| Re: Rivets into Carbon Fiber
[Re: Keith]
#93804 01/02/07 11:42 AM 01/02/07 11:42 AM |
Posts: 1,382 Essex, UK | All of the mast fittings on the Stealth carbon mast are rivetted. I don't know of anyone with major problems as a result. On the other hand, being new to the class at the time, I took the precaution of through bolting the upper and lower diamond tangs <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> (it does no harm!)
If I were going to rivet into carbon, I'd drill the hole, paint it with epoxy to seal the ends of the cut fibres, and then pull up the rivet. Ideally I'd want to get a backing plate on as well.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Rivets into Carbon Fiber
[Re: Todd Berget]
#93806 01/02/07 12:24 PM 01/02/07 12:24 PM |
Posts: 829 Charleston, SC | I have riveted stuff onto my carbon N20 spin pole before. I have never had any problems in the last 2 or 3 years I've had the boat. I think you'll be fine.
Trey
[Re: NCSUtrey]
#93807 01/02/07 04:13 PM 01/02/07 04:13 PM |
Posts: 461 Victoria, Oztralia | Hi All
I've done some work in the fibreglass industry and there was a special rivet we used in water tanks and they were stainless, when the rivet pulls up, it splits off into four instead off balling up, it looks like a cross on the inside when your finished, and spreads the load of the rivet.
Regards
Matt Harper
Homebuilt Taipan 4.9
[Re: Todd Berget]
#93808 01/02/07 04:35 PM 01/02/07 04:35 PM |
Posts: 1,449 | Todd, If concermed you could always glue them to the pole. Layer of glss around the pole to insulate the stainless from carbon. Bed them into glue and then wrap a couple layers of glass around the stainless tags on the cheek blocks. If concerned about appearance you can colour the glue black with a picgment in the resin when mixing up the glue and we can now buy epoxy resin with a hardenner that does not discolour due to UV. So the glass can remain transparent.
So if concerned, with a bit of care and planning, you can probably make the attachment almost invisable.
Regards, Phill
[Re: phill]
#93809 01/03/07 02:19 PM 01/03/07 02:19 PM |
Posts: 1,200 Vancouver, BC | I prefer to thread self-tapping screws into carbon in place of rivets. They hold very well and don't squash the laminate.
Mike.
[Re: jollyrodgers]
#271324 04/11/14 12:48 PM 04/11/14 12:48 PM |
Posts: 12,310 South Carolina | Stainless does indeed react with Carbon. The following image shows the galvanic relationship of particular materials (graphite = carbon). Monel is one of the Cu-Ni alloys on that scale. To avoid galvanic corrosion between dissimilar materials, you want to choose materials that are close to each other on this chart. As you can see, Aluminum Alloys are almost as far away as they can get from graphite...the aluminum, being the more active of the two will act as the anode and will corrode at a high rate. 316 series stainless steel is what's usually used in marine application and most common stainless fasteners but even it is a bit far away from the graphite - it will rust if in contact (stainless is not impervious to everything...soak it in concentrated bleach for 24 hours and then water for a few hours and you will see!). 304/302 Stainless steels are the poor man's version of stainless (we typically build machine frames from 304 because it offers similar corrosion resistance at a reduced price from 316). What you really need are platinum rivets...they'll stand up well with that carbon. I used to be a cathodic protection system technician for a gas company....I would watch over the systems and methods used to slow down the corrosion of steel and cast iron gas pipelines... so I got a pretty good education on these things. What the guys are talking about with the fiberglass is for it to act as an electrical insulator. All of this galvanic corrosion takes place when the materials start swapping electrons - this leaves the less noble material unbalanced and oxygen atoms step in and start to make new materials from it (oxidation!). If you can keep these two items electrically isolated (for instance, with a patch of fiberglass cloth and resin) or charged with a small current (as we did in some pipeline systems), they won't swap electrons as readily and it helps the less noble material keep it's molecular crap together. When they're in the process of corroding you can actually measure a tiny electrical current. This also explains why salt water accelerates the problem - there are other things involved but the salt water will carry electrical current better than fresh water so when you get salt water mixed between these materials, it accelerates the corrosion because it increases the electrical conductivity allowing the different materials to swap more electrons.
Jake Kohl | | | Re: Rivets into Carbon Fiber
[Re: Todd Berget]
#271343 04/12/14 11:58 AM 04/12/14 11:58 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Jake,
you had me at "I used to be a cathodic protection system technician for a gas company..."
And this paraphrased section " salt water will carry electrical current better than fresh water"
Fresh water will carry a current, pure water will not, but you knew that.
You post above is very informative. I just kinda knew the basics, of what you have down to a science.
Nice post btw
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#271439 04/14/14 11:21 PM 04/14/14 11:21 PM |
Posts: 493 Minnesota | Pure water has a resistance of 18 meg-ohms.
21,518
guests, and 424
