Dyneema rigging #267429
12/02/13 05:43 AM
12/02/13 05:43 AM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Hey Guys! I see people use Dyneema on the trap wires can this be used on rigging as long as its more than 3mm? Would love some advise before I build rigging this weekend
Cheers grin
Damien 1820 Raw Prawn (under construction)!!!
QLD
Re: Dyneema rigging [Re: Damo] #267431
12/02/13 07:02 AM
12/02/13 07:02 AM
Rye, Victoria
air_apparent Offline
Rye, Victoria
Hi Damien
the rules state:
13.8 All standing rigging shall be circular in section, minimum diameter 3 mm, and shall have no fairings. so in that regard it's probably Ok
however 3mm dyneena won't be 3mm after its loaded up as it tends to thin out as the fibres stretch out.
Gordon Hyde
Air Apparent
1520
Re: Dyneema rigging [Re: air_apparent] #267446
12/02/13 04:29 PM
12/02/13 04:29 PM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Thanks Gordon
Cheers wink
QLD
Re: Dyneema rigging [Re: Damo] #267455
12/02/13 07:30 PM
12/02/13 07:30 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=252631&page=1
close but the tech is not quite there yet. personally I would like nothing more than to have full synthetic rigging.
Re: Dyneema rigging [Re: Damo] #267699
12/12/13 06:23 PM
12/12/13 06:23 PM
Matt_Stone Offline
Matt_Stone  Offline
my brother wanted thism I said no, as wire last a lot longer, dyneema steach under huge loads, easy to knot and tangle, any sparp objects will cause a rig to fail. Spreaking from profession I would use wire, dyform (hammer)wire or normal 1x19, I have tried this meathod on a far 36 tri, couldn't get the right shape in mast. Use it if u like but I wouldn't recommend it.
Matt
Re: Dyneema rigging [Re: Damo] #267703
12/12/13 09:26 PM
12/12/13 09:26 PM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Thanks Matt, will stick with whats proven, cheers
QLD
Re: Dyneema rigging [Re: Damo] #267704
12/12/13 10:41 PM
12/12/13 10:41 PM
lesburn1 Offline
lesburn1  Offline
I have been using 3mm STS-12-90 Dyneema in my A-cat for two years without any problems.
lesburn1.blogspot.com
A-Cat USA 49
18Sq 49
0 registered members (), 375 guests, and 129 spiders.
