| Re: EPIRB, which one?
[Re: Timbo]
#270808 03/28/14 06:36 AM 03/28/14 06:36 AM |
Posts: 932 Solomon's Island, MD | Then you should know, Sam, everything is indeed about airplanes, then it trickles down to sailing.
We just saw an America's Cup being raced on flying boats with wing sails. How much more proof do you need? Hydrofoils and wing sails used by the AC use custom 2-D foil sections developed by T. Speers and others for this application. Only thing that's the same is the software (XFOIL and wind tunnels for section design, FLUENT and OpenFoam, most likely for 3-D analysis, in conjunction with VPP packages by North and others). Your analogy is like saying a Boeing 777 uses the same ABS brake system found in my Toyota Corolla.
Scorpion F18
[Re: Team_Cat_Fever]
#270809 03/28/14 06:37 AM 03/28/14 06:37 AM |
Posts: 932 Solomon's Island, MD | I want the EPIRB that when I hit the switch about 30 helicopters and two ships (with nekkid women and rum) show up in 10 minutes or less. Here's what happened when Davis flipped ours on during the 2002 Worrell 1000. Now I know why Brett pulled the eject handle in the 2010 Tybee!
Scorpion F18
[Re: samc99us]
#270811 03/28/14 07:14 AM 03/28/14 07:14 AM |
Posts: 12,310 South Carolina | Then you should know, Sam, everything is indeed about airplanes, then it trickles down to sailing.
We just saw an America's Cup being raced on flying boats with wing sails. How much more proof do you need? Hydrofoils and wing sails used by the AC use custom 2-D foil sections developed by T. Speers and others for this application. Only thing that's the same is the software (XFOIL and wind tunnels for section design, FLUENT and OpenFoam, most likely for 3-D analysis, in conjunction with VPP packages by North and others). Your analogy is like saying a Boeing 777 uses the same ABS brake system found in my Toyota Corolla. Dude, it was a joke.
Jake Kohl | | | Re: EPIRB, which one?
#270814 03/28/14 08:51 AM 03/28/14 08:51 AM |
Posts: 5,590 Naples, FL |
In that case, I'll take two
#270824 03/28/14 10:24 AM 03/28/14 10:24 AM |
Posts: 6,049 Sebring, Florida. | Then you should know, Sam, everything is indeed about airplanes, then it trickles down to sailing.
We just saw an America's Cup being raced on flying boats with wing sails. How much more proof do you need? Hydrofoils and wing sails used by the AC use custom 2-D foil sections developed by T. Speers and others for this application. Only thing that's the same is the software (XFOIL and wind tunnels for section design, FLUENT and OpenFoam, most likely for 3-D analysis, in conjunction with VPP packages by North and others). Your analogy is like saying a Boeing 777 uses the same ABS brake system found in my Toyota Corolla. Dude, it was a joke. Thanks Jake, I'm glad somebody gets it! And for you Sam, I mean, Psyco: http://www.youtube.com/watch?v=0OnpkDWbeJs I'm leaving Sebring for Dubai in a few minutes, and I'll be looking for shadowing Malaysions then testing my Toyota 12 wheel Anti Skid on the 777 when I get there, about noon east coast time tomorrow. You boys have fun this weekend, see ya on Monday. Why is the wind always blowing nicest when I have to go to work??
Blade F16 #777
#270842 03/28/14 02:32 PM 03/28/14 02:32 PM |
Posts: 4,119 Northfield Mn | I want the EPIRB that when I hit the switch about 30 helicopters and two ships (with nekkid women and rum) show up in 10 minutes or less. Here's what happened when Davis flipped ours on during the 2002 Worrell 1000. I see eighteen titties and two boobs.
[Re: Karl_Brogger]
#270847 03/28/14 03:04 PM 03/28/14 03:04 PM |
Posts: 12,310 South Carolina | I want the EPIRB that when I hit the switch about 30 helicopters and two ships (with nekkid women and rum) show up in 10 minutes or less. Here's what happened when Davis flipped ours on during the 2002 Worrell 1000. I see eighteen titties and two boobs.
#270855 03/28/14 06:01 PM 03/28/14 06:01 PM |
Posts: 3,224 Roanoke Island ,N.C. | I want the EPIRB that when I hit the switch about 30 helicopters and two ships (with nekkid women and rum) show up in 10 minutes or less. Here's what happened when Davis flipped ours on during the 2002 Worrell 1000. I see eighteen titties and two boobs. As opposed to the sausagefest you two boners would be having. p.s. The guy in your gif asked to sail with me , but he cried when I said Davis was my crew, so he brought us drinks instead.
[Re: David Ingram]
#271234 04/08/14 11:12 AM 04/08/14 11:12 AM |
Joined: Jun 2001 Posts: 3,906 Clermont, FL, USA David Ingram OP
Posts: 3,906 Clermont, FL, USA | EPIRB's are on the way, team manager veto'd the SPOT alternative. Thank you boys you've been very helpful.
[Re: David Ingram]
#271256 04/08/14 08:08 PM 04/08/14 08:08 PM |
Posts: 3,224 Roanoke Island ,N.C. | EPIRB's are on the way, team manager veto'd the SPOT alternative. Thank you boys you've been very helpful. If your life depends on it you'll be glad about that decision.
15,848
guests, and 372
