Need to modify hull cradles. #252588
09/23/12 04:04 PM
09/23/12 04:04 PM
california
F-18 5150 Offline OP
california
My hull cradles are too this for the hulls to touch the bottom of the cradle. This is making a pressure point where the top of the cradle hits the hull. I have seen some trailers with foam on the cradles to get rid of this problem. What kind of foam works best for this? Also where can I buy it?
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Need to modify hull cradles. [Re: F-18 5150] #252593
09/23/12 08:19 PM
09/23/12 08:19 PM
catman Offline
catman  Offline
Can you just trim off some of the cradle at the top and fix it?
Re: Need to modify hull cradles. [Re: F-18 5150] #252594
09/23/12 08:49 PM
09/23/12 08:49 PM
I used scrap pieces of carpet to build up the bottom of the cradle when I had this issue a while back.
Re: Need to modify hull cradles. [Re: F-18 5150] #252623
09/24/12 09:29 AM
09/24/12 09:29 AM
Houston
carlbohannon Offline
Houston
The 2 foams I use are minicell or Rubatex. Minicell can be found at kayak supply companies and Rubatex, I normally source locally. Minicell is smooth and feels nice Rubatex is used as an industrial insulation and is rough but very duraable. Be careful when ordering. Shipping gets very expensive for sections larger than 2 x 2 ft. Many companies are aware of this and offer "deals" on pieces that keep the shipping down.
I don't use carpet or anything that holds water. A few years during a wet winter, I had blisters form where the carpet held water against the hulls for months.
0 registered members (), 360 guests, and 330 spiders.
