| Re: What's up with the America's Cup
[Re: Timbo]
#286795 05/12/17 02:15 PM 05/12/17 02:15 PM |
Posts: 586 Hobart, Tasmania, Oz. | 50 footers and not nearly as fast, they are way faster that the 72's around the course. seems that the rig and hulls are not as important as the foils These cats are what, 45 feet long?
And they are making nearly the same speeds as the 72' cats from 3 years ago!
Wow.
It used to be that a longer waterline made for a faster boat, but once they get up on the foils I guess it comes down to weight and sail area for determining max speed. Foil mechanics and control are becoming more important than waterline length.
[Re: mbounds]
#286796 05/12/17 05:52 PM 05/12/17 05:52 PM |
Posts: 12,310 South Carolina | The bow down attitude is the result of restrictions in the angle of the rudder foils and the different speeds upwind vs. downwind.
Upwind, the boats are relatively level; the boats are moving 25-30 kts. A higher angle of attack is required on the rudder foils to lift and stabilize the back of the boat.
Downwind, the speed increases to 35-40 kts; a lower angle of attack on the rudder foils is required to achieve the same lift, so the boats assume a bow-down attitude. I do realize that's what Oracle said about their bow down...but it also stands to reason that they would want to rake their rigs more vertically when sailing downwind and rake them back upwind...all I'm sayin. There is no advantage for everyone to spill their techniques - trust nothing any team says at this stage
Jake Kohl | | | Re: What's up with the America's Cup
#286800 05/13/17 08:56 AM 05/13/17 08:56 AM |
Posts: 1,403 | | | | Re: What's up with the America's Cup
[Re: Mike Fahle]
#286824 05/18/17 09:56 AM 05/18/17 09:56 AM |
Posts: 12,310 South Carolina | This whole bike thing has a tinge of "absurdity" to it.
#286826 05/18/17 10:55 AM 05/18/17 10:55 AM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | Cap'n Don says it's a hoax. Cap'n Bob says it's a fad. But NZ has a long memory of yelling "Hydro, hydro...!" back in San Francisco when pressure went down. I bet it was high on their "never again" list. Listen in at about 1:48 NZ f-upI love watching these old videos of SF. Would someone post once again how to embed a video, please. | | | Re: What's up with the America's Cup
#286828 05/18/17 12:13 PM 05/18/17 12:13 PM |
Posts: 5,590 Naples, FL | This whole bike thing has a tinge of "absurdity" to it. Legs have more power than arms (well, except for kenny), so I would have thought a recumbant type setup with proper gearing could do the trick.. I hadn't thought about in-line bicycle style pedaling. But I guess you could stand up and crank (can't do that in recumbant format)
[Re: David Parker]
#286829 05/18/17 12:50 PM 05/18/17 12:50 PM |
Posts: 118 fl | Cap'n Don says it's a hoax. Cap'n Bob says it's a fad. But NZ has a long memory of yelling "Hydro, hydro...!" back in San Francisco when pressure went down. I bet it was high on their "never again" list. Listen in at about 1:48 NZ f-upI love watching these old videos of SF. Would someone post once again how to embed a video, please. Dave, I don't see it anymore = perhaps when Damon made the upgrade (march) the feature to embed a video has disappeared and all you can do is post it as a link
Mn3
[Re: Mike Fahle]
#286833 05/19/17 07:21 AM 05/19/17 07:21 AM |
Posts: 12,310 South Carolina | Mike,
I didn't mean in the sense of technology or whether or not it made sense - I just meant in the sense of sailing. I'm very familiar with the systems in use on those boats. I'm all for multihulls, wings, foils, etc. at the bleeding edge of the sport but you take someone not familiar with the America's cup and show them the New Zealand boat, everyone jumps to the conclusion that they are peddling props on the bottom of the boat. It takes a lot of explaining through furrowed brows that the bicycles (another mode of human transportation) were mounted to a sailboat (typically considered relatively slow) to build up hydraulic pressure so the two or three guys at the back of the boat can push buttons and control the sails and foils and make it go. To someone not fully invested in sailing as a sport, it sure as hell seems like a lot of complication to go 40 miles an hour....hence the tinge of absurdity.
#286834 05/19/17 08:46 AM 05/19/17 08:46 AM |
Posts: 5,590 Naples, FL | Jake, I'm sure they said that back in the days of the galley boats... Lots of dudes sitting at oars while a guy in the back pounds a drum and pushes buttons (or rudder) But you engineers could help me understand the most efficient way to store hydraulic power. Since liquids are essentially non-compressible, are they building up pneumatic pressure to apply the hydraulics later? If not what is the mechanism used to "build" up the power to be used "during peak demand"?
[Re: waterbug_wpb]
#286835 05/19/17 12:04 PM 05/19/17 12:04 PM |
Posts: 118 fl | But you engineers could help me understand the most efficient way to store hydraulic power.
I'm no engineer but i did stay near a Holiday Inn last night... i think they use this type of machine to build and store the hydro power
Mn3
[Re: waterbug_wpb]
#286838 05/20/17 11:00 AM 05/20/17 11:00 AM |
Joined: Jan 2005 Posts: 6,049 Sebring, Florida. Timbo OP
Posts: 6,049 Sebring, Florida. | I know on most big jets there are hydraulic accumulators that do have a nitrogen precharge of around 1000 psi. This accumulator system is usually only on the brakes. The problem is, once you pump the breaks a couple times, the precharge is gone, so you need hydraulic pumps (either electric or mechanical off the gearbox) to recharge the system.
There are period of very high demand for hydraulic pressure on an airliner, which are when the gear is retracted right after takeoff and at flap extension/gear door retraction after extension on configuring for landing. The 767 and 777, in addition to electric and mechanical hydraulic pumps, have an air driven demand pump, which use bleed air off the engines and only kicks on during periods of high demand, or if one/both of the electric/mechanical pumps fail.
Blade F16 #777
[Re: waterbug_wpb]
#286844 05/22/17 11:52 AM 05/22/17 11:52 AM |
Posts: 12,310 South Carolina | So does anybody have any idea if/when/where we will be able to watch any of the America's Cup racing here in the USA?
Jake Kohl | | |
544
guests, and 111
