| 1101........ Scorpian's rebuild #274445 08/07/14 09:15 AM 08/07/14 09:15 AM |
Joined: Apr 2013 Posts: 858 Victoria Australia Pirate OP
Posts: 858 Victoria Australia | 1 was fun..... 2 was challenging .... so whats this sitting outside the shed ??? ![[Linked Image]](http://i1376.photobucket.com/albums/ah3/Al_Noone/Scorpian/001_zpsc4b40df4.jpg)  Al ( the owner) and his dad have decided its time for a face lift on the old girl, part of that lift is where I come in, the decks. So, tramp off and the general fittings are also removed in preparation for the onslaught !!! The decks look 'ok' from a distance don't they.... you'd better strap your self in because your in for one hell of a ride this time !!! ![[Linked Image]](http://i1376.photobucket.com/albums/ah3/Al_Noone/Scorpian/004_zps11cf2c13.jpg) & part of the process will include the repair of the Easter Regatta's damage ....... ![[Linked Image]](http://i1376.photobucket.com/albums/ah3/Al_Noone/Scorpian/1101a_zps4dc8c605.jpg) let the carnage begin.......... again  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
Kingy started with Impara Cadet #3 / Mosquito #245 & now Mosquitos #1182 & #1740 | | | Re: 1101........ Scorpian's rebuild
[Re: Pirate]
#274471 08/08/14 04:32 AM 08/08/14 04:32 AM |
Posts: 76 Qld | Hi Kingy. Good to see another mossie getting the TLC treatment. I hope the job goes in a reasonably smooth manner for you.
I'm sure you'll keep us all informed on the progress' Dave. 1724.
David Madden 1724 Brisbane Valley Sailing Club Mossies are still alive in Qld.
[Re: Pirate]
#274476 08/08/14 06:13 AM 08/08/14 06:13 AM |
Posts: 76 Qld | Lets hope so. the more inspirational work the better.
[Re: Pirate]
#274478 08/08/14 06:17 AM 08/08/14 06:17 AM |
Posts: 858 Victoria Australia | doesn't take too long to find the potential problems ![[Linked Image]](http://i1376.photobucket.com/albums/ah3/Al_Noone/Scorpian/006_zpsb70e1c78.jpg) and of course the multiple shift that fitting game that leaves even more screw holes to filled with multiple products but its usually what's layin around in the bottom draw, I've encountered everything from silicone, resin, araldite, cotton buds, matches, flush-cut screws, chewing gum, candle wax, and just about everything in between  ![[Linked Image]](http://i1376.photobucket.com/albums/ah3/Al_Noone/Scorpian/007_zpsd81a9a68.jpg) Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274484 08/08/14 06:48 AM 08/08/14 06:48 AM |
Posts: 858 Victoria Australia | and so it begins...... I started off by peeling back the matting stuff and then ran the angle grinder over the remaining 'paint', this was to find the nail heads so they could be pulled prior to hitting the deck with the router.... but I found something rather odd underneath it .... The section from the front shroud mount forward has no nails  ![[Linked Image]](http://i1376.photobucket.com/albums/ah3/Al_Noone/Scorpian/016_zpsd06eb324.jpg) Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274488 08/08/14 07:09 AM 08/08/14 07:09 AM |
Posts: 76 Qld | Those stringers look messy at the moment . Do you think that they are sound or will you need to do some remedial work.
How do the bridal wire plates look.
[Re: Pirate]
#274489 08/08/14 07:10 AM 08/08/14 07:10 AM |
Posts: 858 Victoria Australia | deck on the port hull removed..... now we can see what's been going on and why we have such a mess on our hands The foams have collapsed at some stage and rather than removing the deck properly they've opted to run a jigsaw down the inside edge of the gunwhales, resin up the broken foam, add 2 strips of ply to the gunwhales to bulk them out and then resin back in the original deck ply. ![[Linked Image]](http://i1376.photobucket.com/albums/ah3/Al_Noone/Scorpian/024_zps32ca5e93.jpg) Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Dave M]
#274490 08/08/14 07:19 AM 08/08/14 07:19 AM |
Posts: 858 Victoria Australia | Those stringers look messy at the moment . Do you think that they are sound or will you need to do some remedial work. full replacement, not worth the effort of saving anything in there .... not even the foams How do the bridal wire plates look. the plates themselves are ok, the method of attatchment however  again it been one of those now what have I got in the bottom drawer that might work tricks !!! I was a bit taken aback to hear Phill say " are they mechano plates".... I thought he was joking.... WRONG  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274491 08/08/14 07:24 AM 08/08/14 07:24 AM |
Posts: 858 Victoria Australia | I like rear decks..... small area minimal work easy to do so again the flap dick uncovers the nails and then the nails get pulled before I wreck another router bit  ![[Linked Image]](http://i1376.photobucket.com/albums/ah3/Al_Noone/Scorpian/025_zpsf041e1b9.jpg) note: the dust generated from the high-speed 'sanding' from the flap disc is usually bad enough, but the matting stuff is chokingly bad, its incredible as to the vast volumes of dust its creating Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274492 08/08/14 07:31 AM 08/08/14 07:31 AM |
Posts: 858 Victoria Australia | uncovered  nice idea for an under deck support by placing the small triangle plates in there even if they are in a totally useless place.... why would you ever put them so close to a major part of the frame, would it not make more sense to locate them to support the middle area as best as possible ??? If these had of been midway between the beam support and the transom, I'd probably have been inclined to leave them there.... Oh well, next time maybe ![[Linked Image]](http://i1376.photobucket.com/albums/ah3/Al_Noone/Scorpian/026_zps57b16e48.jpg) Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274493 08/08/14 07:35 AM 08/08/14 07:35 AM |
Posts: 858 Victoria Australia | take a deep breath..... time to hit the starboard foredeck.... and yet again there's that oh-no feeling  ![[Linked Image]](http://i1376.photobucket.com/albums/ah3/Al_Noone/Scorpian/027_zpse4a2d695.jpg) [insert head bashing against the brick-wall emoticon here] ![[Linked Image]](http://i1376.photobucket.com/albums/ah3/Al_Noone/Scorpian/028_zps5313c755.jpg) Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
503
guests, and 336
