Clear sail for Aquacat 12.5? #280016
07/21/15 08:44 PM
07/21/15 08:44 PM
WildBilly66 Offline OP
I would like to be able to "see" thru (the bottom) of my sail. All I see out there is Dacron sails.
1) Are there any clear or partially clear sails for this non-battened sail?
2) If not, is there any problem with cutting out an area and stitching in a old clear windsurf sail(mylar?)?
Thanks in advance .............. Bill
Re: Clear sail for Aquacat 12.5? [Re: WildBilly66] #280018
07/22/15 06:32 AM
07/22/15 06:32 AM
Bill, any sail loft can cut you in a window in the bottom of that sail or you could definitely do it yourself. It probably wouldn't be too expensive to have a sail loft do it and there are a lot of lofts around the country. If you do it yourself, the stitching job might be slightly above the capacity of a home duty sewing machine, though. The right material for the job is either this 4mil X-ply
http://www.sailrite.com/Monofilm-4mil-X-Ply-54
or this 5 mil monofilm
http://www.sailrite.com/Monofilm-5mil-54
Re: Clear sail for Aquacat 12.5? [Re: WildBilly66] #280034
07/23/15 09:03 AM
07/23/15 09:03 AM
Thanks Jake!
Any thoughts if this clear type of material will be too "brittle" for a non=battened sail? That is will it tear while flopping around in the wind say on a turn?
Re: Clear sail for Aquacat 12.5? [Re: WildBilly66] #280036
07/23/15 12:17 PM
07/23/15 12:17 PM
Thanks Jake!
I wouldn't make a whole sail out of it if that is what you mean. It would be too brittle for that. For a window in an existing sail, however, it would be fine. My monohull sailboat has windows in the jib and main made from the same material like this:
Re: Clear sail for Aquacat 12.5? [Re: WildBilly66] #280037
07/23/15 02:20 PM
07/23/15 02:20 PM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
The 4mil X-ply monofilm is what we use for the window in the Isotope Jib (which is not battened). We stopped using it in panels at the luff of the sail, where furling was really hard on the material, but it holds up as well as the 2mil Pentex on the back half of the sail. I think it would be more than adequate for an Aquacat sail.
I hope that helps,
Eric
0 registered members (), 451 guests, and 44 spiders.
