| Re: Bridle wire tang broke off at hull
[Re: TurboCat]
#253475 10/14/12 04:01 PM 10/14/12 04:01 PM |
Posts: 1,383 Kingston SE South Australia | I don't know anything about the Prindle but the angle of the existing bow tang should give you an idea of how it will be mounted. If its flat verticle it may be as simple as bolted to a bulkhead and that would be a relatively easy fix once in the hull. When cutting into the hull make sure you don't make a cut on top of a bulkhead as you wont be able to get your arm in the hole
[Re: Hullflyer1]
#253483 10/15/12 07:33 AM 10/15/12 07:33 AM |
Posts: 12,310 South Carolina | for backing to reinstall the hole, cut short popsicle sticks and glue them to the inside of the hull to make a "shelf" for the cutout to sit against. Use cloths pins clips to hold the sticks to the hull while the glue dries (epoxy or polyester resin) and be careful not to get any resin on the sides of the opening so your cut-out will fit back in without issue. Then mix up some more thickened resin and put it to the sticks and the edges of the opening (lightly). fit the cut-out back into the hull and rotate it back and forth to squeeze out the resin and get it at the same level as the outer surface of the hull. Tape it into position and let it firm up. With a small ziplock bag, fill it again with more thickened resin and just nip off a corner of the bag with scissors or a razor blade. Use this to squeeze in some more thickened resin around the perimeter of the repair filling the gap between the hull and the plate like icing a cake. This resin should be the thickest of them all - nearly like peanut butter in consistency. Scrape away any excess and let this cure. Then, with a side-angle grinder and a flapper sanding disk, I would sand around the perimeter of the repair you just made and dig into the fresh resin creating a little dished out area to lay in some new fiberglass to join the outer skin back together. Cut a bunch of fiberglass pieces and start to build the shallow U-notch you made back out slightly beyond the outer surface of the hull. Let it cure, sand with palm sander, skim coat with some premium bondo, sand, fill pin holes, gelcoat.
Jake Kohl | | | Re: Bridle wire tang broke off at hull
[Re: TurboCat]
#253486 10/15/12 09:13 AM 10/15/12 09:13 AM |
Posts: 8 Seabrook, TX | Thanks for the replies guys, I wasn't sure if my question would be seen as this thread was from back in 2009. I posted up again as a new posting, hope this is not a problem. This seems like it is going to be a BIG undertaking and I have no glass experience. I read and reviewed the photos Turbocat posted, it just looks like removing the top deck will give the easiest access but I don't even know if I can still find new top decks. Plus, not even sure how to get the top decks off.
Thanks for the help.
Morris Covin
Prindle 16 sail #5229 Prindle 16 sail #8647 Current ride; Prindle 19 sail #309
[Re: Sailinghoutx]
#253493 10/15/12 11:22 AM 10/15/12 11:22 AM |
Posts: 12,310 South Carolina | Thanks for the replies guys, I wasn't sure if my question would be seen as this thread was from back in 2009. I posted up again as a new posting, hope this is not a problem. This seems like it is going to be a BIG undertaking and I have no glass experience. I read and reviewed the photos Turbocat posted, it just looks like removing the top deck will give the easiest access but I don't even know if I can still find new top decks. Plus, not even sure how to get the top decks off.
Thanks for the help. I think going in through the side is a better option. A hole-saw may not provide a large enough hole, you may be better off to use a jig saw and cut the access through the side of the hull, then reinstall the panel you cut out. Removing the decks is really hit or miss...you may break the deck and I really doubt you'll be able to find a replacement....then again, maybe fixing the deck would be easier than the hole option?
[Re: TurboCat]
#253505 10/15/12 12:55 PM 10/15/12 12:55 PM |
Posts: 3,224 Roanoke Island ,N.C. | If you do use a jigsaw ,set the blade at 45 degrees so you cut the hole like the top of a Jack o' Lantern( \_/ ), then you have a larger stable gluing surface to re-mount the patch back on to. Makes fairing and finishing much easier, as well as a much sturdier repair.
[Re: TurboCat]
#253513 10/15/12 04:19 PM 10/15/12 04:19 PM |
Posts: 1,383 Kingston SE South Australia | I've removed a top deck before on another boat and it turned into a big job to get it tidy again. I would encourage you to do it through the side as the above posts by experienced people recommend. The more worried about your fibreglass skills the more you should go through the inside of the hull, even if you don't do a very good paint job on your repair nobody will notice it but your decks everyone will see. If you do manage to buy a new deck you need to trust your resin skills to glue it down with absolutely no gaps anywhere or it will suck water and it is very difficult to stop these leaks afterwards
[Re: JeffS]
#253514 10/15/12 07:36 PM 10/15/12 07:36 PM |
Posts: 3,224 Roanoke Island ,N.C. | I've removed a top deck before on another boat and it turned into a big job to get it tidy again. I would encourage you to do it through the side as the above posts by experienced people recommend. The more worried about your fibreglass skills the more you should go through the inside of the hull, even if you don't do a very good paint job on your repair nobody will notice it but your decks everyone will see. If you do manage to buy a new deck you need to trust your resin skills to glue it down with absolutely no gaps anywhere or it will suck water and it is very difficult to stop these leaks afterwards I've done both and getting the deck off without tearing or breaking it is very hard (Apparently too hard for me) if you are going to try and get the deck off you need to use a heat gun and a putty knife ,but not get the glass too hot. The side is easier, will finish better (especially if you do the pumpkin cut) and is less apt to be under as high stress loads as the deck will be. Just make sure you have open access before you cut i.e. not cutting into a bulkhead.
[Re: Team_Cat_Fever]
#253526 10/16/12 06:58 AM 10/16/12 06:58 AM |
Posts: 12,310 South Carolina | I've removed a top deck before on another boat and it turned into a big job to get it tidy again. I would encourage you to do it through the side as the above posts by experienced people recommend. The more worried about your fibreglass skills the more you should go through the inside of the hull, even if you don't do a very good paint job on your repair nobody will notice it but your decks everyone will see. If you do manage to buy a new deck you need to trust your resin skills to glue it down with absolutely no gaps anywhere or it will suck water and it is very difficult to stop these leaks afterwards I've done both and getting the deck off without tearing or breaking it is very hard (Apparently too hard for me) if you are going to try and get the deck off you need to use a heat gun and a putty knife ,but not get the glass too hot. The side is easier, will finish better (especially if you do the pumpkin cut) and is less apt to be under as high stress loads as the deck will be. Just make sure you have open access before you cut i.e. not cutting into a bulkhead. Aaaa! good point...avoid bulkheads. Cutting into one of those for your access hole has a suck factor of "12".
#253538 10/16/12 10:23 AM 10/16/12 10:23 AM |
Posts: 1,304 Gulf Coast relocated from Cali... | I agree with cutting into the sides vs. removing a deck. I need to cut into the sied of my N20 this winter and have been studying Jakes repair photos for ideas. Not to hi jack but has anyone ever noticed a thin, soft line in the side just below the no-skid where your heel rides when trapping out?
Lee
[Re: TeamChums]
#253547 10/16/12 12:58 PM 10/16/12 12:58 PM |
Posts: 12,310 South Carolina | I agree with cutting into the sides vs. removing a deck. I need to cut into the sied of my N20 this winter and have been studying Jakes repair photos for ideas. Not to hi jack but has anyone ever noticed a thin, soft line in the side just below the no-skid where your heel rides when trapping out? I've never noticed that on any of the 20's I've owned/worked on. Is it horizontal? There shouldn't be any structural feature to cause that (unless you have a Hobie Tiger-like sub deck for some reason).
#253599 10/17/12 11:23 AM 10/17/12 11:23 AM |
Posts: 1,304 Gulf Coast relocated from Cali... | It is horizontal and about 16" long. I'm thinking there may be a seam in the foam core here. I'll be cutting in a hole on the inside and likely laying up some carbon in there.
Lee
[Re: TeamChums]
#253615 10/17/12 08:45 PM 10/17/12 08:45 PM |
Posts: 337 Arizona | Mine had a 6" fracture when I bought it,. I chased it , glassed it and gelcoated it, seems to be solid so far. It was right behind the rear beam, 6" down.. It was easy to sand and add a layer of glass on the inside through the access port. I got lucky. There was no structural member there.
My 5.0 had a 6" fracture in front of the main beam. right at the top of the long. struct member. same fix. single layer glass hulls so I just fixed from the outside.
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | |
573
guests, and 1,065
