| Re: Blade F16
[Re: waterbug_wpb]
#257497 02/14/13 10:41 AM 02/14/13 10:41 AM |
Posts: 932 Solomon's Island, MD | Pete,
Sailrocket is a rocketship, literally. They have custom foils because they are reaching custom speeds!!! You're not doing anything crazy with your Blade and standard airfoils designed to operate in turbulent flow are fine (NACA series). Others have generated perhaps better for our cats but these aren't freely available.
Rolf,
Good to know, that makes sense, thank you. You pay a little drag penalty going thicker on the NACA foils, but the advantage is a higher stall angle of attack, which is why you want a NACA0012 on the rudder. You should never approach stall with your dagger boards unless you are doing something wrong with boat handling, so the key there is minimizing drag. On a long board, you may select a thicker foil for structural reasons mentioned elsewhere in this thread.
I've come full circle and decided I would rather go sailing than build foils. I don't have time to repair boards because my layup was insufficient, nor do I want to deal with broken foils 30+ miles from my destination. Finally, I have a hard time justifying my materials cost relative to a set of production blades. Mold cost is staggering for the required materials; this is with free CNC time on a $50K+ machine! Carbon alone is $800 for the pair of long dagger boards!
Scorpion F18
| | | Re: Blade F16
[Re: waterbug_wpb]
#257498 02/14/13 10:45 AM 02/14/13 10:45 AM |
Posts: 5,525 | I was hoping to go with asymetric boards, thinking this would actually give me an advantage!
Remember F16 is a developement class and I'm using first generation boards (and case which will not accept the new boards without modification) while third generation are available.
Pete Pollard Blade 702
| | | Re: Blade F16
[Re: waterbug_wpb]
#257513 02/14/13 01:52 PM 02/14/13 01:52 PM |
Posts: 932 Solomon's Island, MD | Solo sailing with asym boards is a lot of work in the tacks.
Even double handed I wouldn't want to deal with it. Performance increase is likely mitigated by crew work level.
Scorpion F18
| | | Re: Blade F16
[Re: waterbug_wpb]
#257520 02/14/13 05:22 PM 02/14/13 05:22 PM |
Posts: 5,525 | There's an idea, hadn't thought of that.
| | | Re: Blade F16
[Re: waterbug_wpb]
#257536 02/16/13 10:37 AM 02/16/13 10:37 AM |
Posts: 5,525 |
| | | Re: Blade F16
[Re: pgp]
#257560 02/18/13 09:25 AM 02/18/13 09:25 AM |
Joined: Dec 2001 Posts: 5,590 Naples, FL waterbug_wpb OP
Posts: 5,590 Naples, FL | Foil "V" shape looks interesting. Might make the form rigid without expensive layups?
| | | Re: Blade F16
[Re: waterbug_wpb]
#257630 02/19/13 11:17 PM 02/19/13 11:17 PM |
Posts: 7 | What are the standard boards for a blade f16? Mine are similar to those on a taipan
Blade F16 with Viper beams
| | | Re: Blade F16
[Re: waterbug_wpb]
#257633 02/20/13 04:45 AM 02/20/13 04:45 AM | Scarecrow
| Scarecrow
Unregistered | Charles who built your boat, there are quite a few flavours of blade and it may well have taipan boards. For the record the Taipan, Blade and Viper all have the same mast. | | | Re: Blade F16
[Re: waterbug_wpb]
#257641 02/20/13 10:36 AM 02/20/13 10:36 AM |
Posts: 7 | I believe my boat is Australian built as I live in Singapore, the hull is kevlar with the short boards
| | | Re: Blade F16
[Re: waterbug_wpb]
#257642 02/20/13 10:40 AM 02/20/13 10:40 AM |
Posts: 5,525 | Can there really be a standard board? Since F16 is a developement class the boards can change almost at will.
I prefer to think I have generation 1 boards while others are using generation 3 or higher.
| | | Re: Blade F16
[Re: waterbug_wpb]
#257643 02/20/13 11:40 AM 02/20/13 11:40 AM |
Posts: 5,525 | fwiw, my boards extend approx. 21" below the case, and have a chord of about 11 1/2", and are approx. 3/4" thick (that's an eyeball measurement).
It appears to be NACA 0006
| | | Re: Blade F16
[Re: waterbug_wpb]
#257652 02/20/13 07:58 PM 02/20/13 07:58 PM |
Posts: 7 | does anyone build or sell blade foils these days or are they all home builds?
| | | Re: Blade F16
[Re: waterbug_wpb]
#257664 02/21/13 02:15 AM 02/21/13 02:15 AM |
Posts: 7 | Is there an Australian builder still around? just thinking about shipping costs etc
| | | Re: Blade F16
[Re: waterbug_wpb]
#257665 02/21/13 02:42 AM 02/21/13 02:42 AM | Scarecrow
| Scarecrow
Unregistered | measure your boards and post here (with a photo) so we can work out if they're taipan boards or not then contact ahpc and order either viper or taipan boards. It would also be worth trying windrush, Brisbane cat centre (nacra) and performance sailcraft ( laser/Capricorn 2) and seeing if they can help. | | | Re: Blade F16
[Re: waterbug_wpb]
#257666 02/21/13 02:53 AM 02/21/13 02:53 AM |
Posts: 7 | okay cheers, I'll post the info this weekend after sailing
407
guests, and 46
