| Custom NACRA's #27116 12/16/03 08:17 PM 12/16/03 08:17 PM |
Posts: 4 | [color:"red"] [/color] I have a VERY good friend in the powder coating business. She is a formulator. There are also several places close to me that could powder coat my beams and mast or anything that is aluminum. Are these custom NACRA's and INTERS using powder coating? I am told it weighs next to nothing and is VERY durable. Anyone have any experince with this subject. I understand it's just for looks. My boat is already 50 lbs. over weight anyways ('83 NACRA 5.8) so what would it hurt?
Toby NACRA 5.8 w/spi "Adrenaline Rush"
Toby
NACRA 5.8 w/spi Adrenaline Rush
Jackson, Ga
| | | Re: Custom NACRA's
[Re: nacra_racer]
#27117 12/17/03 05:20 AM 12/17/03 05:20 AM |
Guy next to me on the beach uses this on his 160 sq. (literally an widened A-cat with more mainsailarea) and is very happy with it. It also makes the alu feel less cold (quite nice in the cold first months season). Anodising is lighter but apart from that is fine.
Anodising also protects the inside of the beams to corrosion (if it is a new tube), powder doesn't as it is only done to the outside. However 2 - 3 mm ( 1/12 - 1/8 inch) alu doesn't seem to degrade much over time.
| | | Re: Custom NACRA's
[Re: MauganN20]
#27119 12/17/03 10:22 AM 12/17/03 10:22 AM |
Posts: 12,310 South Carolina | Like anything, there are high quality and low quality ways to go about things. However, anodizing chemically converts the outer surface layer of the aluminum object into a very stable material - you can't scrape it off without removing material from the aluminum. Powder coating is a tougher than most painting but it's still an exterior coating that will be more suceptible to damage.
However, you could probably powder coat your beams three times by they time you paid for one round of anodizing for one set of beams (there is usually a heavy volume discount for anodizing since tanks of chemicals large enough to imerse the object are required).
Jake Kohl | | |
414
guests, and 45
