falcon f16 sugestions #280796
10/13/15 09:06 PM
10/13/15 09:06 PM
Sarasota Florida
Angelo190471 Offline OP
Sarasota Florida
i recently started sailing f16s. i have raced lasers for the past couple years and sailing h16s. im pretty sure the boat im sailing is set up the same way it came from falcon as. is there anything you guy ran different or did differnt that works better or is easier to use?
thanks angelo
Re: falcon f16 sugestions [Re: Angelo190471] #280805
10/14/15 12:37 PM
10/14/15 12:37 PM
dr5e14w Offline
dr5e14w  Offline
thanks angelo
Most of these boats are pretty well sorted. I would learn to sail the boat before making any major changes that could end up just setting you back or over complicating things.
Re: falcon f16 sugestions [Re: Angelo190471] #280806
10/14/15 02:59 PM
10/14/15 02:59 PM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
Hi Angelo,
It's best to start with the factory setting on the boat and the standard trampoline layout. Both you can find here on the US Falcon site: http://www.falconmarinellc.com/?page_id=78
Once you get to know the boat better, you can work on finetuning ofcourse.
I see you're from Sarasota, so there must be quite some Falcons around, have a look/talk with them, that's the fastest way to learn.
Ofcourse if you have any questions you can contact Matt or myself and we'll be happy to help you get things sorted!
Gill
Falcon F16 - BEL666
Boats: TheBoatShop.be
Re: falcon f16 sugestions [Re: Angelo190471] #280812
10/15/15 07:27 PM
10/15/15 07:27 PM
Sarasota Florida
Sarasota Florida
yeah, this is one of the sysp boats. so far it mostly works good, i changed bungies today i think that is the main problem.
Re: falcon f16 sugestions [Re: Angelo190471] #280826
10/18/15 04:17 AM
10/18/15 04:17 AM
Gilo Offline
Gilo  Offline
Yep thats important. If they are not tight the rest doesn't work well either. I replace them once a year.
Falcon F16 - BEL666
0 registered members (), 504 guests, and 552 spiders.
