| Re: Dimensions of trailer cross bars…
[Re: carlbohannon]
#27759 01/14/04 10:31 AM 01/14/04 10:31 AM |
Posts: 12,310 South Carolina | Carl, what did it cost to galvanize the tilt trailer in question?
Jake Kohl | | | Re: Tilt Trailers
[Re: carlbohannon]
#27763 01/15/04 09:00 PM 01/15/04 09:00 PM |
Posts: 1,200 Vancouver, BC | Carl,
There are a group of Southern CA Tornado owners working out plans to get 3 or 4 Tornado tilt trailers built in the next month or two. We have a few concepts that look promising. One involves an all aluminum trailer for good corrosion resistance and a "crane" post that will hoist the boat up via the main beam/hull intersection point, up into an upsidedown beam cradle fixed the the top of the crane post. The high side will then hang from this cradle only...no other support posts will be needed since the main beam is so close to the balance point of the whole boat. The lower hull will be strapped into pivoting hull cradles and thus provide all the other hold down stability needed. This has advantage of keeping weight aloft to an absolute minimum. If more weight is wanted down low for stability, a good sized storage box could be added etc.
Can you provide us any details on your trailer? Pics? Drawings? Doug Graf's contact?
Mike.
| | | Re: Tilt Trailers
[Re: Keith]
#27765 01/16/04 06:41 PM 01/16/04 06:41 PM |
Posts: 1,200 Vancouver, BC | I'm familar with the Scace design...unfortunately we all want a trailer we can also use to launch the boat off of directly. The upside down tilt type does'nt meet this requirement.
| | | Re: Tilt Trailers
[Re: Tornado]
#27767 01/21/04 10:37 AM 01/21/04 10:37 AM |
Posts: 778 Houston | Mike
It would hard to make a picture of the trailer right now, everything is covered for the winter. I will see what I have in the library. Design wise the trailer is standard. A reinforced "A" frame with a tongue. The tilt platform is an H with telescoping arms (so you can trailer the boat flat) with steel cradles for the hulls.The real difference is in construction. It was built like a commercial trailer. For a cat trailer it is a monster. It uses 2x6 for the lower frame, 2 1/4x2 1/4 & 2x2 for the upper and what looks like 3 in drill casing for an axel. Empty and bare it probably weighs around 1000 lbs
Your design uses the boat as the tilt platform. Steel trailers, hinges, etc damp road vibration and raise the resonance frequency. You are going to have to worry about resonance frequencies. If I don't tie my upper hull tight, it vibrates in the 0-10 hertz range.
I do not recommend launching a Tornado off a tilt trailer. It is hard enough keeping the corrosion off the expensive bits without dunking them in saltwater.
The US Tornado Assoc used to have plans for a good tilt trailer. Contact the US Sec to check.
The plans were detailed. They told you how long to cut what and how to weld, etc. Basically you could go to a self service steel yard and cut the parts. Then take them to a welding shop. Finally to galvanizer and then put it together.
When I first started, I wanted something like you are talking about. I was looking at a welded Aluminum or an aluminum upper with a steel lower. When I talked to trailer building professionals they talked about cracking problems with welded aluminum, transmission of vibration, galvanic corrosion at the hinge, and how the aero loads are dominant for the upper section. When I talked to an owner, he talked about sway, vibration and loosening hulls.
After living with the trailer for a while, I have decided that Isolating your boat from loads, stability in cross winds, ease of operation, reliability, and protecting that expensive hydraulic system is more important.
If I were going to build a trailer, I would look at the upside down system. A friend built one years ago. He claimed he might not be the fastest Tornado on the water but, he would be the fastest back on the trailer and he was. | | | Re: Tilt Trailers
[Re: MauganN20]
#27769 01/21/04 02:04 PM 01/21/04 02:04 PM |
Posts: 1,200 Vancouver, BC | Guys,
It's exactly the very slight flexing of an "H" type tilt bed that can damage the beams. When you support the hulls in snug fitting cradles where the cradles are connected by metal beams...any bending along the lateral tiltbed beams will tend to cause the cradles to pry the hulls apart in a direction that the hull/beam structure is not designed to handle. Even very slight bending can do damage and over many trips, this can(has) lead to boat failures.
Our hanging-from-the-mainbeam concept eliminates this risk entirely, since flex of the trailer cannot be applied between the two hulls. THe mainbeam is quite close to the balance point, so any windage or road bump loading on the ~80 lbs lifted hull should be easily handled by the structure. A structure designed to slam into waves and come to a rapid stop from 20+ kts speed (easily hundreds of lbs loading) is not going to be affected significantly by 60 mph winds from straight ahead while driving on the freeway. Many of these mainbeam support designs were built in the 70's for Tornados with no reports of problems.
Mike.
| | | Re: Tilt Trailers
[Re: MauganN20]
#27771 01/22/04 11:22 AM 01/22/04 11:22 AM |
Posts: 623 Gulf Coast | how about a rack that attaches not to the hulls, but rather the beams themselves... much like the scace design. David Tilley, who has contributed to this thread, has designed a quite interesting tilting trailer. I have the second of the prototypes, and on the whole am VERY pleased. This trailer has easily several thousand miles on it with only two failures, and those due to the base (OLD conventional cat trailer - the leaf springs failed, and not catastrophically). That would be easily rectified by either fabricating a strong Aframe or using a powerboat trailer Aframe to start with. Go have a look at Tilley's trailer: http://tinyurl.com/nlvasea ya tami | | |
1 registered members (FredL),
343
guests, and 59
