| Re: So - how the hell do I fix this?
[Re: ThunderMuffin]
#262086 08/05/13 12:34 PM 08/05/13 12:34 PM | MN3
| MN3
Unregistered | Thought maybe you got the wife to grab you a colonascope from work or something The harbor freight special. Actually I'm not even sure it works anymore. | | | Re: So - how the hell do I fix this?
[Re: ]
#262087 08/05/13 12:44 PM 08/05/13 12:44 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin OP
Posts: 3,655 Portland, Maine | Thought maybe you got the wife to grab you a colonascope from work or something The harbor freight special. Actually I'm not even sure it works anymore. No but she did bring the ultrasound home one night to check to see where our puppy's undescended testicle was :P | | | Re: So - how the hell do I fix this?
[Re: ThunderMuffin]
#262088 08/05/13 12:50 PM 08/05/13 12:50 PM | MN3
| MN3
Unregistered | haha! (don't even wanna know what the results were) Thought maybe you got the wife to grab you a colonascope from work or something The harbor freight special. Actually I'm not even sure it works anymore. No but she did bring the ultrasound home one night to check to see where our puppy's undescended testicle was :P | | | Re: So - how the hell do I fix this?
[Re: bacho]
#262090 08/05/13 12:56 PM 08/05/13 12:56 PM |
Posts: 12,310 South Carolina | My 20 front beam has the same deal as the rear beam. Would appear to be an extruded part of the beam. Hmmmmm. I really thought that was an extra piece but you certainly could be right. Either way, if it looks like the rear beam reinforcement, it will be a lot easier to work around than the infusion-style pieces.
Jake Kohl | | | Re: So - how the hell do I fix this?
[Re: brucat]
#262096 08/05/13 01:41 PM 08/05/13 01:41 PM |
Posts: 2,490 On the Water | That is hands-down, the mother of all thread tangents. Wow... Right up there with this one.
Philip USA #1006 | | | Re: So - how the hell do I fix this?
[Re: P.M.]
#262101 08/05/13 03:36 PM 08/05/13 03:36 PM |
Posts: 5,590 Naples, FL | That's the "UN-friend" one, right?
[Re: Hullflyer1]
#262103 08/05/13 03:42 PM 08/05/13 03:42 PM |
Posts: 3,655 Portland, Maine | It is like the Prindle, the strip and 2 bolts are one piece, If you can remove the other nut and see if you can force the piece up into the beam, remove and replace. If I recall the bolts were welded to the strip. So I can't just replace a bolt? Its a strip that goes in there that I have to order from Nacra? | | | Re: So - how the hell do I fix this?
[Re: ThunderMuffin]
#262107 08/05/13 03:59 PM 08/05/13 03:59 PM |
Posts: 12,310 South Carolina | It is like the Prindle, the strip and 2 bolts are one piece, If you can remove the other nut and see if you can force the piece up into the beam, remove and replace. If I recall the bolts were welded to the strip. So I can't just replace a bolt? Its a strip that goes in there that I have to order from Nacra? I would bet that it's two loose stainless steel bolts that go through a 1/4" or 3/16" aluminum backing plate inside the beam. I would expect to see enough corrosion on that plate to justify replacing it but you might get lucky and be able to reuse it. You can get pre-anodized aluminum bar stock from McMaster. You will have the exposed cut end and the holes you drilled where the anodizing will not exist - but I would spray paint the exposed areas and use plenty of 42 or 5200 on reassembly. You should be able to get plenty of what you need for under $20. McMaster anodized aluminum McMaster never links easily. From that link, choose Multipurpose 6061 alloy. On the left menu from there, click "anodized". Pick the size you need from there.
[Re: ThunderMuffin]
#262110 08/05/13 04:18 PM 08/05/13 04:18 PM |
Posts: 2,490 On the Water | I built a new beam awhile back and ordered all the new parts needed. The part was called a "bolt plate" which was made up of SS bar with the SS bolts welded to it. Like Hullflyer said.
[Re: ThunderMuffin]
#262112 08/05/13 04:46 PM 08/05/13 04:46 PM |
Posts: 3,655 Portland, Maine | What a clusterfu.... So you have to take the beam bolts out, then get the box insert out of there (BFH works the best here) and here's what you get as your consolation prize: ![[Linked Image]](https://lh5.googleusercontent.com/-LdbxkzqfmGs/UgAact7hCbI/AAAAAAAAl4I/u0yFgidRjoU/w584-h779-no/IMG_20130805_173405.jpg) ![[Linked Image]](https://lh6.googleusercontent.com/-UaT2grfLbec/UgAb1ooAeTI/AAAAAAAAl4k/Rz6qhkiBJzI/w1039-h779-no/IMG_20130805_174011.jpg) The beam box insert seems to have taken the brunt of the galvanic corrosion. FWIW, those bolts aren't stainless as they really, REALLY liked my magnet lamp. | | | Re: So - how the hell do I fix this?
[Re: ThunderMuffin]
#262113 08/05/13 05:39 PM 08/05/13 05:39 PM |
Posts: 12,310 South Carolina | I can't imagine why those are magnetic. They should be 316SS. We know Nacra of old (or any manufacturer really) and they wouldn't have put in some exotic expensive hardware where a bigger bolt would do.
#262114 08/05/13 05:48 PM 08/05/13 05:48 PM |
Posts: 2,490 On the Water | I can't imagine why those are magnetic. Really? Maybe previous owners? Undecided (the boat) does indeed have a colorful history.
505
guests, and 21
