: spi sailing
[Re: Pirate]
#268197 01/01/14 09:32 AM 01/01/14 09:32 AM |
Posts: 12,310 South Carolina | And if you pull your dagger boards up half way, it won't fly the hull as quickly, so if you're having trouble with it popping up in every gust, try pulling the bords up, see how that works for you. ok .... I gotta ask.... how does lifting the daggers alter the speed in which the hull lifts It raises the center of rotation of the boat higher. With boards in the water resisting the sideways motion of the boat, the boat hinges around a point somewhere under the water where the lateral resistance of the boards resist the side force from the sails. If you raise the boards, you raise that pivot point closer to the surface of the water giving the sails less leverage to heel the boat. When you raise the boards, you trade off a little resistance to sideways travel for a higher center of rotation and less wetted surface. This helps increase your speed potential downwind because of two things: 1) your speed increases so the boards are generating more lateral resistance and 2) a ~little~ side slip downwind isn't hurting you as it is taking you deeper down the course* *you might think that a ton of side slip downwind would get you to the mark faster but you also have to consider that a hull sliding sideways in the water is MUCH more draggy than a hull traveling in a straight line. If you raise your boards completely out of the water you will get a lot of side slip and speed will be reduced.
[Re: Arjan13]
#268213 01/02/14 02:26 PM 01/02/14 02:26 PM |
Posts: 5,590 Naples, FL | your strategy for point #3 above (downwind without spin) would likely vary In your situation, it would seem that you were more concerned with keeping the boat manageable (by dropping the spin) rather than maximum VMG. In that case, I'd keep some traveler in for the "reserve" should a sudden puff or something pick the boat up and you need to reduce power (in combination with a heading change). Weight should be all the way on the back of the bus, and boards up somewhat depending on conditions. The strategy would be to reduce lift and avoid knockdowns. If it's really honking, some advise to sheet main/traveler in tight and go really deep. This reduces the mainsail's "profile" to the wind, thereby reducing power/heeling force. I think many here on the forum have experiences with the "death reach" zone, where you really don't know what option (heading up or down) will cause the least amount of collateral damage. The consensus is deep reach = drive down / tight reach = head up when overpowered. Between those two is the problem...  And I think all agree with your spin luff being too lose, with the boards being a bit too deep. From your dramatic steering when hit with the puffs, you were likely heading up too high to hunt them, and didn't have the boatspeed/apparent wind to turn that heeling into forward propulsion.
| | | Re: spi sailing
[Re: Arjan13]
#268215 01/02/14 03:35 PM 01/02/14 03:35 PM |
Posts: 833 St. Louis, MO, | You are doing it mostly right.
Keep the luff tight. Don't travel out much unless you have too. Travel in and sail lower and faster. When the gust hits big then travel out, hike harder (skipper)., and drive down. I didn't see any hiking by the skipper or travelling out.
Mike Hill N20 #1005
| | | Re: spi sailing
[Re: Arjan13]
#268220 01/02/14 05:34 PM 01/02/14 05:34 PM |
Posts: 858 Victoria Australia | I agree with you the shroud seems loose. However pleae believe me if I say our rigging is rather tight. On this type of boat we do not have the ajustable system yet (as on the Infusion) so we use the main sheet and traps to set the tension on the shrouds. They feel "hard", especially compared to many other boats. (but who sais they know?) Maybe we should check anyway when we have somebody with a gauge available. another one I'd check would be the dolphin striker's tension...... years ago I had an adjuster bolt failure on the striker, on the beach and rigged it wasn't noticeable at all and my home made shroud tensioner at the time said all was as usual when it was checked. on the water in a good wind it was a different case, on a reach I actually saw the leeward shroud adjuster flopping around, once back on the beach all the rig was reset and I went out for race 2.... again the shroud adjuster was flopping around on that reach although not as badly as it was when I first noticed it. It wasn't until I was pointing hard that I noticed the huge bend in the front beam  its a wild shot in the dark but still worth checking and crossing off the list  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Arjan13]
#268301 01/07/14 10:42 AM 01/07/14 10:42 AM |
Posts: 97 The Netherlands | Last weekend we sailed again, and of course it was the opportunity to try some things. We had the perfect wheater with wind around 18 knots. First of all we found out that in the past we eased the spi sheet when the puff hits. This weekend we tried to do it as explained by easing a little bit and then sheet in again. We also decided to keep the travelar in. We had a hard time seeing the puffs coming, and decided to keep the sheet as it was for some time. We experienced that this was already much better. more direct steering and control, no collapsing of the spin, and less agresive steering. We still have to learn, but this was a step forward. We also measured the spinaker as suggested before, and came to the conclusion it is rather big?? See below photograps: ![[Linked Image]](http://i40.tinypic.com/2en84g0.jpg) ![[Linked Image]](http://i39.tinypic.com/2hpj97d.jpg) ![[Linked Image]](http://i39.tinypic.com/14nfbsh.jpg) We had to turn over the cat due to the strong wind, so we measured once at the mast, and once at the luff (don't let the extra pole mislead you, we use it for our camera) At both positions it's clear that we have some extra length compared to what was said / explained earlier. We checked the spi but it's original, and however its old, it isn't used too much. So is it streched? Or is this normal with our boat? (inter 18) Should we be worried?
2,570
guests, and 211
