| Re: Cross cut Mylar vs radial cut mylar. GO!
[Re: ]
#252692 09/25/12 08:45 AM 09/25/12 08:45 AM | MN3
| MN3
Unregistered | here is what my new main looks like | | | Re: Cross cut Mylar vs radial cut mylar. GO!
[Re: PTP]
#254555 11/11/12 06:09 AM 11/11/12 06:09 AM |
Posts: 5 | Looking for advice ,,, I have read the sail reviews here , and also will order a new set of sails , for my 18 sq ,which i am going to upgrade to run a jib and spin ,,However im told the F i8 main sail will fit the 18 sq 30 ft mast ,Can any one confirm this ,,or help me find ,Where can i get the sail plans for the F 18 ?? | | | Re: Cross cut Mylar vs radial cut mylar. GO!
[Re: AzCat]
#254676 11/13/12 09:50 AM 11/13/12 09:50 AM | MN3
| MN3
Unregistered | f18 sails fit very well on my 30' mystere mast
I purchased 2 used ones for around $500 each (one was heavily used, the other was an older model that had a repair from crew going through it during a capsize). | | | Re: Cross cut Mylar vs radial cut mylar. GO!
[Re: stormdog777]
#254677 11/13/12 10:36 AM 11/13/12 10:36 AM |
Posts: 1,121 Eastern NC, USA | ... for my 18 sq ,which i am going to upgrade to run a jib and spin ... Are you going to add a bridle foil or some sort of bow support before adding these sails?
Tom | | | Re: Cross cut Mylar vs radial cut mylar. GO!
[Re: AzCat]
#254952 11/19/12 01:52 PM 11/19/12 01:52 PM | MN3
| MN3
Unregistered | 26.7 seems more correct to me | | | Re: Cross cut Mylar vs radial cut mylar. GO!
[Re: AzCat]
#255179 11/26/12 09:05 AM 11/26/12 09:05 AM | MN3
| MN3
Unregistered | Doyle made it, took about 3 weeks, $1350 | | |
547
guests, and 51
