| Spinnaker sheet loads? #26603 12/01/03 08:06 PM 12/01/03 08:06 PM |
Joined: Jul 2001 Posts: 1,200 Vancouver, BC Tornado OP
Posts: 1,200 Vancouver, BC | Just had my first day with a spinnaker on my (new to me) Marstrom Tornado. Everything went great...what a ride! However, we noted that the spinny sheet (mafioli sp?) running thru a Harken Ratchamatic at 180 degrees still didn't take enough of the load off the line to keep the crew from complaining  . This was in 7-10 knots of wind, flat water and only for a short period of time. I do regular round the island trips that have 1-2 hours between gybes...and I'm sure hte crew will be squawking quite loudly by then. Is there a recommended solution to reduce the load (a 2:1 setup perhaps) or would a cleat be the way to go? Cheers! Mike Dobbs '95 Marstrom Tornado "Full Tilt" '81 SailCraft Tornado "DoubleMint"
| | | Re: Spinnaker sheet loads?
[Re: Tornado]
#26605 12/01/03 09:22 PM 12/01/03 09:22 PM |
Posts: 12,310 South Carolina | I never understood how the doubler worked until this thread...Chris, from Team Accelerated Chaos, posted this on the old forum - refer to the following link to Rick's Wave stuff for photos. 'perty neat! On my nacra 6.0, we run two sets of spin blocks, one on the rear beam and a second set further forward. I have one set of the harken ratchematics and a second set of manual on/off blocks that we turn off in light air. Remember that with ratchet blocks, the angle the line comes out of the block matters cause of the numberr of 'teeth' inside the block that have a grab on the line. In my particular set-up my crew can hold the line fully heated up with both ratchets on with two fingers with the NE class spin @ 350 sq ft. (pulling in the sail is a lot more work though). Another option to consider is using a 2:1 spin sheet often called a 'doubler'. In this case a set of blocks is tied in the sail @ the clew that the spin sheet is run though and a stop knot tied on the other side. When you need the extra power, the crew reaches up the the stop knot and pulls it back to a cam cleat on the rear beam. When its time to jibe, release the sheet from the cam cleat and you are back to a 1:1 sheet so you don't need ten thousand feet of line. hope this helps...
Chris http://www.catsailor.com/bestof_articles/Hooter.html
Jake Kohl | | | Re: Spinnaker sheet loads?
#26606 12/01/03 09:28 PM 12/01/03 09:28 PM |
Posts: 1,200 Vancouver, BC | Here is a picture of the current setup: So, from what you're saying...make the forward turning block into another Ratchematic (or Carbomatic)? Hmmmm. One other thing that's different...the position of the ratchamatic is quite forward, about 6 inches ahead of the shrouds. Does anyone know if this is special to Tornado or do other classes use this sheeting position? Wouldn't the leech on the sail be much tighter and the slot smaller than compared with rear-beam sheet setups? Mike.
[Re: Tornado]
#26607 12/01/03 10:18 PM 12/01/03 10:18 PM |
Posts: 12,310 South Carolina | You gotta remember that the NE6.0 Chute in question is a pretty big dude (340sq ft I think). I think the I20's sheet to the shroud as do most of the factory spinnaker boats. I have a ratchematic like yours on my rear beam and plan to install, like Chris, a ratchet block (that can manually be turned on and off) forward on my jib traveler track. My crew is confident that that should be plenty.
[Re: Tornado]
#26608 12/02/03 03:07 PM 12/02/03 03:07 PM |
Posts: 833 St. Louis, MO, | If you want two to one purchase you could just hang two bullet blocks from your chute clew. Then run your spinnaker sheets like normal and put them threw the blocks with a stopper knot so that there is a tail. You need to attach a camcleat close to your rear spinnaker block. Then after you jibe just reach up and grab the tail and put it threw the camcleat. I only recommend this for long distance races where you are going to be on one tack for a long time.
For triangles you can try two Harken Rachamatics. It seems to work well for me but others have different experences.
Mike Hill H20 #907
Mike Hill N20 #1005
[Re: Dlennard]
#26612 12/02/03 10:33 PM 12/02/03 10:33 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Wow, some people sure can get mixed up by trying to picture rigging when you type about it! What David L. said is right. On my Nacra 6.0, from the spin clew I use a ratchamatic off the shroud tang. Then the line goes forward, allowing a contant nearly 180 degree turn, then thru a block that was the bottom block of a prindle 16 mainsheet system. (sorry, no part number).  This block has the switch to turn on or off the ratchet, so in light air, it freewheels, and when needed, it has alot of drag being only unidirectional with the ratchet on. This really takes alot of the loads off the sheet, and still allows for good spin control. Face it, especially in a distance race, you pretty much leave the spin sheeted to it's sweet spot for the course and conditions, and control things with the tiller, and alittle main traveler-at least I do anyway. ON my 6.0, to get the spin sheet out of the spaghetti bowl of sheets with the 4-way jib system, I then route it thru a third block on each side, just a turning block, to get the spin sheet back behind the 4-way jib lines. With a smaller chute, (ideal for these boats-sorry Randy), the two block system is needed anyway to get the sheet around the daggerboards, then I use a third to get it back behind the jib sheets. After tailking to many I-20 sailors, and Tornado sailers, such as J. Tomko, and C. Ogletree, their advice was to have either two blocks that you could turn the ratchet on/off, or one and a ratchamatic. The doubler is another good idea, and I've used that set-up in the past, but with my current set-up, it's not needed. When I get around to it (ever say that?), I'll also put a cleat on the windward side for the spin sheet in distance races. To make a long story short, get a ratchet for the second block, with a switch to turn on or off when needed. It helps to snuff, when the ratchet freewheels, so there isn't much tension on the spin sheets while going in. My 50 cents. Todd Bouton Nacra 6.0na #111 with I-20 chute, and mid pole snuffer, square top main, ...
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#26614 12/03/03 09:08 AM 12/03/03 09:08 AM |
Posts: 12,310 South Carolina | Todd,
What size spinnaker are you using? I think all the New England guys sheet to the rear beam - my 320 sq ft sail likes to be sheated to the rear beam - however, the clew of the sail is pretty high (While I may loose a little performance, I can see to leward under the chute).
#26615 12/03/03 10:18 AM 12/03/03 10:18 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Well, I guess I'm kind of a renegade,  The spin rigged boats that I used as a template, mainly the I20, and Tornado, DON'T sheet back there on the butt end of the boat. I simply bought a I20 spin, new, for about 950. USD, and rigged that to my boat. IN races I've done with other 6.0's with larger chutes, during the long chute runs, I wasn't loosing anything, and often being faster. The 270 sq ft chute, In my opinion, is ideal for this boat. Gee, I wonder why the Tornado guys didn't go with a bigger chute with all that beam width? Why didn't the I20 come with a larger chute? I don't live in NE, and I'm glad you can see under your chute, that is oftentimes important, especially on the 6.ona, with it's low jib. Todd
[Re: Barry]
#26618 12/03/03 03:07 PM 12/03/03 03:07 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Jake, That was from RTI right? I've got a pic very similar, I'll try to scan and attach it. Todd
[Re: Tornado]
#26619 12/03/03 03:13 PM 12/03/03 03:13 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Mike,
If you read my post, actually the block you have last to the clew, looks like the one I use, are you sure that isn't a switch to turn on/off a ratchet?
Ir you put the ratchamatic as last before it goes to the clew, you get a better near 180 wrap, which helps. I think someone said that already though, if so, sorry.
[Re: Todd_Sails]
#26620 12/03/03 08:43 PM 12/03/03 08:43 PM |
Posts: 1,200 Vancouver, BC | Todd, the ratchet on the block closest to the clew is definately on...it is a load sensing type, much like the newer type Carbomatics have. Based on what has been discussed here, I think I will swap out the turning block with another ratchamatic (or a carbomatic) to help take more of the load on the sheet. Seems like the most straightforward setup with no drawback like more line lenght, snuffing issues, cleating dangers etc. As for the other question asked about the Maffoli (sp?) line, it's what came with boat, and seems to most popular on the Olympic circuit team boats. It's a nice, very light material and doesn't absorb water. Seems to grip the ratchet well compared to "harder" coated lines. Stuff is quite expensive...so I'm told. Mike. Mike,
| | | Re: Spin Size
[Re: Todd_Sails]
#26621 12/03/03 08:51 PM 12/03/03 08:51 PM |
Stan Schreyer, the guy I purchased the tornado from, has told me the Tornado actually performs better with the smaller spinnaker than the class rule actually permits. I also asked about the sheeting position, angle...he said the sail is cut to allow for the fairly steep angle that tends to keep the leech tighter. The sail is also quite flat relative to others I have seen on different classes.
So I guess, the sail is cut to sail at higher, faster angles without getting drag a bigger, fuller sail might cause.
Mike.
439
guests, and 53
