| Spinnaker attachment to front hulls #269508 02/18/14 04:28 PM 02/18/14 04:28 PM |
Joined: Oct 2012 Posts: 104 gold coast fast energy OP
Posts: 104 gold coast | Hi all Just asking what is the best way to attach the end of the spinnaker pole to the front of the hulls with out leaking water At the front of the spinnaker pole is it best to have the tack line going through a nylon bush at the end or to have a roller inside the pole I ask these question due to my last spinnaker set up was very difficult on get in and out of the shoot Thanks for your options
Brett Kelly Fast Energy Gold Coast
| | | Re: Spinnaker attachment to front hulls
[Re: fast energy]
#269514 02/19/14 02:14 AM 02/19/14 02:14 AM | thricebitten
| thricebitten
Unregistered | Hi Brett,
I think the hole through the bows is the easiest way, I have glued in a tube on previous boat, but drilled the current ones oversize and filled and then drilled to the right size again. Make the hole big enough for loop of dyneema type rope then use tail to stop the loop pulling back through, makes rigging quicker, than setting length each time.
I have used both the pulley into the pole and the plastic end cap with hole in it for tack line, haven't noticed much difference in drag, most of it is kite in the chute. So I think either way is ok, but whatever you do, put a end cap on for safety.
[Re: fast energy]
#269517 02/19/14 06:09 AM 02/19/14 06:09 AM |
Posts: 104 gold coast | hi gary I think I saw at the wild cat your spinnaker pole nylon bush had a rope ware grove mark in it I think I like the nylon bush idear I may go for this method
thanks gary
[Re: fast energy]
#269557 02/20/14 01:44 AM 02/20/14 01:44 AM | thricebitten
| thricebitten
rope groove was only from using old fashioned polyester covered spectra rope, if you use dyneema type with no cover, no wear, on spinnaker either. | | | Re: Spinnaker attachment to front hulls
[Re: fast energy]
#269560 02/20/14 02:30 AM 02/20/14 02:30 AM |
Posts: 104 gold coast | thanks Gary where do you get dyneema rope from thanks mate
[Re: fast energy]
#269580 02/20/14 05:24 PM 02/20/14 05:24 PM |
Posts: 108 Port Hedland | Hello Brett, Dyneema and splicing needle should be available at any sailing shop. There is also plenty of videos on how to splice it on you tube. It is super easy and makes an excellent job. There is also a link to a video on the goodall website to splicing when you can only use one end. Even I picked it up in 2 minutes.
I rigged a spinnaker this year and made up a continuous dyneema bridle. I spliced an eye about 70mm from the end, and knotted the very end of the dyneema. You feed the eye through the hull and a flat washer (to spread out the load and stop it jamming), and then put the stopper knot through the eye to lock it in. Ensure between the bit of dyneema between the splice and the knotted end is long enough so there is no weight on it when rigged, otherwise it can cut into the hull, but not too long to flop around. This effectively gives you a direct pull from the washer on the outside of the hull towards the pole. I put a small roller in the end of my spin pole, held in place with a rivet on the back end and a SS bolt through the pole and roller on the front end.
I drilled into the sides of my pole to provide a straight lead for the dyneema bridles, and then tied a clove hitch knot around the SS bolt in the middle of my bridle. This knot enables you to adjust the bridle to get the same exact lengths, but after you put weight on it it locks in never to slide again.
The benefits of this rig are that the weight of the spin is taken over a broad area on the outside of the hulls, and there is no torque on the spin pole as the bridles are effectively attached to bottom of the sail. All the weight is taken by the dyneema which is more than strong enough, and the pole simply acts like a spacer to hold it out and up.
I am really happy with it and can send you some pictures if you like. Luke | | | Re: Spinnaker attachment to front hulls
[Re: Beckit 1824]
#269589 02/20/14 08:15 PM 02/20/14 08:15 PM | thricebitten
| thricebitten
Unregistered | Hey Luke,
so when is the first race against "Bite Me"? | | | Re: Spinnaker attachment to front hulls
[Re: fast energy]
#269592 02/20/14 09:13 PM 02/20/14 09:13 PM |
Posts: 104 gold coast | Hi Luke Thanks for the info Could you send some photos please As I am going to rig up this week Please send photos to Brett photo 0437818181 or [email protected]Thanks for your help Hoping to go to the nationals this year Would you know where they are?
[Re: fast energy]
#269613 02/22/14 04:58 AM 02/22/14 04:58 AM |
Posts: 104 gold coast | hi luke I don't seem to have any photos as yet I think I am trying to go with your idea I think that I will drill the front of the hulls with a 10mm drill then epoxy in a 10mm pvc pipe to run my spinnaker bridels through the problem is I cannt find any 10mm pvc pipe to do this procedures thanks luke
[Re: fast energy]
#269632 02/23/14 05:07 AM 02/23/14 05:07 AM |
Posts: 104 gold coast | Sorry Luke I cant seem to find these photos they maybe in the computer but my computer skills arnt that good to do too such indept searching or can I ring you tomorrow If you could text me your phone number I can ring you thanks
[Re: fast energy]
#269645 02/23/14 07:09 PM 02/23/14 07:09 PM |
Posts: 104 gold coast | That's good Luke I have received them I my phone Thanks
[Re: fast energy]
#269687 02/25/14 07:30 AM 02/25/14 07:30 AM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | I think that I will drill the front of the hulls with a 10mm drill then epoxy in a 10mm pvc pipe to run my spinnaker bridels through
Why so big? Only make them as big as they have to be to get the rope through. When Peter put the holes in the bows of Red Alert (a very light plywood boat) he stood the boat on it's nose and filled the tips up with epoxy filler so they would be a solid and waterproof attachment for the bridle.
Tim Shepperd Mosquito 1775 Karma Cat
[Re: fast energy]
#269714 02/26/14 05:36 AM 02/26/14 05:36 AM |
Posts: 104 gold coast | hi tim I through that you drill a hole about 10 mm and use a 10mm bush or conduit to seal the hole and glue it up so you can remove this rope I had this idear from the f 18 and vipers I don't thing that this is be the best way but at the moment this is all I have to go buy I just want to go sailing after selling my boat I don't think that where was so much work in getting finished to get on the water thanks for your reply tim greatly appreciated
672
guests, and 252
