| Re: Spin halyard cleat redesign
[Re: wildtsail7]
#260702 06/26/13 02:50 PM 06/26/13 02:50 PM |
Posts: 932 Solomon's Island, MD | Todd I'll lend a hand, since the problems are annoying me as well.
One needs to look at the line tail geometry. At least on my setup, rigged per Tripp and Mike's guide, the halyard when uncleated upwind still has enough tension on it from the shock cord to keep it out of the spreaders. The downside is this also pulls the halyard out of the cleat to begin with.
So, how do you fix this? The tail has to get to the tramp somehow...that I am going to think on for a few days.
A random thought is leading the halyard to a clutch ala big boat.
Scorpion F18
[Re: samc99us]
#260705 06/26/13 03:36 PM 06/26/13 03:36 PM |
Posts: 49 Israel, Sdot Yam | One of the infusions at our club has added a normal cleat on the mast, below the halyard cleat, which feeds from top to bottom. After dousing they cleat in the bottom cleat, so any pull on the halyard just yanks it in place
Opher Nacra F20C ISR1 F18 Cirrus ISR2 Sdot Yam, ISRAEL
[Re: wildtsail7]
#260706 06/26/13 03:48 PM 06/26/13 03:48 PM |
Posts: 932 Solomon's Island, MD | The negative to the base cleat and my clutch idea is it's more difficult to blow the halyard from the port side. Right now I just grab the retrieval line, give it a yank, then grab the halyard tail that's on the deck, give it a hard yank which uncleats it and lets me keep dousing, always staying over the center of the tramp. Hence it's easy to douse on port or starboard.
Is anyone doing something radically different?
Scorpion F18
[Re: wildtsail7]
#260727 06/27/13 09:20 AM 06/27/13 09:20 AM |
Posts: 932 Solomon's Island, MD | Any photos Dave? Your description is a little tough to follow, are all the cleats attached to the head knocker swivel, i.e it has 2 cleats instead of one?
Scorpion F18
[Re: wildtsail7]
#260728 06/27/13 09:26 AM 06/27/13 09:26 AM |
Posts: 554 Boston, Ma | Honestly haven't had too many issues since we switched to a nice tapered halyard that is the correct length. It is not cleated upwind, but there isn't any extra slack in the system. After sailing your boat Todd you halyard seemed a bit long.... then again the epicness of that sail has clouded my memory.
If you guys come up with something I would be happy to draw it up in Solidworks.
USF18 Eastern Area Rep Nacra Infusion USA 753
[Re: samc99us]
#260748 06/27/13 10:51 PM 06/27/13 10:51 PM |
Posts: 602 Wilmington,NC | Any photos Dave? Your description is a little tough to follow, are all the cleats attached to the head knocker swivel, i.e it has 2 cleats instead of one? Mike might have some photos. Yes the 2 cleats are in line and attached to a plate that attaches to the swivel. Take off the existing cleat and make a plate long enough to mount 2 cleats in line and mount using existing cleat bolts and holes. The line just goes through both cleats and they work together. | | | Re: Spin halyard cleat redesign
[Re: mikekrantz]
#261206 07/11/13 10:38 AM 07/11/13 10:38 AM |
Posts: 172 Anacortes | Just like what we put on the Melges spin halyard. Double cleat = no slipping.
Anacortes Rigging.com Rigging and Yacht Services
[Re: stampede]
#262034 08/04/13 03:15 PM 08/04/13 03:15 PM |
Posts: 49 Israel, Sdot Yam | We solve the slippage problem the other way for the same result - add a 6mm cover over the 5mm halyard where it cleats. Stops the slipping and protects the halyard, when the 6mm cover wears out we replace it, the halyard itself is still in good shape.
[Re: wildtsail7]
#262059 08/05/13 08:31 AM 08/05/13 08:31 AM |
Posts: 932 Solomon's Island, MD | Opher,
That was my though as well after I had it slip Sunday. Replaced the cleat with a Harken 150DS=double springs which holds better but the issue is as stampede says, the 5mm FSE Robline Racing Sheet is compressing in the cleat and sliding. Doesn't help that this line is a bit slippery to begin with. Runs really nice though; for a change the spinnaker setup is running smoothly.
Upwind it's not an issue for me; using Tripp and Mike's bungee takeup system, if the halyard isn't cleated upwind it's no big deal, enough tension exists to keep it free of the spreaders.
Scorpion F18
[Re: mikekrantz]
#263444 09/09/13 05:38 PM 09/09/13 05:38 PM |
Posts: 1,403 | Never slipped again... Mike What two cleats are you using here? | | | Re: Spin halyard cleat redesign
[Re: mikekrantz]
#263770 09/13/13 07:16 PM 09/13/13 07:16 PM |
Posts: 1,403 | Harken 365 and 471.
If you look closely, I had to add a riser under the 471 to get the bases in alignment. Mike, Can you post a template of the two parts that you fabricated with the materials used. Thanks
4,589
guests, and 679
