| Re: Repair advice
[Re: schobiedoo]
#25458 10/27/03 07:45 AM 10/27/03 07:45 AM |
Joined: Sep 2003 Posts: 270 Nepean (Ottawa) Ontario Canada Frozen
Posts: 270 Nepean (Ottawa) Ontario Canada | Don't get cheap bolt extractors! I have found that dispite my somewhat OK mechanical skills, I have found that bolt extracting is a somewhat difficult task to do well. In other words to drill a hole on the old bolt shaft without taking the threads can be difficult. I am lucky, I get the (aircraft) mechanics at work to do bolt extractions. If you do a bolt extraction, be very careful doing the punch for the drill to start in and use a new, sharp drill bit so the drill hole is a good quality straight hole. Put bolt anti seize oil in the hole to free up the old bolt. Probably stand the hull up so the oil can penetrate. Cheap extractors will break, compounding the problem and the frustration. Basically the idea is to use the largest extractor you can withut having to drill such a large hole that you ruin the bolt hole threads.
Sounds like you are lucky that the bolts broke rather than some other part, like the hull!. Probably was designed that way.
Cheers Alan F
Tiger
| | | Re: Repair advice
[Re: schobiedoo]
#25462 10/28/03 08:55 AM 10/28/03 08:55 AM |
Posts: 270 Nepean (Ottawa) Ontario Canada | Hmmm I don't know if that is true but if it is then get some loosenall type of bolt unfreezing liquid raise up the hull so the fluid will seep in around the bolt and try to turn it. Problem is how to turn it.
Ther only way I can think would be to use screw extractors but they work the wrong direction, so you would drill a hole and put a small screw driver that is larger than the hole and bang it in with the hammer and try it.
Just be careful you don't ruin everything in the process.
It looks like cmerrill is right but proceed carefully whatever you do.
Cheers Alan F
Tiger
3,079
guests, and 444
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
