| Main mast fitting N inter 20 '2002 #256385 01/18/13 01:32 PM 01/18/13 01:32 PM | norbert OP
| norbert OP
Unregistered | Hi, I am new to this forum, but excited to see, how much active posts here are! Last year my girlfriend and I started over with our cat sailing buying an Inter 20. We sail mostly in France or the Netherlands, so whether Atlantic coast or internal lakes. Hence, some repair I still have to do on the Inter 20 and I hope I can get some tips from you- I think to renew the mast main fitting, since the iron where the main shakle is placed , is worn out. I wonder, if there are washers on the inside of the mast to spread the force from the rivets into the carbon laminate of the mast. Maybe I would not be able to access these washers, when putting new rivets on the repaired fitting. (...?) On the other hand the replacement of these rivets may be just straight forward, just like any other rivet replacement on the aluminium parts of the boati.e.- I have no idea..... but surely I don't want to put damage to the mast following the intention to repair it.
Does anyone have experience in replacing the main fitting before, or does anyone know, how I could get in contact with the manufacturer of the mast?
Thanks in advance for all infos-
Norbert , Germany
| | | Re: Main mast fitting N inter 20 '2002
[Re: ]
#256881 02/02/13 02:55 PM 02/02/13 02:55 PM | norbert OP
| norbert OP
Unregistered | Hi Bacho & Elcazador, sorry, it took me some days to follow op your kind replies. Anyway, thanks for your tips! Looks like my inter 20 is not the only one that suffers from widened mast tang. But- drilling the old rivets repairing the tang outside with a much thicker vertical plate would forecome these troubles once and for all. Do you know the mast manufacturer, maybe they can tell which rivets needs to be fixed and if it would be wise to proceed in this way....
Norbert
[Re: elcazador]
#257050 02/06/13 08:58 AM 02/06/13 08:58 AM | norbert OP
| norbert OP
Unregistered | Hi, good idea, a tube should spread the tension much better than washers. You are right, any not perfect strong connection at that part of the boat bears risks to crew and material. Defining the right rivet isn' t trivial at all, not to talk about the way to fix them. If we talk about 6mm non stainless steel rivets, most hand pliers won't do. What annoys me @ nacra boats sometimes, is that same parts on smaller / as well as on larger boats are used, although wear is more stronger on an 20ft than on a 18ft. Same counts for rudder heads/ tillers, jib furlers, etc.
kind regards
Norbert | | |
619
guests, and 36
