I20 mast re enforcement #276536
12/04/14 09:54 AM
12/04/14 09:54 AM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
I want to cover a couple repair patches on my I20 mast(CF). I added a CF/epoxy patch about 2 1/2 diameter to each side of the mast at the rotator attachment. Can I use gel coat? It seems to have gel coat over a primer or transition material from the factory.
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: I20 mast re enforcement [Re: AzCat] #276537
12/04/14 10:07 AM
12/04/14 10:07 AM
It has an Imron or some other two part paint system on it. I would use paint instead of gelcoat.
Re: I20 mast re enforcement [Re: Jake] #276539
12/04/14 10:52 AM
12/04/14 10:52 AM
catman Offline
catman  Offline
Depending on the epoxy, Gel coat (polyester) may not harden or it could react badly.
If matching the paint is an issue, use something close and find a couple stickers to cover the repaired area.
Re: I20 mast re enforcement [Re: catman] #276548
12/04/14 01:25 PM
12/04/14 01:25 PM
I believe Southern Spars told me it was Awlgrip "Matterhorn White"
Re: I20 mast re enforcement [Re: AzCat] #276556
12/04/14 03:12 PM
12/04/14 03:12 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
I do have some Imron white. I guess I'll try that. Can that go directly on the repair/ current primer/ current paint?
Re: I20 mast re enforcement [Re: AzCat] #276560
12/04/14 04:09 PM
12/04/14 04:09 PM
Yes...scuff it first with 320 grit.
Re: I20 mast re enforcement [Re: AzCat] #276624
12/09/14 11:23 AM
12/09/14 11:23 AM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
Matterhorn White is a shelf item at your local West marine usually, its a pretty common color and/or base
0 registered members (), 639 guests, and 38 spiders.
