| I20 mast re enforcement #276536 12/04/14 09:54 AM 12/04/14 09:54 AM |
Posts: 337 Arizona | I want to cover a couple repair patches on my I20 mast(CF). I added a CF/epoxy patch about 2 1/2 diameter to each side of the mast at the rotator attachment. Can I use gel coat? It seems to have gel coat over a primer or transition material from the factory.
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: I20 mast re enforcement
[Re: AzCat]
#276537 12/04/14 10:07 AM 12/04/14 10:07 AM |
Posts: 12,310 South Carolina | It has an Imron or some other two part paint system on it. I would use paint instead of gelcoat.
Jake Kohl | | | Re: I20 mast re enforcement
#276539 12/04/14 10:52 AM 12/04/14 10:52 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Depending on the epoxy, Gel coat (polyester) may not harden or it could react badly.
If matching the paint is an issue, use something close and find a couple stickers to cover the repaired area.
[Re: catman]
#276548 12/04/14 01:25 PM 12/04/14 01:25 PM |
Posts: 5,590 Naples, FL | I believe Southern Spars told me it was Awlgrip "Matterhorn White"
[Re: AzCat]
#276556 12/04/14 03:12 PM 12/04/14 03:12 PM |
Posts: 337 Arizona | I do have some Imron white. I guess I'll try that. Can that go directly on the repair/ current primer/ current paint?
[Re: AzCat]
#276560 12/04/14 04:09 PM 12/04/14 04:09 PM |
Posts: 12,310 South Carolina | Yes...scuff it first with 320 grit.
[Re: AzCat]
#276624 12/09/14 11:23 AM 12/09/14 11:23 AM |
Posts: 1,253 Columbia South Carolina, USA | Matterhorn White is a shelf item at your local West marine usually, its a pretty common color and/or base
282
guests, and 50
