| Re: Clear sail for Aquacat 12.5?
[Re: WildBilly66]
#280018 07/22/15 06:32 AM 07/22/15 06:32 AM |
Posts: 12,310 South Carolina | I would like to be able to "see" thru (the bottom) of my sail. All I see out there is Dacron sails.
1) Are there any clear or partially clear sails for this non-battened sail?
2) If not, is there any problem with cutting out an area and stitching in a old clear windsurf sail(mylar?)?
Thanks in advance .............. Bill Bill, any sail loft can cut you in a window in the bottom of that sail or you could definitely do it yourself. It probably wouldn't be too expensive to have a sail loft do it and there are a lot of lofts around the country. If you do it yourself, the stitching job might be slightly above the capacity of a home duty sewing machine, though. The right material for the job is either this 4mil X-ply http://www.sailrite.com/Monofilm-4mil-X-Ply-54or this 5 mil monofilm http://www.sailrite.com/Monofilm-5mil-54
Jake Kohl | | | Re: Clear sail for Aquacat 12.5?
[Re: WildBilly66]
#280036 07/23/15 12:17 PM 07/23/15 12:17 PM |
Posts: 12,310 South Carolina | Thanks Jake!
Any thoughts if this clear type of material will be too "brittle" for a non=battened sail? That is will it tear while flopping around in the wind say on a turn? I wouldn't make a whole sail out of it if that is what you mean. It would be too brittle for that. For a window in an existing sail, however, it would be fine. My monohull sailboat has windows in the jib and main made from the same material like this:
Jake Kohl | | |
3,577
guests, and 411
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 Sep 13th, 2025 | | | |
