| Re: Modify pinhead main to square-top?
[Re: evansail]
#253428 10/12/12 11:51 AM 10/12/12 11:51 AM |
Posts: 12,310 South Carolina | I am in the process of restoring an old Prindle 19 and plan to wrap things up this fall/winter. It came with a Dacron pinhead main that is in really good condition for its age.
The boat will be a fun weekend cruiser for the in-law's cottage (i.e. no serious racing) so the project budget is limited - but it would still be cool to have a square-top main.
Has anyone had an older pinhead main like this modified into a square-top? It seems like it would only require a few new panels and some additional battens and batten pockets (though I am obviously not a sailmaker).
I am curious if anyone has had success with this modification - and maybe a picture or two they would be willing to share, and how much I should expect a sailmaker to charge.
Thanks! Evan Evan, You probably could get something put together in the shape of a square head, but it may not be worth the $. Square heads require a good bit more leach tension in the sail to properly hold their shape and Dacron would not hold up well for this. Additionally, it may be tough to keep the (probably decent) flying sail shape you have now with the modifications. If you want a square head, you're probably better off having a new sail made from pentex or similar (mylar film fabric).
Jake Kohl | | | Re: Modify pinhead main to square-top?
[Re: bacho]
#253457 10/13/12 03:39 PM 10/13/12 03:39 PM |
Posts: 3,224 Roanoke Island ,N.C. | If it was me, I would sell the nice p19 main and buy a cheap f18 main. It should break even on prices. +1 Or an old N-20 main and have it modded if need be.
[Re: evansail]
#253504 10/15/12 12:51 PM 10/15/12 12:51 PM | MN3
| MN3
Unregistered | i have purchased 2 f18 sails (mkI&mkII) for my 94 mystere 5.5. they both fit and performed extremely well (the difference from my boat to a f18 is i have a center board f18 have daggers)
I have had 2 tornado mains (both cut down a bit to better fit my mast). worked well
I am not sure what size your mast is, mine is 30' | | | Re: Modify pinhead main to square-top?
[Re: ]
#253535 10/16/12 10:15 AM 10/16/12 10:15 AM |
Posts: 1,304 Gulf Coast relocated from Cali... | I saw a P19 main a few years ago that had been modified to a square top by Glazer, I think. Looked great. As far as Dacron not working? Not true. I had one on my H21se for a while and It was fantastic. There are a few Dacron square tops running around here in Texas that are holding up very well. One is at least 10 years old on a 5.8 and made by Calvert (the same maker of my 21se main) and is still raced quite a bit. But back to the original question about modifying, I think that's the way more than a few P19MX's were done in the first place.
Lee
1 registered members (FredL),
2,799
guests, and 283
