| Re: Safe A-cat landing
#276191 11/10/14 03:50 PM 11/10/14 03:50 PM |
Posts: 1,246 Orlando, FL | Cary a small mushroom anchor and a fender. Before launching, wade out and set the anchor with the fender tied to it some safe distance from shore. Wheel your a-cat into the water and wrap the fender around one of the forestays at the hull. Take your wheels up the beach while the boat just swings on the anchor. Do the reverse when coming in. I've done this quite a bit when launching the a-cat by myself. I do this except I modify my technique: * Wait to raise sail until on water * wheel boat out till water depth is waist high * drop anchor and secure other end to boat ** I like dolphin striker so boat tracks evenly ** I also use a milk jug to this end as a float * Raise Sail * Remove catrax and tie them to the end of the anchor line * Sail Away On return I repeat this process
USA 777
[Re: AzCat]
#276204 11/12/14 02:18 AM 11/12/14 02:18 AM |
Posts: 337 Arizona | Pirate, sorry about the question. Didn't mean to waste your time. Just so you know though, using carpet under a modern boat around here is a great way to get multiple holes in it. I can tell you this from experience, although not with one of my boats. What I was getting at is that you could get away with being a bit careless and/or make a mistake with older boats. It wouldn't destroy the boat, just scratch it up. Doesn't mean that I didn't take care of my boats. But as with all things cats sailing, there is a learning curve involved especially when there is no soft sand to land on. Regarding getting familiar with a few places on the lake, I've been sailing on lake pleasant for about 10 years now, and know all of the best spots. But NONE of the "good "spots are even remotely "good " or safe for an acat. Carpet will not spread out the point loading in the places I have to land the boat. And believe me, I look for the 10 lineal feet of gravel that I am lucky to find to put my foam pool floaties down on. But there are always those boulders just under the surface of the water that are hungry for the taste of a little gel coat. You say that some of the places you put in are "ugly" . Maybe that's because people keep leaving carpet on the beach. I can't even imagine doing that. ANYWHERE! In fact, when I leave the lake, I go around and pick up all of the trash that others leave . There's more than enough.
Everyone else, thank you for your responses. Sounds like the anchor and fender method is what I will use. As long as I can get the anchor far enough off shore . For shoreline, lots of pool floatys. I'm sure the wife will need a new one from costco next spring. She won't notice it's gone till then.
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: Safe A-cat landing
[Re: AzCat]
#276205 11/12/14 02:48 AM 11/12/14 02:48 AM |
Posts: 337 Arizona | Tide is a whole other dilemma. I will be sailing in Rocky Point Mex also. The tide goes out almost 1/4 mile . The tidal area is sand with large areas of coral. I'm pretty sure that I won't be able to coordinate my vacations with the phases of the moon/ optimal wind patterns. Although I think that full and new moons may coordinate well, I think. No sailing when the tide is out. Or at least no coming ashore when the tide is out and the coral is exposed. And there is no one to hold the boat. I guess that if the tide is out, I can tie the wheels to the anchor/fender with a 10/15' rope attached, and let the tide come in and float them. Maybe I can make a thick padded anchor bag for once the anchor is on board. What can happen will happen, that's what I know. Best to minimize the possibilities.
[Re: sasha]
#276206 11/12/14 02:53 AM 11/12/14 02:53 AM |
Posts: 337 Arizona | Your problem is insoluble. No problem is insoluble, except maybe string theory.
220
guests, and 29
