Re: New to Mozzies [Re: swatter] #272629
05/22/14 04:22 AM
05/22/14 04:22 AM
East Gippsland, Australia
Tim_Mozzie Offline
Tim_Mozzie  Offline
This question is asked so often I've just added a page to the website on the topic.
Raising the mast
Now it just needs a few pictures.
Tim Shepperd
Mosquito 1775
Karma Cat
Re: New to Mozzies [Re: Hack] #272732
05/23/14 07:57 PM
05/23/14 07:57 PM
Grafton, NSW
Greg/Debra Offline
Greg/Debra  Offline
Grafton, NSW
Thanks for that Tim.
The hinge plates on our old boats (1140 and 1434) are fixed to the beam with the hinge at the back, which is why we have been putting up the mast from the back. I suppose it would be possible to take them off and turn them around so the hinge is at the front.
1140 Gadfly
1434 J.I.B.E.
1727 Atreus
Re: New to Mozzies [Re: Greg/Debra] #272745
05/24/14 06:04 PM
05/24/14 06:04 PM
thricebitten
thricebitten
Hi Greg,
Thats exactly what I did with my first Mossie 1111 whay back when, everything just turned around and fitted the same. Wish you could still get those pins and bases.
Re: New to Mozzies [Re: Hack] #272746
05/24/14 06:13 PM
05/24/14 06:13 PM
Scarecrow
Scarecrow
Gary, why can't you use the hinge Goodall sells?
Re: New to Mozzies [Re: Hack] #272749
05/24/14 06:50 PM
05/24/14 06:50 PM
Grafton, NSW
Greg/Debra Offline
Greg/Debra  Offline
Grafton, NSW
Matt or Kingy could probably make them.
1140 Gadfly
1434 J.I.B.E.
1727 Atreus
Re: New to Mozzies [Re: Greg/Debra] #272750
05/24/14 07:05 PM
05/24/14 07:05 PM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
If I could get hold of one to copy from it would be a simple task to duplicate them....
wink
Kingy
& now Mosquitos #1182 & #1740
Re: New to Mozzies [Re: Pirate] #272753
05/24/14 10:28 PM
05/24/14 10:28 PM
Scarecrow
Scarecrow
Re: New to Mozzies [Re: Hack] #272758
05/25/14 05:03 AM
05/25/14 05:03 AM
Grafton, NSW
Greg/Debra Offline
Greg/Debra  Offline
Grafton, NSW
Hi Kingy,
I thought you would have them on 1182 as most Mossies from that era had them. I can do a detailed sketch of the old ones, no problem there if people want to make replica ones.
I for one would like to fit them to 1727.
1140 Gadfly
1434 J.I.B.E.
1727 Atreus
Re: New to Mozzies [Re: ] #272759
05/25/14 06:57 AM
05/25/14 06:57 AM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
Originally Posted by Scarecrow
Simple enough .......
Thanks for that example
smile
Kingy
Re: New to Mozzies [Re: Greg/Debra] #272761
05/25/14 07:06 AM
05/25/14 07:06 AM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
That would be good if you can do that Greg, a few pics with a ruler or tape measure in the shot will make life far easier too....even a short vid of it actually opening / closing would help wink
Email them through to me when you can and we'll go from there
1182 never had one and there's no sign of one ever being fitted to her either so I'd want to make 2 for my two mozzies for starters and if there's an interest or demand we can make as many as required from there.
grin
Kingy
Re: New to Mozzies [Re: Hack] #272762
05/25/14 07:07 AM
05/25/14 07:07 AM
Matt_Stone Offline
Matt_Stone  Offline
that one looks too "HEAVY" I thing theres one on Garys old boat at somers and ill make some, from memory its 1.6mm square or plate bent up (similer to previous post)and just bolts on your existing pins
Ill look in to it
Matt
Re: New to Mozzies [Re: Matt_Stone] #272786
05/26/14 03:00 AM
05/26/14 03:00 AM
thricebitten
thricebitten
Hi all,
there is one thing some may be missing here. That is that retrofitting is not possible (to my knowledge) on mast bases unless the mast rotation pivot is bolted in.
The mast bases that came standard with these had a pivot that had a space before the cone of the pin that fits in the cup that captured the plate, keeping it attached to the mast base.
For instance on the mast base on 1766 the pivot is pressed into the cast alloy base and the cone that goes into the cup is flush underneath the alloy, no room to capture the plate.
But all is possible if you bolt through a new pivot or make a complete new base.
Re: New to Mozzies [Re: ] #272787
05/26/14 03:27 AM
05/26/14 03:27 AM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
Originally Posted by thricebitten
...... For instance on the mast base on 1766 the pivot is pressed into the cast alloy base and the cone that goes into the cup is flush underneath the alloy....
That's the tough one to get around, but like every thing if there's a will ........
Had a look at a spare base I have here and without destroying it I think it wouldn't take much to remove the cast in stainless part....... The alternative is to simply use the cast in stainless bit and bore through it and cut a thread for a new bolt.
Personally I'd like the cone on the beam and the cup on the mast, it would be simple to re-machine the cone into a cup and retro fit a new cone to the beam where the cup usually sits !!!!!!
Big advantage for me is no sand in the beam-cup and therefore no horrid grinding every tack smile
Problem solved
wink
Kingy
Re: New to Mozzies [Re: Hack] #272963
06/02/14 04:21 AM
06/02/14 04:21 AM
Grafton, NSW
Greg/Debra Offline
Greg/Debra  Offline
Grafton, NSW
I think it can be done without replacing the mast rotation pivot. It is a bit hard to explain without pictures but I am thinking of a piece of curved of 1.6mm stainless that can be riveted to the bottom front of the mast. Welded to that would be a hinge part which matches the other half of the hinge attached to the beam.
1140 Gadfly
1434 J.I.B.E.
1727 Atreus
Re: New to Mozzies [Re: Hack] #273264
06/17/14 11:22 PM
06/17/14 11:22 PM
benalla
swatter Offline
swatter  Offline
benalla
hi all thanx for advise on getting mast up i used my tralier put behind the th boat used the mast stand from trailer to hold mast to get the pin in it worked well now getting a stand made up so wont have to use trailer any more
Re: New to Mozzies [Re: Hack] #273272
06/18/14 05:59 AM
06/18/14 05:59 AM
Grafton, NSW
Greg/Debra Offline
Greg/Debra  Offline
Grafton, NSW
Hi swatter,
Glad to hear that you are making some progress with the mast raising. Using your trailer and mast stand is a good idea.
I have found it quite easy putting the mast up by myself from the back the way I described earlier.
I know that some people (Tim, Gary etc) say that it is easy to put the mast up from the front without a hinge, but that hasn't been our experience.
We have had difficulties putting up the mast from the front on our new boat 1727 which doesn't have a hinge. I am at the moment making a hinge for 1727 which will be on the front of the mast. I will post some pics when it is finished.
Greg.
1140 Gadfly
1434 J.I.B.E.
1727 Atreus
Re: New to Mozzies [Re: Hack] #273747
07/07/14 09:04 PM
07/07/14 09:04 PM
benalla
swatter Offline
swatter  Offline
benalla
hi thanx i got a stand made up its got 3mm 400 by 400 flat steel with 1400 square tubeing with angled plate to rest mast on at back of boat tryed it once seems to work well hope to have pics soon to show how it works
Re: New to Mozzies [Re: Greg/Debra] #274565
08/10/14 06:07 AM
08/10/14 06:07 AM
Grafton, NSW
Greg/Debra Offline
Greg/Debra  Offline
Grafton, NSW
I've finally done it... Below is a series of pics which hopefully are self explanatory
[img]http://s2.postimg.org/xnija8vm1/MH6.jpg[/img]
[img]http://s30.postimg.org/wwd7nck29/MH8.jpg[/img]
[img]http://s4.postimg.org/fjrj6zubx/MH9.jpg[/img]
1140 Gadfly
1434 J.I.B.E.
1727 Atreus
0 registered members (), 21,922 guests, and 1,500 spiders.
Most Online23,433
7 seconds ago
