Tornado mast vs F20 mast (compatible?) #237190
09/06/11 06:38 AM
09/06/11 06:38 AM
Sweden, Gothenburg
patrik Offline OP
patrik  Offline OP
Sweden, Gothenburg
Hello,
Would a Tornado mainsail fly without major recutting on a F20 tube (of the correct length) or would differences in stiffness make this a horrible idea?
Kind regards
Patrik Elfving
Re: Tornado mast vs F20 mast (compatible?) [Re: patrik] #238456
09/30/11 08:42 AM
09/30/11 08:42 AM
I believe that the mast bend characteristics of the N20 carbon mast would not be compatible with a Tornado main suited for an aluminum mast
Re: Tornado mast vs F20 mast (compatible?) [Re: patrik] #252906
10/01/12 01:55 PM
10/01/12 01:55 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
It would not be flying as it should. Luff curves are specific to the flex characteristics of the spar...even within the T class sails cut for the old soft rig masts would never be used on the prebend alu masts and alu-prebend cut mains were never used on carbon prebend masts.
Plus the I20 main is a different(larger?) size then the T. If you just want to putt around the harbor...go for it but it will not perform as most would want.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Tornado mast vs F20 mast (compatible?) [Re: patrik] #277480
02/05/15 11:36 PM
02/05/15 11:36 PM
M
mislaura7 Offline
mislaura7  Offline
M
Now that 3 races have passed, or 2 (heard sea bouy was rained out) 70-640 what modifications if any have been done to Nacra 20s for this class?
0 registered members (), 347 guests, and 951 spiders.
