| Front Beam #263250 09/05/13 07:32 PM 09/05/13 07:32 PM |
Joined: Feb 2005 Posts: 4,119 Northfield Mn Karl_Brogger OP
Posts: 4,119 Northfield Mn | Do we need a dolphin striker?
| | | Re: Front Beam
[Re: Karl_Brogger]
#263255 09/06/13 02:21 AM 09/06/13 02:21 AM | Scarecrow
| Scarecrow
Unregistered | On a Viper with Ali beams? Yes
Alternately there is only one way to find out for sure.... | | | Re: Front Beam
[Re: Karl_Brogger]
#263263 09/06/13 08:16 AM 09/06/13 08:16 AM |
Posts: 4,119 Northfield Mn | I didn't think so, or at least I didn't remember seeing anything about it. I knew materials weren't limited. A carbon front beam could be designed to not have a dolphin striker, whether or not there is a savings in weight I don't know. It could certainly be stiffer.
| | | Re: Front Beam
[Re: Karl_Brogger]
#263265 09/06/13 08:23 AM 09/06/13 08:23 AM |
Posts: 4,451 West coast of Norway | No dolphin striker to hit waves is faster. I dont know what happened to the rules in 2010 as the ISAFisation process was going on.. Look at this for the rudders in a PDF of the 2010 rules I found on the forum on the class website. E.4.4 CONSTRUCTION (a) The cross section of each rudder shall be symmetrical about its fore and aft centre line .
Now what does this mean?? Rudder winglets certainly is allowed in multiplie configuration and is used in the class but this effectively does not allow L-shaped winglets. No discussion, no ballot and comments.. | | | Re: Front Beam
[Re: Rolf_Nilsen]
#263274 09/06/13 10:00 AM 09/06/13 10:00 AM |
Posts: 141 | No dolphin striker to hit waves is faster. I dont know what happened to the rules in 2010 as the ISAFisation process was going on.. Look at this for the rudders in a PDF of the 2010 rules I found on the forum on the class website. E.4.4 CONSTRUCTION (a) The cross section of each rudder shall be symmetrical about its fore and aft centre line .
Now what does this mean?? Rudder winglets certainly is allowed in multiplie configuration and is used in the class but this effectively does not allow L-shaped winglets. No discussion, no ballot and comments.. T foil rudders are specifically mentioned as allowed. No varying shape is allowed on the dagger although they could be assym as long as they are straight and canted no more than 6 degrees. You could easily argue that a J or L foil on the rudder would be likewise allowed. What is not mentioned is moving flaps or likewise appendages. By the rules you could add them on the rudders now and vertical flaps to the daggers too if you wanted to. - That ought to bring forth a big rules debate as soon as somebody shows up to a worlds sporting moveable flaps. | | | Re: Front Beam
[Re: Karl_Brogger]
#263276 09/06/13 10:52 AM 09/06/13 10:52 AM |
Posts: 5,525 | Does anyone have a link to the current rules set?
Was there a class meeting at Racine?
Pete Pollard Blade 702
| | | Re: Front Beam
[Re: Karl_Brogger]
#263278 09/06/13 10:56 AM 09/06/13 10:56 AM |
Posts: 5,525 | I think the hulls as we have known them are going away and the boat will become a ladder frame to attach sponsons and foils.
I was unwilling pay the collectors price for the Bernard Smith book, but iirc he talks about fat foils which lead to limitless design possibilites.
| | | Re: Front Beam
[Re: mini]
#263282 09/06/13 12:21 PM 09/06/13 12:21 PM |
Posts: 932 Solomon's Island, MD | This might be a good thing for the class if it can be done well, and still be usable for single handing, and not add a lot of hassle to sailing off the beach. I for one would be pretty likely to switch to a full flying F16, as we're in the ball park weight range and have an existing local fleet. Trouble is the existing boats are not good in short chop on a distance course where waterline is king. Full flying changes all of that.
Scorpion F18
| | | Re: Front Beam
[Re: Karl_Brogger]
#263291 09/06/13 03:39 PM 09/06/13 03:39 PM |
Posts: 6,049 Sebring, Florida. | I would love to see some of the A Cat guys build an arched front beam with no dolphin striker. Are there any out there already?
It would have to be made of carbon of course, unless you're really good at custom bending alum. tubes.
I guess you could put on a huge oversized straight tube, either alum. or carbon, with a thick enough wall, it wouldn't need a striker for support, but it'd be heavier and more drag when you do hit the top of a wave with the beam.
Blade F16 #777
| | | Re: Front Beam
[Re: Karl_Brogger]
#263408 09/09/13 08:37 AM 09/09/13 08:37 AM |
Posts: 932 Solomon's Island, MD | Hydro's has a dolphin striker (here: http://4.bp.blogspot.com/-plJNEqIu7...k3vAWmg0/s1600/cclasshydrosADimages1.jpg) That doesn't mean the other boats do. The DNA does not have a dolphin striker, meaning you can probably do the same on a F16. That is the kicker with the F16 rules as currently written, as has long been discussed elsewhere. Phantom built a foiling F18, but in carbon of course. Reading between the lines the existing hull shapes are fine but longer and wider is much better, as is having a second pair of hands to work the dagger boards. Time will tell.
Scorpion F18
| | | Re: Front Beam
[Re: bacho]
#263616 09/11/13 02:46 PM 09/11/13 02:46 PM |
Posts: 141 | I've been told a striker and beam on an A wieghs less than a striker less beam. A triangle is a fantastic way to add strength. Efficiently reaching your goal. You do not think the AC and C class guys would place those very complicated strut systems on their rides if is was not more efficent.(better) | | |
1 registered members (FredL),
320
guests, and 20
