| Re: Snuffing trouble
[Re: Mac McCallum]
#269887 03/05/14 08:02 PM 03/05/14 08:02 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Spray the chute with Silicone, or a more exspensinve lube. Especially sprey the chute where it contacts the chute, and spray the leading half of the chute as well.
That should help. Goes without saying- may sure you don't have any retrieval lines/block friction as well.
F-18 Infusion #626- SOLD it!
[Re: Mac McCallum]
#269889 03/05/14 08:12 PM 03/05/14 08:12 PM |
Joined: Oct 2013 Posts: 38 Lugoff, South Carolina Mac McCallum OP
Posts: 38 Lugoff, South Carolina | Rick, I haven't tried snuffing on the other side. I put it up for the first time this afternoon and that's the way the wind was blowing.
Seems the bunching is causing a lot of the problem. The sail is brand new, it was pointed out that this might cause some of the problem. That and it's a really big sail...
'09 Viper F16 USA102 A Cat USA 366
[Re: Mac McCallum]
#269912 03/06/14 04:06 AM 03/06/14 04:06 AM |
Posts: 586 Hobart, Tasmania, Oz. | Is it my imagination or does the lower patch look too far up the kite, almost to the middle? Does the kite hang out of the bag when it's snuffed?
[Re: Mac McCallum]
#269913 03/06/14 04:46 AM 03/06/14 04:46 AM |
Posts: 38 Lugoff, South Carolina | The sail is 350 sq ft/32.5 sq meters. Matt McDonald (Flacon Marine) had it made for a 20ft distance racer he was designing that never came to be. The shell is SNU's normal offering, his current design works with most any size pole.
Dazz, not sure if patch placement is at halfway, kinda looks like it in the picture though. The sail snuffs fully. Dennis told me how to measure the sail to get the sock length, it fits perfectly.
[Re: Mac McCallum]
#269921 03/06/14 07:38 AM 03/06/14 07:38 AM |
Posts: 38 Lugoff, South Carolina | I was hoping it might work better on the water, but figured that would be wishful thinking!
There is no pigtail and I don't know how to rig one. I feel like the wad is what's causing the trouble so maybe that would help?
I'm not used to using a separate tack so that could be some of the problem maybe? Launching I pull the tack all the way out, then raise the sail. When I snuffed I started pulling the sail in and then cut the tack loose when the sail started going in the snuffer.
[Re: Mac McCallum]
#269922 03/06/14 07:54 AM 03/06/14 07:54 AM | MN3
| MN3
Unregistered | new spins can be much more difficult than ones that have been broken in. all things above are correct (IMHO) - lube the snot out of the snuffer and sail - i have used http://www.holmenkol.com/ and thought it helped snuffing on the water is easier i also recommend silicon on areas it could get hung up on during a snuf (bridal area, bow tips, etc) | | | Re: Snuffing trouble
[Re: Mac McCallum]
#269926 03/06/14 08:08 AM 03/06/14 08:08 AM |
Posts: 382 SE MI / NE IN | In my experience, when you're on the water, the wind tends to string the chute out a bit and it doesn't wad up as much. When I have issues on shore its usually the wadding-up problem. I'ts also usually either calm or the breeze is on the nose of the boat which are not ideal either.
You might try turning the boat so the wind is coming across the beam. This is probably a closer approximation of your apparent wind when doing a take-down on the water.
[Re: Mac McCallum]
#269939 03/06/14 01:44 PM 03/06/14 01:44 PM |
Posts: 5,590 Naples, FL | There is no pigtail and I don't know how to rig one.
A figure eight knot in the snuffer line somewhere between the two patches might help keep the two patches from joining together into one giant glob going into the snuffer hoop... You'll have to probably adjust where that knot goes to make sure the sail fully snuffs, but if it keeps the two patches about 6 inches apart that should keep the glob of sail from forming...
[Re: waterbug_wpb]
#269940 03/06/14 01:46 PM 03/06/14 01:46 PM |
Posts: 12,310 South Carolina | There is no pigtail and I don't know how to rig one.
A figure eight knot in the snuffer line somewhere between the two patches might help keep the two patches from joining together into one giant glob going into the snuffer hoop... You'll have to probably adjust where that knot goes to make sure the sail fully snuffs, but if it keeps the two patches about 6 inches apart that should keep the glob of sail from forming... Until that knot jams on one of the snuffer points on the next hoist. Don't ask me how I know. Use a stopper ball. On the other hand...that really didn't help with the drag in my case either.
Jake Kohl | | | Re: Snuffing trouble
#269942 03/06/14 01:50 PM 03/06/14 01:50 PM |
Posts: 5,590 Naples, FL | that's cuz you use that teensy-weensy tapered line. The knot needs to be big enough to not get hung up in the grommet of the sail patch  You guys and your tapered everythig..... :), sheesh!
4,331
guests, and 637
