Nacra 5.5Uni - F17 or F18 square top work? #278037
03/19/15 05:26 PM
03/19/15 05:26 PM
White Bear Lake, MN
h17racer Offline OP
h17racer  Offline OP
White Bear Lake, MN
I am curious to learn if anyone has tried an F17 or F18 square top sail on a 5.5 Uni?
Mast length is more similar with an F17 and I am aware the "F" sails require a boom.
Thanks, Tom G
Re: Nacra 5.5Uni - F17 or F18 square top work? [Re: h17racer] #278038
03/19/15 06:34 PM
03/19/15 06:34 PM
M
MN3
MN3
M
i own 2 f18 sails that i have used on my mystere 5.5 (30' mast)
a gen 1 and a gen 2 capricorn sail
they worked well, were very powerful upwind but lacked size for downwind sans spin
(the sail is designed to be used w a spin downwind)
i like them both very much but don't use them anymore unless my main is in the shop getting repaired
Re: Nacra 5.5Uni - F17 or F18 square top work? [Re: h17racer] #278039
03/19/15 08:41 PM
03/19/15 08:41 PM
Are you saying the 'stock' Mystery 5.5 sail has more sail area than the F18, square top sail? I would think any square top would project more sail area than the equivalent pin top? I know my F16 square top main has a LOT more sail area up high were you want it, than my Prindle 18 pin top. In fact, I run the Prindle pin head in big wind, just because it has so much LESS sail area up high.
Re: Nacra 5.5Uni - F17 or F18 square top work? [Re: h17racer] #278046
03/20/15 07:51 AM
03/20/15 07:51 AM
M
MN3
MN3
M
nope, the f18 has more sail area
but i dont sail stock sails
i use cut down tornado sails or other custom sails i have had made.
Re: Nacra 5.5Uni - F17 or F18 square top work? [Re: h17racer] #278074
03/23/15 09:11 AM
03/23/15 09:11 AM
M
MN3
MN3
M
and the stock mystere sails has lots of roach and was designed for upwind and downwind sailing
the f-18 has no roach and is designed for upwind sailing and spin assist downwind
Re: Nacra 5.5Uni - F17 or F18 square top work? [Re: ] #278075
03/23/15 09:14 AM
03/23/15 09:14 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Perhaps I'm ill-informed, but I thought the amount of roach was defined by drawing a line from the end of the boom to the top of the mast and looking at the ratio of sail area that is beyond that line. If that's the case, I'd say the square-tops are very "roachy"
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Nacra 5.5Uni - F17 or F18 square top work? [Re: rehmbo] #278077
03/23/15 09:53 AM
03/23/15 09:53 AM
M
MN3
MN3
M
let me re-phrase that
the mystere sail has a lot more roach than an f18 sail
PS i am not sure but i would think that roach is measured from the clew and head of the sail, not the boom / mast, but could be wrong
Re: Nacra 5.5Uni - F17 or F18 square top work? [Re: ] #278078
03/23/15 10:00 AM
03/23/15 10:00 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
PS i am not sure but i would think that roach is measured from the foot and head of the sail, not the boom / mast, but could be wrong
Yup - I think you're probably right. I had made an assumption in my mind that the sail is attached at the end of the boom and top of mast, but you know what they say about assumptions smile
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Nacra 5.5Uni - F17 or F18 square top work? [Re: h17racer] #278079
03/23/15 12:06 PM
03/23/15 12:06 PM
maui
jollyrodgers Offline
maui
i was under the impression that all the area aft of a line between a point on the head,usually where you attach the halyard, and the clew is considered roach. So a square top has most of it's roach at the top and a H16 sail or Shark sail has the roach distributed lower down the leech.
Re: Nacra 5.5Uni - F17 or F18 square top work? [Re: h17racer] #278381
04/14/15 07:48 AM
04/14/15 07:48 AM
Netherlands
DennisMe Offline
DennisMe  Offline
Netherlands
I modded an existing square top to fit my Nacra 5.2.
But I selected it so that the boom length was almost perfect to start with so I could simply remove a horizontal section and go sailing asap.
Worked well. Check the Texel rating sheets (floating out on the internet somewhere) for measurements, they will give you some idea of what kind of sails may be suitable.
Take note that the sails are either cut for floppy masts or masts with diamonds. Be sure to get a sail cut for a mast with diamonds.
0 registered members (), 4,636 guests, and 1,000 spiders.
