| Power Pole - N6.0?? #26744 12/08/03 11:06 PM 12/08/03 11:06 PM |
Joined: Oct 2003 Posts: 118 St. Louis, MO JoeLeonard OP
Posts: 118 St. Louis, MO | Anybody tried the power pole righting system on a Nacra 6.0? I'd like to know how well it has worked compared to a more traditional system...
Also....any issues with it being class legal for either N6.0 class or F20??
Thx in advance.
Joe
JL
N20 # 1041 "Lucille"
A-cat USA 44
| | | Re: Power Pole - N6.0??
[Re: JoeLeonard]
#26746 12/09/03 11:21 AM 12/09/03 11:21 AM |
Posts: 12,310 South Carolina | Joe, Will that motorcycle double wind speed or what?
Jake Kohl | | | Re: It was designed for a N6.0??
[Re: RickWhite]
#26749 12/10/03 01:18 PM 12/10/03 01:18 PM |
Posts: 1,200 Vancouver, BC | Rick, still no reports of it working on 10 ft beam boats like Tornado?
Mike.
[Re: RickWhite]
#26750 12/10/03 03:36 PM 12/10/03 03:36 PM |
Posts: 118 St. Louis, MO | Thanks Rick....good feedback!! Can you explain how / where it anchors/pivots? It is unclear to me if it mounts to the crossmember or to the bottom of the dolphin striker...(which would make it more of a concern in regard to water drag...  ) Also...do you know if there are any limit on using it with the N6.0 class racing? Thx again! Joe
JL
A-cat USA 44
| | | Re: Tornado Use
[Re: RickWhite]
#26753 12/11/03 09:59 AM 12/11/03 09:59 AM |
Posts: 12,310 South Carolina | Oooops! I stand corrected - not sure what I was thinking about! However, I was almost positive that the shroud lengthening devices were not...did they recently change this? From the Hobie class rules: 8.2 A minimum* 3/8 in. (9.53 mm) diameter righting line or webbing consisting of at least one 14 ft. (4.27 meter) length of line or webbing, or two 8 ft. (2.44 meter) lengths of line or webbing shall be securely attached and readily accessible from each side of the boat. The righting lines or webbing shall be in addition to all other required equipment. (Unless specified differently in individual boat class rules) * Righting water bags, shroud lengthening devices, righting pole type devices, and righting systems other than the minimum system specified may be carried and shall be used for righting purposes only.
Jake Kohl | | |
297
guests, and 42
