| Re: Formula 20 foiling class ?
[Re: pitchpoledave]
#265490 09/30/13 02:08 PM 09/30/13 02:08 PM |
Posts: 5,590 Naples, FL | looks like it has a belt (screecher) and suspenders (spinnaker)  Why do the boards flair outward at the top?
[Re: pitchpoledave]
#265552 10/01/13 07:14 PM 10/01/13 07:14 PM |
Posts: 96 | http://www.nacra.ca/f20cfoiling-3.jpg Wow --Looks like they added about 20 to 24 inches of horizontal area to the curved boards and the T foil rudder is visable in the pic. Wondering what locks the boards in the down position --amazingly strong boards -cases -etc able to carry all the loads . Don't believe this version would be adjustable --that is able to adjust the foil board angle like A C cats . | | | Re: Formula 20 foiling class ?
[Re: Carl]
#265606 10/03/13 01:43 PM 10/03/13 01:43 PM |
Posts: 932 Solomon's Island, MD | Trunks must be different than stock to handle the S board vs. C-board, so yes AoA etc. can be made an option.
As an upgrade kit this makes little sense with the Flying Phantom costing the same as a new Nacra F20c. Add a $5K+ foiling package to the F20c and its $5K more than a boat designed from the ground up to foil. Pegasus didn't have the Flying Phantom option when these were built, and I suspect picked up the F20c at a bargain basement price.
Scorpion F18
[Re: samc99us]
#265631 10/04/13 03:34 PM 10/04/13 03:34 PM |
Joined: Jun 2005 Posts: 133 The Netherlands Kennethsf
Posts: 133 The Netherlands | Trunks must be different than stock to handle the S board vs. C-board, so yes AoA etc. can be made an option.
As an upgrade kit this makes little sense with the Flying Phantom costing the same as a new Nacra F20c. Add a $5K+ foiling package to the F20c and its $5K more than a boat designed from the ground up to foil. Pegasus didn't have the Flying Phantom option when these were built, and I suspect picked up the F20c at a bargain basement price. it's more the other way around, the Flying Phantom is a widened F18 [full displacement boat] while the F20C was designed with the curved foils to create semi foiling sailing as standard feature, so optimized to dip back en forth in the water | | | Re: Formula 20 foiling class ?
[Re: Carl]
#265632 10/04/13 03:51 PM 10/04/13 03:51 PM |
Posts: 96 | Has anyone developed an easy method of controling the foiling height ---that is --stabalizing the foiling above water level.
The cup cats used for and aft adjusters --moths use trim tabs . The tendancy to "dip back en forth in the water" seems like the unwanted characteristic to correct or find a simple solution for .
Higher angles are needed to foil in light winds --once up foiling it seems a lesser angle relative to the hull is needed for optimum speed .
[Re: Kennethsf]
#265635 10/04/13 04:49 PM 10/04/13 04:49 PM |
As an upgrade kit this makes little sense with the Flying Phantom costing the same as a new Nacra F20c. Add a $5K+ foiling package to the F20c and its $5K more than a boat designed from the ground up to foil. Pegasus didn't have the Flying Phantom option when these were built, and I suspect picked up the F20c at a bargain basement price. it's more the other way around, the Flying Phantom is a widened F18 [full displacement boat] while the F20C was designed with the curved foils to create semi foiling sailing as standard feature, so optimized to dip back en forth in the water ETNZ did a lot of hull optimization; their initial hull shape, done without full-flying VPP analysis, was found perfectly optimized for full flying when they got the VPP working. This hull shape happens to mirror the Cirrus R pretty closely in rocker and volume. So, I would take the full flying Phantom over modifying a F20c. The F20c is designed to use the hull+foil to get into a semi-planning mode, so it is perhaps a little flatter further aft than ideal. Really the hull shape does not matter much, save enough bow volume to avoid a total wipeout and reducing drag when you're in displacement mode. Difference is the F20c doesn't come stock with board trunks that handle full flying.
Scorpion F18
[Re: Carl]
#266068 10/11/13 07:27 AM 10/11/13 07:27 AM |
Posts: 932 Solomon's Island, MD | Yes, hulls matter when getting up, but again those shapes have already mostly been optimized with the fat sterns and modern rocker profiles.
The flying phantom has 10' carbon beams, >32' carbon rig and full carbon hulls, built by the #1 F18 builder for quality in the world. It is equally as powerful as the F20C and the build quality is likely better (read: stiffer=faster on foils). Again, I'd take the flying phantom over a full-foiling F20C in anything above about 8 kts of breeze.
Yes, the F20C is a good retrofitting platform, but again a lot of work and $10K to add foils to a boat that is just as expensive as the flying phantom to begin with. It doesn't make economic sense unless you find a F20C for less than $20K.
Scorpion F18
[Re: Carl]
#269545 02/19/14 03:49 PM 02/19/14 03:49 PM |
Posts: 5,590 Naples, FL | I'm sure foils extending past the max beam is more efficient, but dang that's got to be tricky at a crowded starting line or turn buoy.
Sort of like a bunch of H-18 with wing racks all going at it... except you can't see the foils nearly as well...
[Re: Carl]
#270476 03/20/14 06:59 PM 03/20/14 06:59 PM |
Posts: 932 Solomon's Island, MD | Brainstorming...slightly canted straight boards (~6°) with L's at the bottom...no curves. "Simple", easy to build, 3 part mold. Insert from bottom. Remove L-foils for beach races, insert regular straight boards from top.
Or build a set of c-boards and t-foil rudders for 98% lift and potentially less drag when it goes light.
Scorpion F18
1 registered members (FredL),
2,799
guests, and 283
