| Broken and Seized Gudgeon Screws #265456 09/29/13 09:58 AM 09/29/13 09:58 AM |
Posts: 160 North Carolina | Hello all. I am hoping I can get some repair advice from others that have had this problem. My current situation is that I have two ss gudgeon screws that were broken off inside the transom on my starboard hull during a race in Myrtle Beach (a couple of years ago I am ashamed to say). I don’t think I ever hit anything, must have just been some sort of weird stress on the rudders. I also have to ss gudgeon screws with broken heads on my port side rudder. They are all the upper part of the gudgeon. I have gone through numerous drill bits and hours working to get these ss screws out with little success. I’ve learned to take my time and drill slow, but we are talking hours on one screw here. I have also messed up and gone through the aluminum backing plate in some of the hole locations accidentally. I’ve made some progress, but I need to start thinking about how I am going to make this a lasting repair so I can get back on the water. My boat is pieced together with 86 hulls. She was pretty fast and light last I remember. At this point I’m not really looking to get back into racing just yet, I just want to be able to have some fun with her and the wife on the water. I have the one piece gudgeons and plan on using them. So, my questions are: 1. Do I just continue to try and drill out the ss screws (I’ve been using cobalt bits), fill with resin and filler (btw I have no fiberglass experience), and then re-tap with a larger size screw? I really worry about doing this correctly. I think it would be hard to get them all back into the aluminum. Drilling these screws out has not gone well. I’ll get into the screw, but it isn’t perfectly center and the screw eventually sheers off making it even harder to drill out. 2. Do I do the above step and try to glass in helicoils? (seems expensive, compared to other options)
3. Do I cut inspection ports into the stern of each hull to thru-bolt the new gudgeons?
While more drastic, this seems like an ultimately easier and more sure-thing repair. It would also allow me to make sure the transom is sealed.
4. Some option that I do not know about???? I’m open to anything at this point. What would be the fastest, cheapest, and most effective way to do this repair? I’ve got to get back sailing. I will try and post pics of the transoms in a few. Thanks in advance.
James 1983 Hobie 16'
| | | Re: Broken and Seized Gudgeon Screws
[Re: abbman]
#265460 09/29/13 10:40 AM 09/29/13 10:40 AM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | We had some discussion about the same subject about a month ago on this forum. Also with a H16 as I remember.
I would choose definitly for option nr. 3
ronald RAIDER-15 (homebuilt)
[Re: abbman]
#265464 09/29/13 02:25 PM 09/29/13 02:25 PM |
Posts: 306 St. Louis, MO | +1 for option 3. Much easier to repair in the future and it is nice to have access to that area of the hulls through an inspection port
Nick
Current Boat Looking for one
[Re: abbman]
#265489 09/30/13 02:00 PM 09/30/13 02:00 PM |
Posts: 160 North Carolina | Thanks for the input everyone. I think I will install ports and thru-bolt the gudgeons. It seems like my best option. I don't know of anyone local that I could get to do the repairs and cost is a huge factor. I think I am up for the port installation. Carlbohannon, I think I know the bit you are talking about. I purchased one of those to drill around the ss screw. It was nice to be able to see the screw and know where the aluminum backing plate was. Do you think that bit will go all the way through the aluminum? This is what I have been using more or less, they are pretty expensive though at 15 bucks or so a pop http://www.toolbarn.com/hitachi-728020.html?gclid=COmks5jl87kCFfFj7Aod9X8AfgIf that will go through the aluminum, then I am just going to drill around the screws and bore a hole, fill with resin and filler, re-drill, thru-bolt, and seal it all up and GO SAILING! Do you worry about the helicoils failing because they are not set in the aluminum backing plate? My next question would be...what are the best ports to use. Should I order from Hobie or somewhere like Annapolis Performance Sailing?
[Re: abbman]
#265528 10/01/13 10:06 AM 10/01/13 10:06 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I would do #3. However I would cut out the existing backing plates and replace them. I haven't installed the one piece gudgeon on a boat yet. Does it use the existing holes or are they all in new locations? If it's all new locations then you can drill and tap. If you can't get the bolts out now you won't have any better luck from behind through a port. To cut them out a dremel tool works but I prefer using one of the sonic tools like the Rockwell sonicrafter. Works great and easy to control with less dust. You can buy 1/2" plate stock by the foot from McMaster Carr. I've also simply knocked them out by using a punch from the outside and just drive the plate out. Generally that plate is only covered buy a single layer of light cloth. To prevent this from happening again coat the screws with Tefgel.
[Re: Karl_Brogger]
#265531 10/01/13 12:53 PM 10/01/13 12:53 PM | MN3
| MN3
Unregistered | you can just buff that out! kidding aside - is that a goner or repairable? BAM! | | | Re: Broken and Seized Gudgeon Screws
[Re: ]
#265533 10/01/13 01:12 PM 10/01/13 01:12 PM |
Posts: 4,119 Northfield Mn | kidding aside - is that a goner or repairable? Repairable, but being that I haven't heard from the fibreglass guy for three weeks I'm thinking I should've just bought a new hull. It's either going to be a horrendous bill, or he just hasn't had time to work on it. I'm hoping its the latter. Unless you've got a pile of bits and pieces left almost anything is repairable. It's just making sure you don't cross that line of replacement vs. repair costs.
[Re: abbman]
#265534 10/01/13 01:19 PM 10/01/13 01:19 PM | MN3
| MN3
Unregistered | | | | Re: Broken and Seized Gudgeon Screws
[Re: Karl_Brogger]
#265535 10/01/13 01:22 PM 10/01/13 01:22 PM |
Posts: 12,310 South Carolina | kidding aside - is that a goner or repairable? Repairable, but being that I haven't heard from the fibreglass guy for three weeks I'm thinking I should've just bought a new hull. It's either going to be a horrendous bill, or he just hasn't had time to work on it. I'm hoping its the latter. Unless you've got a pile of bits and pieces left almost anything is repairable. It's just making sure you don't cross that line of replacement vs. repair costs. That's a pretty easy repair. It's in a nice flat section of hull with no non-skid to deal with. You can lay up flat patches and flat pieces parts to fill and repair. If it wasn't right in front of the front beam, I wouldn't hesitate to seal it with packing tape and keep sailing (it is probably a structural problem with where it appears to be, however).
Jake Kohl | | | Re: Broken and Seized Gudgeon Screws
[Re: abbman]
#265578 10/02/13 03:27 PM 10/02/13 03:27 PM |
Posts: 160 North Carolina | Rick, in hindsight that is exactly what I should of done. I had heard of left-handed bits, but no one around here carried them and I was too impatient to order them.
[Re: RickWhite]
#265585 10/02/13 06:56 PM 10/02/13 06:56 PM |
Posts: 921 Alachua, FL | Know what you mean. I don't know how many time I wished I had them.., finally found them at Northern Tool and got them. Have not needed them since.., haha Flag down a Snap-On or Mac Tool truck. They all have them and I'll bet they are better quality than at Northern. A little pricier...but they are worth gold when you need them.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | |
20,780
guests, and 1,475
