| Rigging H16 Jib Traveler with bungee cord #283564 09/30/16 03:57 PM 09/30/16 03:57 PM |
Posts: 8 | I searched the posts but could not find it--know answer is out there somewhere--sorry for the duplication. I have one of the original jib traveler set ups with a pin that you have to manually pop-up to move along the track to adjust the angle of the jib when running or heading to windward. It looks like this diagram. http://www.thebeachcats.com/pictures?g2_itemId=10632Can someone please send me a picture and describe how you could rig a bungee to allow the traveller to move more easily when solo sailing? Hard to get up front to undo the pin sometimes. I imagine that it is a bungee or shock cord(?) tied off (to something?) and then something like rope or tape to hold the pin up permanently so that it does not go into the traveler track pin hole. Advice welcome. | | | Re: Rigging H16 Jib Traveler with bungee cord
[Re: Dr. Pitchpole]
#283580 10/02/16 10:42 AM 10/02/16 10:42 AM |
Posts: 3,969 | As shown in the post attached above, you can simply use one bungee line, and connect the two cars to one another. The linked drawing shows a pad eye on the front of the crossbar, but you could just run it from one car, the under the front of the crossbar, then behind the dolphin striker post, and then out and up to the other car.
I used to use two bungees, and just run one from each car and tie it off on the dolphin striker. That way, I could get good tension without worrying about moving one car in to pull the other out. I may have been over thinking it at the time...
You mainly just want to keep the bungee away from the rotating mast base. If a bungee gets stuck in there, it will be destroyed.
Mike | | | Re: Rigging H16 Jib Traveler with bungee cord
[Re: jollyrodgers]
#283596 10/03/16 05:46 PM 10/03/16 05:46 PM |
Posts: 5,582 “an island in the Pacifi... | the bungee pulls the cars outboard, not inboard. You don't need the bungee, but you do need the outer turning blocks with some mini cleats. The bungee pulls the cars inboard, not outboard. The line through the cheek blocks pull the cars outboard to the corner castings. You can get away without the bungee pulling the cars to center and letting the tensioned jib sheet do the job. I liked the positive return by using the bungee. US Sail Level 2 Instructor US Sail Level 3 Coach | | |
2,782
guests, and 579
