Page 3 of 3 1 2 3
Re: Sail setting and sailing techniques [Re: Arjan13] #259561
05/12/13 10:49 PM
05/12/13 10:49 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
G’day Arjan I did almost exactly the same shape change with the sails on my Taipan 5.7 the boat became faster but I regulary pitchpoled until I worked it out a bit. I learn’t in high wind to tie my battens in relatively loosly so the downhaul can flatten the sail not just improve the shape and lay off the top.
On a good reach with plenty of wind I've found in a gust it's much faster and safer to round down with the wind keeping both bows down near the water if you round up you have to go up a fair way to go through the wind way off course which lifts your hull a lot more ready for a knockdown if the gusts solid. If you round down no one can pick you off as your using the full wind strength and you come back up onto the original course as the gust recedes. For me I’ve found boards depend on the course, waves and wind, in big waves I need all of the boards to keep me higher and stop getting swatted off the side by the waves, as in my video on the other thread. Flat water very big wind around the 30 kts I’ve had leeward up windward down so as the gust lifts me right up the boat slides sideways and comes down again but it’s a wet wild ride.
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Sail setting and sailing techniques [Re: Jake] #259567
05/13/13 07:43 AM
05/13/13 07:43 AM
If that reply came off "hateful" I apologize - I was in a hurry and a foul mood. smile
Re: Sail setting and sailing techniques [Re: Arjan13] #259573
05/13/13 04:29 PM
05/13/13 04:29 PM
Scarecrow
Scarecrow
Didn't come across as hatefull, just a typical forum reply. As with anything in life there is a difference between what we all do and what we should do. In threads where people are asking for advice I always try and recommend the "best practice" solution (even where I don't apply it myself) so the person seeking help has all the info they need to decide themselves what they want to do.
Re: Sail setting and sailing techniques [Re: Arjan13] #259740
05/21/13 02:00 AM
05/21/13 02:00 AM
Arjan13 Offline OP
Arjan13  Offline OP
Yep... I always try to find the best answer. Or the answer in between what will work out the best for me. Indeed around the pop rivets the mast has some wear, now we have fixed it again, and made the system usable again.
@Jeff Thanks, we'll keep it in mind, and also try to play a little with the battens. I think we're at a point where we just have to trial and error a bit
Page 3 of 3 1 2 3
0 registered members (), 2,509 guests, and 222 spiders.
