| Re: Hobie 16 Gudgeon Brain Tease
[Re: '81 Hobie 16 Lac Leman]
#263319 09/07/13 02:48 PM 09/07/13 02:48 PM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | Je.. Hobie16-man y're making quite a mess of your hull transom.
I personally hate silicone for these type of repairs!
Anyway, why don't you use bolts through the wooden plate with there heads inside the hull. Put the nuts on the outside, so on the gudgeons and saw the bolts level with the head of the nut. If necessary use a less thicker/flatter nut.
Leading and holding the bolts from the inside is a bit of fiddling but is possible.
And for g..ssake, remove all the silicone (at least for the wooden plate) and use epoxy.
Also Hobie has a one-piece rudder gudgeon for the 16 ( about 30 bugs) which will help you with the wear and tear already outside the transom.
ronald RAIDER-15 (homebuilt)
#263369 09/08/13 01:53 PM 09/08/13 01:53 PM |
Posts: 5,525 | The boats are impressive but I liked the AC45 fleet racing better.
Pete Pollard Blade 702
3,236
guests, and 277
