| Re: Hull cover leakage
[Re: Arjan13]
#288700 04/01/18 04:47 AM 04/01/18 04:47 AM |
Posts: 1,383 Kingston SE South Australia | If you can get rid of all traces of silicone, Marine grade Sikaflex is awesome but it won't stick on top of silicone
[Re: Arjan13]
#288717 04/11/18 12:32 PM 04/11/18 12:32 PM |
Posts: 1,187 38.912, -95.37 | sikaflex 291 is what you want It is a Swiss product, and what all boat builders are using these days Less than half the cost of 3M
Unfortunately not available in small tubes, like 3M products
[Re: Arjan13]
#288720 04/12/18 08:28 AM 04/12/18 08:28 AM |
Posts: 932 Solomon's Island, MD | John,
Does Sikaflex 291 harden in the tube after opening? I recently learned that freezing the 3M products prolongs their in-tube life indefinitely.
-Sam
Scorpion F18
[Re: samc99us]
#288730 05/01/18 12:23 PM 05/01/18 12:23 PM |
Posts: 1,187 38.912, -95.37 | Sam,
Yes, moisture and air are enemies. Put in a storage bag in the freezer. (the fridge is for gelcoat ;p)
[Re: Arjan13]
#288759 05/08/18 07:51 AM 05/08/18 07:51 AM |
Posts: 932 Solomon's Island, MD | My recommendation is to apply the non-skid that you see on newer F18's/A-Cat's. There are several brands, Seadek and Raptor Decking come to mind. The other option is a strip of non-skid tape: https://webshop.nacrasailing.com/product/non-skid-tape-black-per-meter/The final option is basically a strip of the 3-6mm non skid EVA decking along the side of the hull (where your feet go), the 505 guys use a sort of tire-like rubber for this that works quite well. I applied a full EVA deck to my Infusion Mk. 1 and it was the best upgrade we made to the boat, much more comfortable in all positions and super grippy. I used the 3mm raptor decking.
Scorpion F18
[Re: Arjan13]
#288764 05/09/18 05:44 AM 05/09/18 05:44 AM |
Posts: 1,383 Kingston SE South Australia | International has a granular additive to add to paint or gel coat, it's rounded so no sharp edges, I've done it to a few boats now, I apply it with a 4 inch high density roller. You mix it in the paint tray and go over the surface once, if that's not enough grip you go back over a second time straight away and it sticks a lot more grip on, it's very good and much cheaper than tape
[Re: Arjan13]
#288765 05/10/18 06:30 AM 05/10/18 06:30 AM |
Posts: 932 Solomon's Island, MD | Arjan,
A strip of EVA foam will stick if you use contact cement to fasten it, or super glue the edges. Paint works fine too I just find it messy and painful compared with EVA.
-Sam
Scorpion F18
2,647
guests, and 503
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 4 hours ago | | |
