| Re: Hobie 17 wing holes cracked.
[Re: Joe]
#39844 11/11/04 05:05 PM 11/11/04 05:05 PM |
Posts: 833 St. Louis, MO, | Joe, Shirley and Gerald just got done working on her H17 because it was taking on a lot of water. If you arn't taking on water I wouldn't worry about it. Make sure that you have something over the top of the holes to keep them from collecting water this winter and freezing which then will break the sockets.
Mike Hill Tiger #1520
Mike Hill N20 #1005
[Re: Joe]
#273987 07/17/14 12:28 PM 07/17/14 12:28 PM |
Posts: 2 | About to do repair on my wing tubes: I have a 1991 17 Sport.. All 4 tubes are cracked at the very bottom of the tubes.. I live in New Jersey, so I assume it was from frozen water in the tubes. I definitely have water flowing into the hulls. I have read a lot about the repairs and seen some pictures at http://imgur.com/a/EcHTi#uH37RW9 .. We are planning to cut in the 5" inspection ports this weekend and take a look.. From the pictures at http://imgur.com/a/EcHTi#uH37RW9 it appears that the fiberglass holding the tubing to the hull is going to be blocking my access to the very end of the tubes where the cracks are.. Has anyone done this repair and can you give me some hints on properly making these repairs??? I've also seen this post on repairing without cutting in the inspection ports.. http://home1.gte.net/res07lm8/hobie/archives/v5-i2/tip84.htmAny input would be greatly appreciated. Jeff Miller Hobie 17 Sport | | | Re: Hobie 17 wing holes cracked.
[Re: Joe]
#273996 07/17/14 06:00 PM 07/17/14 06:00 PM |
Joined: Apr 2002 Posts: 195 White Bear Lake, MN h17racer
Posts: 195 White Bear Lake, MN | Wow, this is an old post brought back to life!
Solution depends on what the problem(s) is/are. Leaks in the tubes only or leaks and structural?
Fill all 4 tubes with water and determine which are really leaking. If only leaks then the epoxy or maybe even silicone may do the trick.
My repair involved structural as the front tubes had separated from the base sockets so I did cut in ports and glassed the base. Worked like a dream and not that bad a job.
At one time Hobie made vinyl plugs for the tubes to keep water out. Good luck, TG
[Re: Joe]
#274047 07/20/14 08:41 PM 07/20/14 08:41 PM | Scarecrow
| Scarecrow
Unregistered | Don't put silicon anywhere near your sockets. If you ever have to do a proper repair the silicon will make it hard. If you're going to go with this style of repair use a urethane type product not a silicon product. | | |
238
guests, and 21
