Page 2 of 4 1 2 3 4
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262083
08/05/13 11:33 AM
08/05/13 11:33 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
My 20 front beam has the same deal as the rear beam. Would appear to be an extruded part of the beam.
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262085
08/05/13 12:23 PM
08/05/13 12:23 PM
catman Offline
catman  Offline
Of course you realize you have to take the other side apart to check it......right?
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262086
08/05/13 12:34 PM
08/05/13 12:34 PM
M
MN3
MN3
M
Thought maybe you got the wife to grab you a colonascope from work or something smile
The harbor freight special. Actually I'm not even sure it works anymore.
Re: So - how the hell do I fix this? [Re: ] #262087
08/05/13 12:44 PM
08/05/13 12:44 PM
Portland, Maine
ThunderMuffin Offline OP
Portland, Maine
No but she did bring the ultrasound home one night to check to see where our puppy's undescended testicle was :P
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262088
08/05/13 12:50 PM
08/05/13 12:50 PM
M
MN3
MN3
M
haha! (don't even wanna know what the results were)
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262089
08/05/13 12:53 PM
08/05/13 12:53 PM
brucat Offline
brucat  Offline
That is hands-down, the mother of all thread tangents. Wow...
Re: So - how the hell do I fix this? [Re: bacho] #262090
08/05/13 12:56 PM
08/05/13 12:56 PM
Hmmmmm. I really thought that was an extra piece but you certainly could be right. Either way, if it looks like the rear beam reinforcement, it will be a lot easier to work around than the infusion-style pieces.
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262094
08/05/13 01:30 PM
08/05/13 01:30 PM
pgp Offline
pgp  Offline
Puppy? mmh.
Pete Pollard
Blade 702
Re: So - how the hell do I fix this? [Re: brucat] #262096
08/05/13 01:41 PM
08/05/13 01:41 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Right up there with this one.
Philip
USA #1006
Re: So - how the hell do I fix this? [Re: northsea junkie] #262100
08/05/13 03:27 PM
08/05/13 03:27 PM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
It is like the Prindle, the strip and 2 bolts are one piece, If you can remove the other nut and see if you can force the piece up into the beam, remove and replace. If I recall the bolts were welded to the strip.
Re: So - how the hell do I fix this? [Re: P.M.] #262101
08/05/13 03:36 PM
08/05/13 03:36 PM
Originally Posted by P.M.
[quote=brucat]
That's the "UN-friend" one, right?
Re: So - how the hell do I fix this? [Re: Hullflyer1] #262103
08/05/13 03:42 PM
08/05/13 03:42 PM
Portland, Maine
Portland, Maine
So I can't just replace a bolt? Its a strip that goes in there that I have to order from Nacra?
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262104
08/05/13 03:43 PM
08/05/13 03:43 PM
brucat Offline
brucat  Offline
No, that stuff is to be expected (and easily ignored if you're not directly involved). Some poor dog getting "special" attention is definitely new here.
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262107
08/05/13 03:59 PM
08/05/13 03:59 PM
I would bet that it's two loose stainless steel bolts that go through a 1/4" or 3/16" aluminum backing plate inside the beam. I would expect to see enough corrosion on that plate to justify replacing it but you might get lucky and be able to reuse it.
You can get pre-anodized aluminum bar stock from McMaster. You will have the exposed cut end and the holes you drilled where the anodizing will not exist - but I would spray paint the exposed areas and use plenty of 42 or 5200 on reassembly. You should be able to get plenty of what you need for under $20.
McMaster anodized aluminum
McMaster never links easily. From that link, choose Multipurpose 6061 alloy. On the left menu from there, click "anodized". Pick the size you need from there.
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262108
08/05/13 04:04 PM
08/05/13 04:04 PM
Portland, Maine
Portland, Maine
Thanks Jake. I'll take a look inside the damn thing and see whats up.
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262110
08/05/13 04:18 PM
08/05/13 04:18 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
I built a new beam awhile back and ordered all the new parts needed. The part was called a "bolt plate" which was made up of SS bar with the SS bolts welded to it. Like Hullflyer said.
Philip
USA #1006
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262112
08/05/13 04:46 PM
08/05/13 04:46 PM
Portland, Maine
Portland, Maine
What a clusterfu....
So you have to take the beam bolts out, then get the box insert out of there (BFH works the best here) and here's what you get as your consolation prize:
The beam box insert seems to have taken the brunt of the galvanic corrosion.
FWIW, those bolts aren't stainless as they really, REALLY liked my magnet lamp.
Re: So - how the hell do I fix this? [Re: ThunderMuffin] #262113
08/05/13 05:39 PM
08/05/13 05:39 PM
I can't imagine why those are magnetic. They should be 316SS. We know Nacra of old (or any manufacturer really) and they wouldn't have put in some exotic expensive hardware where a bigger bolt would do.
Re: So - how the hell do I fix this? [Re: Jake] #262114
08/05/13 05:48 PM
08/05/13 05:48 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Really? Maybe previous owners? Undecided (the boat) does indeed have a colorful history.
Philip
USA #1006
Re: So - how the hell do I fix this? [Re: Jake] #262115
08/05/13 06:02 PM
08/05/13 06:02 PM
catman Offline
catman  Offline
Page 2 of 4 1 2 3 4
0 registered members (), 601 guests, and 42 spiders.
