Hull surface iverhaul #282536
04/26/16 04:07 PM
04/26/16 04:07 PM
The Netherlands, Europe
flying_dutchman Offline OP
Cleaned the hulls of my 1992 Hobie 16 several times with various products. Good results, applied specual wax immediately after.
However within weeks the hulls look very bad again...
Seems only option will be treating hulls with polishing compound (Commandant ?) decreasing and applying spray paint to finish the overhaul
Happy sailing from The Netherlands!
Eddie
Hobie 16 (1992) # 99173 & CT11 - with spi
Re: Hull surface iverhaul [Re: flying_dutchman] #282555
04/28/16 02:15 PM
04/28/16 02:15 PM
Petten Netherlands
N
northsea junkie Offline
N
Petten Netherlands
First polishing and then spraying paint is not a good idea.
I think your hulls need new painting after 24 year!
So first sanding, cleaning and decreasing and then one or two layers D.D. paint (Poly Service, Amsterdam or Nieuwekerk aan de IJssel).
Succes met die klus
ronald
RAIDER-15 (homebuilt)
0 registered members (), 567 guests, and 42 spiders.
