Re: Double stack designs [Re: brucat] #269532
02/19/14 12:54 PM
02/19/14 12:54 PM
Originally Posted by brucat
So you have zero access to the box if there are boats on the rack?
I guess you'd get used to that, but something is almost inevitably forgotten at least once in a while.
Same here. I would have a bunch of those "damnit!" moments that way.
Re: Double stack designs [Re: Jake] #269534
02/19/14 01:00 PM
02/19/14 01:00 PM
I cut an "idiot door" on the back panel for just that reason
Re: Double stack designs [Re: brucat] #269542
02/19/14 03:04 PM
02/19/14 03:04 PM
If you have two boats it will not be possible to get into the box, the box will be completely filled with sails etc anyway.
With just one boat access is easy as the box can be pushed open when the boat sits on top of it
Re: Double stack designs [Re: Andy Humphries] #269573
02/20/14 12:31 PM
02/20/14 12:31 PM
brucat Offline
brucat  Offline
Like I said, you've probably gotten used to packing up the box before putting the boat on, and it's no problem. I can see myself forgetting to put a board or rudder crossbar in and not noticing until it's too late.
Re: Double stack designs [Re: brucat] #269576
02/20/14 01:10 PM
02/20/14 01:10 PM
Or, getting home and reviewing your boat to-do list and realizing spacers for the trapeze shackle and repair the chips on the foils are on the list. Or maybe you decided you want to try your 10:1 F18 mainsheet system on the trimaran you are getting ready to sail and all that stuff is trapped under two boats....Or...I need a ring ding and a shackle for my J22 and my sparts (spare parts...must be said with thick southern drawl) box is in there too! grin
Re: Double stack designs [Re: Andy Humphries] #269581
02/20/14 06:23 PM
02/20/14 06:23 PM
srm Offline
srm  Offline
The real question is what is the advantage of having the hull crossbars supported by the trailer box? I don't see any. The box needs to be stronger (read, heavier) to support a double stack of boats. The boats are higher up off the ground meaning more lifting to get them up on the trailer. And then there are all of the box access issues previously mentioned. The design doesn't make much sense to me.
sm
Re: Double stack designs [Re: Andy Humphries] #269582
02/20/14 06:43 PM
02/20/14 06:43 PM
The higher the boat is the less likely it is to get hit by anything the vehicle kicks up though.
Re: Double stack designs [Re: Karl_Brogger] #269585
02/20/14 07:44 PM
02/20/14 07:44 PM
srm Offline
srm  Offline
I suppose. I've personally been trailering cats for about two decades and never had any significant issues with stuff getting kicked up from the tow vehicle. If it's a concern, get a set of mud flaps, and if it's a major concern, get some hull covers. Both of those options still seem a lot more convenient than having to lift the boat up an extra foot to foot and a half each time and not being able to get into your trailer box. Heck, if you want the boat higher off the ground, weld up some extensions to raise the trailer crossbars up an extra foot. Incorporating the crossbars into the box just makes no sense to me - I don't see any real compelling reason to build a trailer that way.
sm
Re: Double stack designs [Re: Andy Humphries] #269587
02/20/14 08:01 PM
02/20/14 08:01 PM
I'm just trying to point out an upside. I'd do enclosed for everything if I could afford another $20k boat expense, but I'm pickier than most.
Re: Double stack designs [Re: Andy Humphries] #269588
02/20/14 08:13 PM
02/20/14 08:13 PM
pgp Offline
pgp  Offline
Probably not what you're looking for but I love this guy's work.
https://www.google.com/search?q=sta...mp;ved=0CFYQsAQ&biw=1280&bih=632
Pete Pollard
Blade 702
Re: Double stack designs [Re: Andy Humphries] #269593
02/20/14 09:18 PM
02/20/14 09:18 PM
F that. Cool, but F that.
I kicked around building a slip in camper for my pickup out of wood then glassing it. Way too much screwing around.
Re: Double stack designs [Re: Karl_Brogger] #269594
02/20/14 09:24 PM
02/20/14 09:24 PM
hehe...he made a pun.
1 registered members (FredL), 2,406 guests, and 222 spiders.
