Supercat 17 main sheet question #289056
01/16/19 08:09 PM
01/16/19 08:09 PM
Hopkinsville, Ky
DaleYoung Offline OP
Hopkinsville, Ky
I'm in the process of restoring 2 Supercat 17s. I'm seeing 3 different mainsheet options for these boats that changed over a period of time. One is a a track with a car, another was a triangular floating-type of car that ran along a cable, and the 3rd was a fixed main sheet in the middle of the rear cross tube.
Which option is best, and why?
Thanks in advance.
Re: Supercat 17 main sheet question [Re: DaleYoung] #289057
01/17/19 12:37 AM
01/17/19 12:37 AM
cyberspeed Offline
cyberspeed  Offline
track with a car
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: Supercat 17 main sheet question [Re: cyberspeed] #289058
01/17/19 06:51 AM
01/17/19 06:51 AM
Hopkinsville, Ky
Hopkinsville, Ky
Kinda what I figured. Thanks!
Re: Supercat 17 main sheet question [Re: cyberspeed] #289059
01/18/19 10:07 AM
01/18/19 10:07 AM
Dunedin Causeway, FL
David Parker Offline
Get rid of the cable and car arrangement ASAP. I have heard stories where fingers were crushed and/or severed by being caught up in the car.
A fixed main is also terrible. With no diamonds and a super stiff mast the boat is very hard to depower. You'll need the traveler. It's a pig without a jib so the traveler is all you've got.
Words of wisdom on a SC17: Weight FORWARD. Add 18" to your tiller extension. You'll find your can point crazy high if you're up on the front beam or even in front of the beam. In a puff, step forward even further. And wear goggles as it's the wettest lee bow you'll ever see. Wahoo! What a hoot!
Sail it solo.
Re: Supercat 17 main sheet question [Re: David Parker] #289060
01/20/19 08:05 AM
01/20/19 08:05 AM
Hopkinsville, Ky
Hopkinsville, Ky
Thanks for the info!!
Re: Supercat 17 main sheet question [Re: cyberspeed] #289065
02/08/19 05:37 PM
02/08/19 05:37 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Originally Posted by cyberspeed
track with a car
Ditto
Luiz
Re: Supercat 17 main sheet question [Re: David Parker] #289066
02/08/19 05:38 PM
02/08/19 05:38 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Originally Posted by David Parker
Sail it solo.
Not in a breeze
Luiz
0 registered members (), 428 guests, and 413 spiders.
