| Re: Winter Boat Projects
[Re: samc99us]
#269079 02/04/14 11:15 AM 02/04/14 11:15 AM |
Posts: 12,310 South Carolina | They were ice sailing at the club where we keep the boat. So no, no winter sailing for us, unless its in Florida where the boat is currently! That makes it difficult to fix the small list of issues, but most are fiberglass and require a bit of time to fix. We did damage yet another 5" porthole. Fortunately, Jeff and Brooks have the ultimate solution for the Infusion: http://www.beckson.com/twistdp.html In my experience, the main issue with the durability of the Viking Marine ports is that they are not bedded properly and have been bolted down to a slightly curved surface. This messes with the fine threads and makes them prone to cross threading... and then your crew starts banging on it until they break the thread ring out of it. This was the case with my infusion. Also make SURE you are reading the size of the port with the lettering embossed under the lid. a 5" port is the hole size...not the outer diameter of the entire assembly. Might save someone from ordering the wrong ones! (been there, done that)
Jake Kohl | | | Re: Winter Boat Projects
[Re: Ventucky Red]
#269082 02/04/14 12:08 PM 02/04/14 12:08 PM |
Posts: 932 Solomon's Island, MD | Nice photo.
Our viking hatches haven't been cross threaded, they simply failed at the lip from age. Bit done with that game! The Benson hatch is made of thicker material, is a drop in replacement for the stock hatch (from what I've been told), your crew can't cross thread it and I can leave the vaseline at home. Oh, and it is only a quarter turn to open, and I'm pretty convinced ~80% of the time water is only getting in there from rain, considering less than 20% of races are in big breeze or waves.
Scorpion F18
[Re: F-18 5150]
#269083 02/04/14 12:09 PM 02/04/14 12:09 PM |
Posts: 932 Solomon's Island, MD | Have seen these ports on a Wildcat and a New infusion. We are putting them on the Capricorn soon. How's the boat holding up? Manage to get it up to speed on the race course?
Scorpion F18
[Re: samc99us]
#269084 02/04/14 01:59 PM 02/04/14 01:59 PM |
Posts: 3,224 Roanoke Island ,N.C. | Nice photo.
I'm pretty convinced ~80% of the time water is only getting in there from rain, considering less than 20% of races are in big breeze or waves. Just convinced? You sail mostly in saltwater ,have you tasted the water in the hull? Fresh is rain, salt is leaky boat. Simple really, a gifted mind such as yours has a better way I'm sure, like a salinity tester. Don't forget to get samples from inshore and off at all regatta sites to narrow down your leaky regatta location.
[Re: Ventucky Red]
#269085 02/04/14 02:09 PM 02/04/14 02:09 PM |
Posts: 190 | Whadda have planned for your boat now that the days are getting a little longer and in some places a little warmer.
Me, will be tearing mine down these next few weeks, cleaning, and reassembling with hopefully not too many new parts...
YEA -- Me also ; but i'm making New X-Beams for my Hobie-21se, and opening up the over-all beam from 9.5' to 12ft. It means that instead of using a H-16 sized main & jib in those 30+ winds at Mohave, i'll be able to go with an 18 sized sail, with more stability !! The first ones will be made of ply & aluminium ; if i like it, then the ply & metal get replaced with all composite with Nomex core. The ply is cheaper to test the concept. This is WHY i kept asking how a Shark-class cat was made but i don't need the info any longer ; since the Shark community was so tight-lipped with there design-plans, i simply went with a completely different design instead. Bille | | | Re: Winter Boat Projects
[Re: Ventucky Red]
#269089 02/04/14 04:02 PM 02/04/14 04:02 PM |
Joined: Jun 2005 Posts: 302 Daytona Beach Florida orphan
Posts: 302 Daytona Beach Florida | Bille, You need to contact some of the old Orlando Hobie 21 sailors. Loyde and Louie made a couple of sets of 12' X-bars for H21. I suspect they are sitting around somewhere unused.
[Re: orphan]
#269090 02/04/14 04:11 PM 02/04/14 04:11 PM |
Posts: 5,590 Naples, FL | wow. there's a few names from way back...
[Re: samc99us]
#269091 02/04/14 04:38 PM 02/04/14 04:38 PM |
Posts: 1,430 california | Have seen these ports on a Wildcat and a New infusion. We are putting them on the Capricorn soon. How's the boat holding up? Manage to get it up to speed on the race course? Yea we fixed our rudder issues and now it's sailing great and running with the other boats here. I'm very pleased with the performance after the retune. | | | Re: Winter Boat Projects
[Re: orphan]
#269098 02/05/14 12:23 PM 02/05/14 12:23 PM |
Posts: 190 | ... The problem with a 12' wide 21 is that when you get powered up enough to fly a hull the nose wants to dive. ...
Should i be thinking about moving the Mast-base back a few inches, (or a foot) to counter that ? Or maybe racking the Mast Back a few degrees ? I'm Definitely going to open the beam , to 12' ; and unlike most other sailing lakes, Wind is usually 25+mph on a normal day here at Mohave. I've got a set of SC20 telescoping beams for sale, and I could give you the specs of the solid beams too.
Dave Yes -- specs please !! Bille | | | Re: Winter Boat Projects
[Re: Bille]
#269099 02/05/14 03:37 PM 02/05/14 03:37 PM |
Posts: 12,310 South Carolina | As the boat gets wider, more righting leverage is applied to the hulls - you see this effect dramatically on the bow. The wider it gets for a given length, the more pitchpole prone it will be. For a boat to perform well up and downwind (and be survivable to push it), a 2:1 length to beam ratio is a pretty good place to start.
[Re: Ventucky Red]
#269102 02/05/14 04:11 PM 02/05/14 04:11 PM |
Posts: 302 Daytona Beach Florida | Are you planning on trapping off the wings? If not then I could see the reason for 12' wide. Might be easier and less expensive to reduce sail area. And reduced sail may translate into more speed in high wind.
[Re: Team_Cat_Fever]
#269114 02/06/14 01:41 PM 02/06/14 01:41 PM |
Posts: 932 Solomon's Island, MD | Boat was bone dry after 2 days of sailing at Tradewinds, light air. Clearly water will come in through broken port holes. We use a refractometer for testing salinity and confirm water local with a spectrophotometer. $5K in portable instrumentation to do the same thing as a finger and a tongue
Scorpion F18
[Re: F-18 5150]
#269115 02/06/14 01:43 PM 02/06/14 01:43 PM |
Posts: 932 Solomon's Island, MD | Have seen these ports on a Wildcat and a New infusion. We are putting them on the Capricorn soon. How's the boat holding up? Manage to get it up to speed on the race course? Yea we fixed our rudder issues and now it's sailing great and running with the other boats here. I'm very pleased with the performance after the retune. Glad to hear it, we had rudder issues as well since the boat left the Chesapeake. Finally got them nailed with some expert help and it's a world of difference, we can keep up with the fast guys now.
Scorpion F18
[Re: orphan]
#269117 02/06/14 01:56 PM 02/06/14 01:56 PM |
Posts: 190 | Bille, You need to contact some of the old Orlando Hobie 21 sailors. Loyde and Louie made a couple of sets of 12' X-bars for H21. I suspect they are sitting around somewhere unused. Anyone here got a link or E-mail address for those guys ? Maybe they would part with those X-Beams ? I'm Not looking for more speed with this project, as much as the extra stability associated ; sitting on the hull of a 12' wide cat is actually less leverage form my body weight than if i were on the wings. Standing on wings with my prosthetic(s) , is near Impossible for me. The wings will stay, but only agile people will use them in ((Light)) winds ; and that doesn't include Me ! Bille | | | Re: Winter Boat Projects
[Re: samc99us]
#269119 02/06/14 02:08 PM 02/06/14 02:08 PM |
Posts: 3,224 Roanoke Island ,N.C. | Boat was bone dry after 2 days of sailing at Tradewinds, light air. Clearly water will come in through broken port holes. We use a refractometer for testing salinity and confirm water local with a spectrophotometer. $5K in portable instrumentation to do the same thing as a finger and a tongue I have a refractometer for testing the salinity in artifacts that I've got in electolysis. paid about $40 for it though.
2,751
guests, and 449
