Boat towing at sea #283312
08/18/16 04:59 PM
08/18/16 04:59 PM
Near SLC, Utah
tomthouse Offline OP
Near SLC, Utah
Boat Towing at Sea
While towing sounds pretty simple, it usually is only simple in perfect conditions ­ calm winds and seas. When things are easy like that you need only get in front of the other boat and toss them a line.
(Note on tossing a line: coil the throwing line so there are no kinks. Separate the coil in two with the bitter end of the coil in your throwing hand, the rest of the coil on the other hand. Then toss the line over and past the receiver. The hand not throwing should be laid open and pointing toward the receiver so the rest of the coil will easily exit the hand.)
Most folks just tie the line to the stern of the towing boat. But, that is the worst place you can secure it (especially on a sailboat and even worse on a small sailboat).
Remember, when you turn a boat the point on which it turns is usually near the bow and the stern swings out. If the tow line is on the stern, whcih restricts the stern from swinging out and thereby makes steering the towing boat almost impossible. So, the tow line should be as far forward as possible.
In some cases I've tied the tow line (on small sailboats) directly to the mast base so the tow boat can actually pivot and turn, while towing another craft.
Keep the boats in the similar wave patterns by adjusting the length of the tow line so that both boats are either going up a wave or down a wave at the same time.
My big goal in life is to rescue a power boat using my sailboat.
Always tow at moderate speeds, look and think ahead.
Think safety.
Re: Boat towing at sea [Re: tomthouse] #283314
08/19/16 02:15 AM
08/19/16 02:15 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Well said I've been rescued in a coastal race in pretty solid waves by inexperienced rescue boat where everything was done wrong including by me and I'm lucky I have any fingers and our lives
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Boat towing at sea [Re: JeffS] #283315
08/19/16 06:25 AM
08/19/16 06:25 AM
RickWhite Offline
RickWhite  Offline
Funny, Tom, I have been towed in by a sailboat twice while in a powerboat. Once, a Tornado pulled me in Miami, and another time and Laser did.
We made it.
Rick
Rick White
www.onlinemarinestore.com
Re: Boat towing at sea [Re: RickWhite] #283318
08/19/16 12:16 PM
08/19/16 12:16 PM
cyberspeed Offline
cyberspeed  Offline
It was pretty tricky given the sea state, north current and south wind.
Full Story >>>
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: Boat towing at sea [Re: tomthouse] #283320
08/19/16 04:26 PM
08/19/16 04:26 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Done that, got the t-shirt.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Boat towing at sea [Re: tomthouse] #283321
08/19/16 07:16 PM
08/19/16 07:16 PM
catman Offline
catman  Offline
Boat Towing at Sea
Think safety.
I've towed an 18ft power boat with my Hobie 18 about a mile to safety. We used to brag about all our rescues. That's my 225th rescue....... LOL. The best is when you tow a dismasted boat and fly the hull the whole way back. Three different times.
Re: Boat towing at sea [Re: catman] #283350
08/22/16 10:43 PM
08/22/16 10:43 PM
hobie1616 Offline
hobie1616  Offline
That's rubbing it in.
0 registered members (), 328 guests, and 26 spiders.
