| Re: The sail area didn't hurt either.
[Re: ERoberts]
#27021 12/17/03 10:29 AM 12/17/03 10:29 AM |
Posts: 12,310 South Carolina | Bill,
Is that pole footed jib original equipment for the SC20TR? A friend of mine ordered a set of sails from Aquarius for his SC20TR and got a jib that looked like a hankerchief and was not pole footed. However, I haven't seen his boat in a while and I understand there were some issues with his sails that have since been resolved. The jib might have been part of those issues.
Jake Kohl | | | Allens boat
[Re: Marschassault]
#27023 12/17/03 11:47 AM 12/17/03 11:47 AM |
Posts: 1,253 Columbia South Carolina, USA | He did get his sails straight through some kind of intervention from Haberman and Roberts, and now uses the "pelican" striker to foot his jib to the spin pole. Very neat system, hope it works better than his old(brand new) sails we used at the Mug last year. The jib sucked in a big way! Dave Mosley www.seacats.org
[Re: Marschassault]
#27024 12/17/03 12:02 PM 12/17/03 12:02 PM |
Posts: 12,310 South Carolina | Marschassault,
And to your point, I thought the Tall Rig SC20 simply had the ARC22 mast and sails. My eyeballs are starting to swirl.
Jake Kohl | | | Re: The sail area didn't hurt either.
[Re: ERoberts]
#27028 12/17/03 01:05 PM 12/17/03 01:05 PM |
Joined: Dec 2003 Posts: 1,066 Wellington, FL-Singer Island, ... cyberspeed
Posts: 1,066 Wellington, FL-Singer Island, ... | Hi All, I own the second supercat in question, sail 2032. I have a short rig, oversized jib, square top main, screecher (hooter) and three harnesses. We had three people on our boat. I talked to Rick and he said he would take off the TR but I guess he forgot. It became a non issue when we did not finish. We set up at Gilberts but we were behind the warehouse. We were working on our boat the entire night before and morning trying to get it back together after we had some damage at the Hirams Haul. We have have been developing the boat to a new sail configuration and did not have enough time to reinforce the hulls before Hirams. Hope these answers a few questions. you can also go to our website. Craig TeamCyberspeed.com | | | Re: The sail area didn't hurt either.
[Re: BRoberts]
#27031 12/17/03 02:19 PM 12/17/03 02:19 PM |
Posts: 12,310 South Carolina | You're not helping my eye swirling problem  but I'm with you now. Thanks!
Jake Kohl | | | Sailarea becomes
[Re: BRoberts]
#27034 12/17/03 06:30 PM 12/17/03 06:30 PM |
Posts: 9,582 North-West Europe | SC20TR as sailed in Steeplechase
Main = 27 sq. mtr = 290 sq ft. Jib = about 5 sq.mtr. = 54 sq. mtr.
Only some 90 sq.mtr more than the I-20's on a mast being what ? 6 ft taller ?
What size spinnaker was used on the SC20TR ?
[Re: BRoberts]
#27035 12/18/03 09:44 AM 12/18/03 09:44 AM |
Joined: Aug 2002 Posts: 24 Annapolis, Maryland Marschassault
Posts: 24 Annapolis, Maryland | Bill, I guess that’s where I was going…. You get the extra ~12inches on the luff edge. And by lowering your tack corner from the normal position on the SC20 to the 22’s tack corner mount on the spin pole, you increase your luff edge. Doesn’t this increase your foot potential…. even if you’re running a forward-of-the-beam self tacking jib car?
One thing I noticed about your setup is that you run your spin pole in a low position (similar to the ARC22). Is there an optimum spin pole angle of entry for the SC20, or does it depend on what head sail your planning to fly off it? Did this low angle of entry, and having the lower jib tack corner, create any problems for you or is it a non-factor? This winter I’m going to attempt to engineer and mount a spin pole on my SC20TR and I was going to attempt to engineer mine very similar to the ARC22. Any feedback on optimum or desired mounting angles for the spin pole on a SC20TR would be greatly appreciated…!
You know, people can knock the boat (SC20’s), and compare them to or try to refute comparison to….. the new “high $$” boats on the market today….. But on that day, in that boat…. Eric and You were the champions! GREAT JOB! People that have never sailed on a SC20 will never understand how magnificent that boat is and what a pleasure that boat is to sail, thank you!
Bobby | | |
2,640
guests, and 390
