| Re: trailer leaf spring corrosion
#283166 07/24/16 03:13 PM 07/24/16 03:13 PM |
Posts: 4,119 Northfield Mn | Sam is talking about Boeshield T-9 which is probably the best product available to protect raw metal surfaces (It's THE product to protect cast iron tool surfaces). It dries to a tacky film and you may give it a whirl - that whole suspension environment, though, is just brutal on any coating or finish you can put on it. Same stuff as LPS-3 fyi. I think it'll help, but it's not a solution unless your hosting out down on the regular.
[Re: Karl_Brogger]
#283171 07/25/16 12:07 PM 07/25/16 12:07 PM |
Posts: 12,310 South Carolina | Sam is talking about Boeshield T-9 which is probably the best product available to protect raw metal surfaces (It's THE product to protect cast iron tool surfaces). It dries to a tacky film and you may give it a whirl - that whole suspension environment, though, is just brutal on any coating or finish you can put on it. Same stuff as LPS-3 fyi. I think it'll help, but it's not a solution unless your hosting out down on the regular. Good to know...but none of it is cheap. Was hoping the LPS-3 was going to be cheaper than the T-9.
Jake Kohl | | | Re: trailer leaf spring corrosion
[Re: waterbug_wpb]
#283174 07/25/16 10:55 PM 07/25/16 10:55 PM |
Posts: 4,119 Northfield Mn | Should be easier to find though. A good auto parts store should have it, the local Ace Hardware does here as well.
Don't put that stuff on your tools unless you're planning on storing them long term. Use straight paraffin wax, and Bostik glide coat. Keep the AC on and your grubby hands off and it'll be fine. Why the hobbyists on the forums rave about that **** is beyond me.
[Re: Karl_Brogger]
#283176 07/26/16 10:14 AM 07/26/16 10:14 AM |
Posts: 12,310 South Carolina | Should be easier to find though. A good auto parts store should have it, the local Ace Hardware does here as well.
Don't put that stuff on your tools unless you're planning on storing them long term. Use straight paraffin wax, and Bostik glide coat. Keep the AC on and your grubby hands off and it'll be fine. Why the hobbyists on the forums rave about that **** is beyond me. Agreed - That stuff is definitely too tacky for tool surface use. I usually apply it after a project but I clean it with acetone and buff on a standard furniture wax when I'm getting ready to make something serious. I haven't heard of Bostik glide coat and will check it out. The AC stays set at about 82/84 degrees this time of year so it comes on a few times a day to just knock the humidity down a little in the garage.
[Re: waterbug_wpb]
#283180 07/26/16 06:54 PM 07/26/16 06:54 PM |
Posts: 1,403 | Reading this I am wondering if the salt water in FL is different than the salt water in CA....
I've had a steel non galvanized trailer last me many years, with many miles, and many a salt water dunking.... But, I will say when I got the trailer home, it did get pressure washed and rinsed with soap and hot water....
#283181 07/26/16 10:16 PM 07/26/16 10:16 PM |
Posts: 4,119 Northfield Mn | The gulf is way salty-er I think. Or at least the handful of times I've been in the Pacific, I thought where the f did the salt go? Should be easier to find though. A good auto parts store should have it, the local Ace Hardware does here as well.
Don't put that stuff on your tools unless you're planning on storing them long term. Use straight paraffin wax, and Bostik glide coat. Keep the AC on and your grubby hands off and it'll be fine. Why the hobbyists on the forums rave about that **** is beyond me. Agreed - That stuff is definitely too tacky for tool surface use. I usually apply it after a project but I clean it with acetone and buff on a standard furniture wax when I'm getting ready to make something serious. I haven't heard of Bostik glide coat and will check it out. The AC stays set at about 82/84 degrees this time of year so it comes on a few times a day to just knock the humidity down a little in the garage. It's a Teflon spray basically. A little hint if you do get a can, store it upside down. For some reason the diaphragm at the top of the can where the nozzle goes in will crap out if stored upright. Zep used to have a product called Zepalon that kicked butt. I don't have access to it any longer. But then I look and I can get it on Amazon. Thanks Google!
[Re: Ventucky Red]
#283182 07/27/16 08:38 AM 07/27/16 08:38 AM |
Joined: Dec 2001 Posts: 5,590 Naples, FL waterbug_wpb OP
Posts: 5,590 Naples, FL | Reading this I am wondering if the salt water in FL is different than the salt water in CA....
That is an interesting point... I would suspect the salinity varies a bit between ocean and Gulf. Perhaps the biggest reason would be the ambient temperature of both air and sea? Higher temps would accellerate the attack on the spring steel? Checking the mattress for enough dollars to switch to a torsion bar...
[Re: Ventucky Red]
#283185 07/27/16 01:08 PM 07/27/16 01:08 PM |
Posts: 12,310 South Carolina | Reading this I am wondering if the salt water in FL is different than the salt water in CA....
I'll be damned. I guess it makes sense but I never even considered that before.
[Re: waterbug_wpb]
#283186 07/27/16 01:25 PM 07/27/16 01:25 PM |
Posts: 932 Solomon's Island, MD | I guess the east coast is saltier than the west, that might explain a few things over the years...
Jake is right that any lube doesn't do much good in a leaf spring. I can also tell you that my leaf springs on my Trailex, which I replaced a few years ago, started rusting a few months after I installed them, and I coated them with WD-40 and didn't move the trailer, and they were never in saltwater or any water other than rain. Clearly I didn't get the galvanized variety (I think I ordered direct from Trailex), anyway, oh well.
Scorpion F18
[Re: brucat]
#283188 07/27/16 05:41 PM 07/27/16 05:41 PM |
Posts: 1,403 | Don't use Boesheild T-9 on anything that will be exposed to dirt. I see to use it to lube my traveler (before McLube came along), based on rave reviews by my dealer and a fellow sailor. All it did was trap sand/dirt/road grime, which the traveler ground into a fine paste, and made the traveler stickier than if I'd done nothing...
WD-40 is similar, in my experience. I ruined an electric train engine when I was a kid by spraying that on the wheels and motor.
Mike From my experience I wouldn't use any of this stuff... for that very fact... it is a sludge magnet. I had always made it a point to hose off my trailer after sailing as much as the boat... having a pressure washer with the hose to the hot water heater helped Understandably, you won't keep the rust from coming, but maybe retard it some... I get the fact the being exposed to heat and humidity plays a roll here, but... I think being exposed to the salt air is worse... where my boat a trailer are is right on the ocean..
[Re: Ventucky Red]
#283190 07/29/16 07:55 AM 07/29/16 07:55 AM |
Posts: 5,590 Naples, FL | I think being exposed to the salt air is worse... where my boat a trailer are is right on the ocean.. crap... that too. I guess torsion axle it is then.... I wonder how hard it would be to retrofit the torsion axle on (single axle) without upsetting the balance/ alignment? probably something best left to a trailer service business?
[Re: waterbug_wpb]
#283192 07/29/16 09:35 AM 07/29/16 09:35 AM |
Posts: 1,403 | I think being exposed to the salt air is worse... where my boat a trailer are is right on the ocean.. crap... that too. I guess torsion axle it is then.... I wonder how hard it would be to retrofit the torsion axle on (single axle) without upsetting the balance/ alignment? probably something best left to a trailer service business? I was looking at this on eTrailer last night... does not seem like it is that involved. https://www.youtube.com/watch?v=gDv4o83T4cg | | |
2,858
guests, and 353
