Re: Spreader challenge [Re: Arjan13] #276586
12/05/14 05:14 PM
12/05/14 05:14 PM
Originally Posted by Arjan13
Indeed both aluminum, and very fragile. Especially trying to get it moving is dangerous as you are tempted to use the "teeth"on the other side. However we got them loose again, but do not ask me which treatment finally helped. We used everything available from heat to soaking it in oil and other fluids.
Most of time it's not just one thing, but a combination. Glad you got it apart okay. I'd heed the advice to run a tap and die over everything to clean out and clean up the threads. And make sure to coat them in anti seize or grease when you re-assemble everything
Makes me think I should take my spreaders apart and clean them just for good measure.
The list of **** I need to do to my boat in the spring is horrifying.
Re: Spreader challenge [Re: Karl_Brogger] #276590
12/05/14 10:15 PM
12/05/14 10:15 PM
I don't think that any of the spreaders, other than nacras, use the aluminum on aluminum adjustment method.
Re: Spreader challenge [Re: Arjan13] #276591
12/06/14 01:34 PM
12/06/14 01:34 PM
maui
jollyrodgers Offline
maui
We had spreaders like that on the Prindle 18 in the 80's rental fleet. The alu. was anodized so theoretically corrosion shouldn't be a problem unless the anodizing got scratched. Although there is a ss fitting there. Maybe it was mostly hardened salt in the threads.
Re: Spreader challenge [Re: Jake] #276595
12/07/14 10:04 AM
12/07/14 10:04 AM
catman Offline
catman  Offline
Mystere, older Tornado's, Prindle used it.
Re: Spreader challenge [Re: catman] #276602
12/08/14 06:52 AM
12/08/14 06:52 AM
I meant "currently" and one could argue that Prindle/Nacra as the same company... But good point.
Re: Spreader challenge [Re: Arjan13] #276617
12/08/14 05:48 PM
12/08/14 05:48 PM
maui
maui
Are Prindles on the list of cats currently being built?
Please forgive my ignorance. i don't get out much.
Re: Spreader challenge [Re: jollyrodgers] #276618
12/08/14 06:17 PM
12/08/14 06:17 PM
no prindles are built today.
0 registered members (), 543 guests, and 74 spiders.
Posts267,056
