| Re: 1763 Deck Re-build
[Re: Rebel without a Clew]
#261791 07/28/13 04:47 AM 07/28/13 04:47 AM |
Joined: Apr 2013 Posts: 858 Victoria Australia Pirate
Posts: 858 Victoria Australia | What have I started  Good to see others doing similar repairs  How's the Vale these days, been a couple of years since I've been "home", lots of family in that area..... Kingy Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
Kingy started with Impara Cadet #3 / Mosquito #245 & now Mosquitos #1182 & #1740 | | | Re: 1763 Deck Re-build
#261829 07/29/13 04:20 PM 07/29/13 04:20 PM |
Posts: 858 Victoria Australia | yes the foam stations had separated from the hull sides but at different degrees and in a patchy way..... not all of them had let go and whilst a couple had completely become detatched others had only slightly let go, I also had a couple that had cracked across the actual foam and yet were still well attatched to the hull. I think what happens is the glue at the foam/deck/hull connection area is under constant stress, weight on the deck pushes down and therefore this pushes the hull sides apart, once the glue begins to fail the foam subframes begin to compress, this inturn allows even more pressure to be placed on the hull side and so the glue continues to fail further downwards allowing even more foam compression/failure.... once the stone starts rolling effect  be interesting to see your approach..... Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
#261930 08/01/13 07:45 AM 08/01/13 07:45 AM |
Posts: 858 Victoria Australia | the failures are almost identicle to mine.... I see the foam has had the top section replaced already somewhere along the line  otherwise the construction of your hulls is scaringly similar to mine..... even the conduit for the trap is set in the exact same manor and position as are the actual subframes....  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
#261935 08/01/13 08:06 AM 08/01/13 08:06 AM |
Posts: 92 South Oz | Hi Roy, Following this rebuild with interest as with Pirate's rebuild. Where your entry lists 10 or 7 downloads and I can only open one, is there a process I am not undertaking to see all the images? I am learning a lot about how this generation of boats were assembled. Simon's is the 3rd redeck I have studied in the last 18months. Gleaning great detail! I shall begin my own forum in detail when sufficient info generated and I learn how to add pics. Thanks for the pics. guys
Tortured ply is clearly beautiful. Mozzie Aldebaran VI 1827
#261936 08/01/13 08:07 AM 08/01/13 08:07 AM |
Posts: 858 Victoria Australia | .... 1740/1762/1763/1771/1777 That probably is not all of them ..... I wonder how many of them have had the deck issues we've experienced ??? Kingy Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#261937 08/01/13 08:08 AM 08/01/13 08:08 AM |
Posts: 92 South Oz | All of them! And more issues as you have experienced. Maybe not 1777.
[Re: Phillip]
#261939 08/01/13 08:16 AM 08/01/13 08:16 AM |
Joined: Apr 2007 Posts: 432 McCrae Y.C. Mornington Peninsu... Simon C
Posts: 432 McCrae Y.C. Mornington Peninsu... | As a one time owner of 1762 I concur. I've come out in cold sweats on occasion watching your progress Pirate. Oh the memories, Oh the horror, Oh how I love my foam sandwich boat! Clearly you have considerably more skill and patience than me. I tried hard but confess I just gave up in the end. Thankfully Simon put the effort in to save her from the fate I had in store for her.
Simon Taipan AUS341
[Re: Simon C]
#261943 08/01/13 08:48 AM 08/01/13 08:48 AM |
Posts: 858 Victoria Australia | ... I've come out in cold sweats on occasion watching your progress Pirate ... I didn't have grey hair 2 months ago Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
#261968 08/02/13 07:13 AM 08/02/13 07:13 AM |
Posts: 858 Victoria Australia | thanks for that "image"..... & I'd just had tea.... I work in the steel industry so doing a wooden boat repair when the closest tool I have that's related to timber is a pro chainsaw is certainly a bit of a leap of faith.... having said that..... I've thoroughly enjoyed every minute, except for the staples bit  & yeah I'd do it all again  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: ]
#266353 10/18/13 06:52 AM 10/18/13 06:52 AM |
Posts: 858 Victoria Australia | always looking for new ideas ..... post em up  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
2,548
guests, and 457
