Question about tiller extension uv joint #289218
11/27/19 05:07 PM
11/27/19 05:07 PM
almoniyot Offline OP
I am in the process of building my own rudder/tiller and picked up one of these Allen tiller extension universal joints. Allen tiller extension uv joint
The thing is, it seems much too rigid to me. It is quite difficult to bend. How am I going to stop my tiller extension from pointing upward towards the sky?
Re: Question about tiller extension uv joint [Re: almoniyot] #289219
11/28/19 05:39 AM
11/28/19 05:39 AM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
Don't worry. It will bend under the weight of a long tiller extension. It is the same as the one I use.
Dermot
Catapult 265
Re: Question about tiller extension uv joint [Re: Dermot] #289220
11/28/19 09:05 AM
11/28/19 09:05 AM
Thanks for the reassurance. My tiller extension is roughly 1 meter long. If it does not work I will build my own using a thrust bearing and a small piece of U profile.
Re: Question about tiller extension uv joint [Re: almoniyot] #289221
11/29/19 05:16 PM
11/29/19 05:16 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
1 metre is quite short for a tiller extension on a cat, even if you are only hiking, not trapezing.
Dermot
Catapult 265
Re: Question about tiller extension uv joint [Re: almoniyot] #289222
12/09/19 01:35 AM
12/09/19 01:35 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
I haven’t seen one of those but you don’t have to put it on top of the crossbar, you can put it pointing slightly forward towards the boat no problem and the rigidity will help
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
0 registered members (), 519 guests, and 358 spiders.
