| Re: Front Beam
[Re: Rolf_Nilsen]
#263741 09/13/13 07:51 AM 09/13/13 07:51 AM |
Posts: 141 | You are right on the C class and AC72s. The F16s do have a minimum weight in the class rules so building a strikerless mainbeam might make sense if there is an available weight and money ration on the budget Rolf, You mean increase the striker and get rid of (reduce) the cumbersome beams. The big builders felt they could jump on the marketing potentail of the F16 class and convince everyone they had to have beams and things designed for 20 foot boats. Of course this is good for the builders because they do not have to design anything, but now a big part of the class sails around with a ton of extra weight. If strikerless was better, they guys investing money on speed in the true developmental classes, would obviously be working to go that rout | | | Re: Front Beam
[Re: Karl_Brogger]
#263742 09/13/13 09:11 AM 09/13/13 09:11 AM |
Posts: 932 Solomon's Island, MD | Good history lesson on the original beams...explains why our F18's are such pigs.
The top A-Cat in the world right now is arguably the DNA. It does not have a striker on the beam! When you go to a C-cat, AC45, AC72 etc. the loads are much higher than on the smaller boats, the structure is physically much larger and yes a triangle striker will be lighter.
I suspect there is enough weight budget in the F16 class rules that a carbon front beam can be made to work and this is more aerodynamic than the triangle beam, plus better from a wave slapping standpoint. This of course is more costly. That is why IMO the F16 class needs to tighten down the class rules and follow the F18 lead in some ways on this issue as you continue to build fleets-no one wants an all-carbon F16 class killer.
Scorpion F18
| | | Re: Front Beam
[Re: samc99us]
#263750 09/13/13 10:55 AM 09/13/13 10:55 AM |
Posts: 141 | Good history lesson on the original beams...explains why our F18's are such pigs.
I suspect there is enough weight budget in the F16 class rules that a carbon front beam can be made to work and this is more aerodynamic than the triangle beam, plus better from a wave slapping standpoint. This of course is more costly. That is why IMO the F16 class needs to tighten down the class rules and follow the F18 lead in some ways on this issue as you continue to build fleets-no one wants an all-carbon F16 class killer. The A class has significantly lower loads than a 2 up spin rigged F16. It is also narrower so making a strikerless beam is a more reasonable solution to their design tradeoffs. The DNA chose this path and have a fast design. Would the boat be even faster or stiffer mounted with a striker? There is a minimum weight for the class. They cannot go below this, so a lighter striker system does not buy any weight advantage as it does in the larger designs you mention. They chose a build process that used more carbon but fewer pieces and the sales pitch for lower windage etc. For this boat probably a wash both cost wise and performance wise. There is a min weight for the F16 class as well. There are also already minimum or very nearly minimum weight platforms out there made from standard laminates. There are also various degrees of carbon to full carbon boats out there. The class is continuing to grow and the existence of these boats has in no way brought about the death of the class. Allowing options is an attraction for many. This doom and gloom prophesizing is getting a bit worn out. The DNA did not kill the A class nor did the Flyer or the first of the 75 kg generation like the Jav. All those boats seem to have increased participation not killed it. The F18 class has been very successful and I wish them continued success as it is good for multihulls, but the class is not for everyone. Just a quick view of the infighting and continued arguments over materials and rules minutia is more than enough to drive me from considering an F18, nevermind having to pay that kind of money for an overweight out of date vessel. | | | Re: Front Beam
[Re: Karl_Brogger]
#263757 09/13/13 02:03 PM 09/13/13 02:03 PM |
Posts: 932 Solomon's Island, MD | I'm not predicting doom and gloom for the class. I know if I was buying a new boat and a full carbon F16 was a possibility I might very well take it. By the same token, you cannot argue that a minimum weight carbon masted, carbon hulled F16 isn't going to be faster than a vinylester boat; maybe not when both are brand new but give each a year of hard sailing and I know what I would pick. The main reason I'm not on a F16 right now is the F18 is a better distance race platform, there is much more competition globally, and I already whack my helm in the face with my elbows on the F18 tramp, I know I'd be sent swimming for shore on the F16.
I also agree some of the rules in the F18 class are a bit excessive. For example, I think epoxy should be a valid material, and the sails should have open materials; both of these add very little cost, if any, to the build of a boat and increase the longevity of hulls and sails. However, calling the boat out of date is a very huge stretch; all your F16 sail and hull shape developments have been a trickle down of the design efforts placed on the F18's.
Scorpion F18
| | | Re: Front Beam
[Re: samc99us]
#263765 09/13/13 04:11 PM 09/13/13 04:11 PM |
Posts: 141 | I'm not predicting doom and gloom for the class. I know if I was buying a new boat and a full carbon F16 was a possibility I might very well take it. By the same token, you cannot argue that a minimum weight carbon masted, carbon hulled F16 isn't going to be faster than a vinylester boat; maybe not when both are brand new but give each a year of hard sailing and I know what I would pick. The main reason I'm not on a F16 right now is the F18 is a better distance race platform, there is much more competition globally, and I already whack my helm in the face with my elbows on the F18 tramp, I know I'd be sent swimming for shore on the F16.
I also agree some of the rules in the F18 class are a bit excessive. For example, I think epoxy should be a valid material, and the sails should have open materials; both of these add very little cost, if any, to the build of a boat and increase the longevity of hulls and sails. However, calling the boat out of date is a very huge stretch; all your F16 sail and hull shape developments have been a trickle down of the design efforts placed on the F18's. Nice thing about F16, if you want a full on carbon version you can get it and still race. Nobody is going to bitch at you becuase you have a sticker on your sail that is made with a material that is not approved. Have you ever put a tape measure on a tramp of the various boats? There is only a 2" difference in platform width between the models and the hulls are fatter on the 18 so in actuality the hull centerlines fall in almsot exactly the same width and the trampoline itself is actually wider on the F16 than the 18. Inside on the beams is only 2" shorter. (as just measured on my Falcon - other models may vary) As for trickle down The only thing the F16 took from the 18 is the rigging layout for a spin rigged boat. With this the F18 class did a lot of work and came up with some pretty good useable solutions. Hull shapes, sail shapes etc all came from A class (except for spins, and there both the 18 and 16 classes were following the T) If you want to talk materials weight and performance, get Matt at Falcon to chime in. They regularly produce boats with a bunch of material choices. What other builderor even boat design has identical rigged and molded platforms where you can look head to head at full carbon versus, Kevlar, S-glass, fiberglass different resins, different cores, carbon masts, aluminum masts etc. There are some real world comparisons there, not internet hype. | | | Re: Front Beam
[Re: Karl_Brogger]
#263772 09/13/13 10:49 PM 09/13/13 10:49 PM |
Posts: 932 Solomon's Island, MD | Keep telling yourself otherwise, but a full carbon-epoxy boat will outlast the glass equivalent. Performance wise? It probably doesn't matter straight out of the box. As far as F16 vs. F18, everyone has their choice for a reason. I think the F16 is a great boat, but here in the real-world the F16 will pitch pole first, is slower through short chop, and has yet to show us better performance in light air, so I'll continue sailing our overweight F18. Where the F16 really shines is in the versatility (sort of, 2-up is faster), and getting it up the ramp at the end of the day. As to size, we feel cramped on the Blade. Will give a Falcon or Viper a go and see what we think, but the hulls are MUCH smaller than the Infusion hulls so again, we are more forgiving to drive and faster when the wave state builds. Plus we are a little heavy for the F16, at 310lbs dry. Finally, we have an America's championship regatta with teams flying in from Europe and South America to compete against, plus Catacup, plus a highly competitive NE fleet. We are learning a lot at a very rapid pace in the F18 and I just don't think it's possible in the F16 right now in North America.
All of this wasn't my point to begin with in this thread; my point was a striker less beam can be built, total platform weight can be kept to class rules minimums, and a stiffer platform can be achieved (UHM carbon is MUCH stiffer than aluminum). Would a carbon striker on a carbon beam be the stiffest solution at the least weight? Absolutely. But that wasn't the question. Strikerless can be done.
Scorpion F18
| | | Re: Front Beam
[Re: waynemarlow]
#264063 09/17/13 02:41 PM 09/17/13 02:41 PM |
Posts: 5,590 Naples, FL | One could say that the best most trained sailors will always win. uhhh, that's not going to sell a bunch of new boats now, is it?
| | | Re: Front Beam
[Re: Karl_Brogger]
#264230 09/19/13 08:40 AM 09/19/13 08:40 AM |
Posts: 932 Solomon's Island, MD | Wayne,
I think the issue is with the class itself. You don't have the ultra competitive sailors flipping boats every 2 years, and I think this is going to slow down in the F18's as well. We're on a 5 year old F18 and have placed in the top half of the fleet at most of the events we've attended. There hasn't been a major F18 launch since the Infusion/C2 either. An 07' Infusion was in the top 10 at F18 Worlds.
Anyway, the crux of the matter is new boat prices aren't getting cheaper and the folks' spare income levels aren't growing to match new boat inflation prices. Building larger fleets in any class is getting tougher; best start by getting your local bankers out on the boats, maybe they'll get hooked.
Scorpion F18
| | | Re: Front Beam
[Re: samc99us]
#264241 09/19/13 09:20 AM 09/19/13 09:20 AM |
Posts: 5,590 Naples, FL | You don't have the ultra competitive sailors flipping boats every 2 years Are these sailors still in the F18 fleet, or are they starting to move to some other platform/fleet?
| | | Re: Front Beam
[Re: Karl_Brogger]
#264263 09/19/13 11:04 AM 09/19/13 11:04 AM |
Posts: 932 Solomon's Island, MD | Umm, what fleet would you switch to? Some are running parallel campaigns in Nacra 17's, but none have sold their F18's to do so AFAIK.
The F16 is a great boat for its intended use, mixed teams, lighter sailors and those that like to single hand. When you start bumping up near the weight range of the F18, it's IMO a more competitive platform; more boats, more competitive sailors and more regattas.
Scorpion F18
2,490
guests, and 352
